[Geoserver-users] EOFException: Premature end of file parsing the tasmania_water_bodies feature
When I do a Save after changing the password, I get this to the stdout.log
and similar EOF messages to the screen:
61104878 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType tasmania_water_bodies
61104879 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding
file name: tasmania_water_bodies:::tasmania_water_bodies
61105099 [SEVERE] org.vfny.geoserver.global.Data - FeatureTypeInfo
DS_giant_polygon:::giant_polygon ignored - as DataStore DS_giant_polygon is
unavailable:java.io.EOFException: Premature end of file
61105104 [SEVERE] org.vfny.geoserver.global.Data - FeatureTypeInfo
DS_tiger_roads:::tiger_roads ignored - as DataStore DS_tiger_roads is
This sort of looks like an XML parsing error, but there are no XML errors.
This version of GeoServer is running in WebLogic 8.1. I should also note
that the GeoServer tree was saved to CVS and restored before porting to
WebLogic.
View this message in context: http://www.nabble.com/EOFException%3A-Premature-end-of-file-parsing-the-tasmania_water_bodies-feature-tf3817292.html#a10806840
