By the way, the EPSG database seems to also have the E,N oriented variant, it’s under a different code:
On Thu, Sep 1, 2016 at 6:46 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Sep 1, 2016 at 6:15 PM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
Hi
I’m using GeoServer 2.9 and I’m seeing that the output axes for EPSG:32661 is Northing-Easting. The bug https://osgeo-org.atlassian.net/browse/GEOS-6354 documents that the axis is swapped and says that EPSG:32661 does not follow the standard. This bug report was closed under 2.5 but I’m still seeing that the layer in 2.9 is Northing-Easting and not Easting-Northing. Was EPSG:32661 actually fixed to follow the standard?
Your standard does not agree with the official EPSG database, which explicitly states that CRS is north/east oriented, calling it “WGS 84 / UPS North (N,E)”:
https://epsg.io/32661
The EPSG database is the standard for OGC services. If it’s wrong, you should raise a ticket against the database itself (it happens, it gets fixed)
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
