[Geoserver-users] EPSG 23700 transform fails
I’ve installed Geoserver 2.2.4 and I realized the layers in EPSG 23700 (EOV Hungarian Reverence system), are not transformed properly. I made a map based on openlayers script and I realized Hungary is seated in area of Columbia. And if I chose kml geoserver output, the result is the same.
(an example point coordinate for test: x: 650000, y: 240000 located in the middle of Budapest)
It works only in one case: I need to choose the proper (EOV Hungariyan Datum… ) coordinate system for example in ArcMap, the layers are appears, but can not transformed into other CRS.
I tried to investigate something, and I found a gt-epsg-hsql-8.2.jar in Geoserver. I replaced (and renamed) with an old (2.1.1) version, and the problem has seemed to solve. But in every newer version this transform does not works properly.
It seems a Hotine_Oblique_Mercator and Oblique_Mercator difference. (But nothing is differs in parameters.)
Please take a look on it, why transforms wrong!
Thanks for advance!
Zsolt, Magyar
Hi Zsolti,
A bug in the Hotine implementation seems to be the source of the problem.
Until it is fixed, a usable workaround is to add the EOV transformation
parameters as WKT to the epsg_overrides.properties file, changing the
projection name in it from Hotine_Oblique_Mercator to Oblique_Mercator.
more details here:
http://docs.geoserver.org/stable/en/user/advanced/crshandling/customcrs.html
I am also using it for epsg:23700 and looks OK.
cheers,
GEDE Mátyás
ELTE Térképtudományi és Geoinformatikai Tanszék, Budapest
On Mon, 18 Feb 2013 10:19:25 +0100, Zsolt Magyar wrote
[UTF-8?]I’ve installed Geoserver 2.2.4 and I realized the layers in EPSG
Hungariyan [UTF-8?]Datum… ) coordinate system for example in ArcMap, the
Thanks for advance!
Zsolt, Magyar
