Hello all,
I am trying to add my own coverage dataset to geoserver which is referenced in EPSG:23031. It seems to get loaded correctly but when I try to preview it, it shows the following error:
No authority was defined for code "23031". Did you forget "AUTHORITY:NUMBER"?
It seem to be a paremeter in SRS definition, but I do not know what it means.
Did anyone else faced same problems with others SRS.
<br>-- <br> Aitor Calero García<br> [aitor.calero@anonymised.com](mailto:aitor.calero@anonymised.com)<br> [aitor.calero@anonymised.com](mailto:aitor.calero@anonymised.com)<br> Atos Research & Innovation<br> Atos Origin Spain<br> C/ Albarracín, 25 - 28037 Madrid (Spain) <br> Tel. (+34) 91 214 8805 <br> Fax. (+34) 91 754 3252<br> [http://www.atosresearch.eu](http://www.atosresearch.eu)<br> Before printing this e-mail, think if it is really necessary<br><br>
Aitor Calero García ha scritto:
Hello all,
<ServiceException code="InvalidSRS">No authority was defined for code "23031". Did you forget "AUTHORITY:NUMBER"?</ServiceException>
please have a look in the GeoServer logs and report back the full stack
trace for this error. Btw, which version of GeoServer are you using?
El vie, 10-08-2007 a las 12:30 +0200, Andrea Aime escribió:
I am usign Geoserver 1.5.2 (the last one), and the complete stack trace is added at the end of this emai, but by the way, I connot configure geoserver to create the log properly. I have changed it in Server Settings but my log file is empty!
Error message:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?> org.vfny.geoserver.wms.WmsException: No authority was defined for code "23031". Did you forget "AUTHORITY:NUMBER"?
at org.vfny.geoserver.wms.requests.GetMapKvpReader.parseOptionalParameters(GetMapKvpReader.java:253)
at org.vfny.geoserver.wms.requests.GetMapKvpReader.getRequest(GetMapKvpReader.java:216)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:299)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:445)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1050)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1041)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:354)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:226)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:627)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
at org.mortbay.jetty.Server.handle(Server.java:269)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:430)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:687)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:492)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:199)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:339)
at org.mortbay.jetty.nio.HttpChannelEndPoint.run(HttpChannelEndPoint.java:270)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
Error message:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?><!DOCTYPE ServiceExceptionReport SYSTEM "http://localhost:8080/geoserver/schemas//wms/1.1.1/WMS_exception_1_1_1.dtd"> <ServiceExceptionReport version="1.1.1"> <ServiceException code="InvalidSRS">org.vfny.geoserver.wms.WmsException: No authority was defined for code "23031". Did you forget "AUTHORITY:NUMBER"?
Hum... how are you trying to preview it? It seems the GetMap request
contains SRS=23031 instead of SRS=EPSG:23031, yet the built it standard GeoServer preview should use the EPSG:xxx form...
