I read about this bug
http://jira.codehaus.org/browse/GEOS-1961
so i have to change my version (1.7.0-beta1) to 1.6.5 or 1.7.0
Where can I found them as installer4Win?
Could i use 1.6.2, too?
My aim is to use a PostGIS Layer with SRDI=-1 and declare GeoServer FeatureType with SRS=900913. I tryed also to add in postgis spatial_ref_sys table the SRS=900913 as following:
proj4='+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs'
WKT=
PROJCS["unnamed",
GEOGCS["unnamed ellipse",
DATUM["unknown",
SPHEROID["unnamed",6378137,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Mercator_2SP"],
PARAMETER["standard_parallel_1",0],
PARAMETER["central_meridian",0],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
or WKT=
PROJCS["WGS84 / Google Mercator", GEOGCS["WGS 84", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Longitude", EAST], AXIS["Latitude", NORTH], AUTHORITY["EPSG","4326"]], PROJECTION["Mercator_1SP"], PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","900913"]]
but nothing happened..
Thanks!
Ing. Fabio D'Ovidio
INOVA Open Solutions s.r.l.
Web : http://www.inovaos.it
Tel.: 081 197 57 600
mail: fabiodovidio@anonymised.com
