My geoserver install has gone funny, it looks like I am having problems with the EPSG database. When I load the srs help page (http://localhost:8080/geoserver/srsHelp.do ) I get the error below in the console version.
It started happening in my 1.5.0 version so I tried 1.5.1 and that has the same error
Any ideas what might be going on and how I can solve it?
Thanks
Jerry
WARNING: Issues converting EPSG:42106. Error in “PROJECTION”: No transform for c
lassification “Lambert_Azimuthal_Equal_Area”. Stack trace included at FINER logg
ing level
As far as I know, the transformation for “Lambert_Azimuthal_Equal_Area” isn’t in the version of geotools used for for GS 1.5.x…I know this because I have a project where I would really like to use a projection of this type. and found i can’t. To fix it , I would just delete the record from of the epsg db, since you can’t use it anyway.
Steve
Stephen Crawford
Center for Environmental Informatics
GeoVISTA Center
The Pennsylvania State University
From: geoserver-users-bounces@lists.sourceforge.net [mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Jerry O’Sullivan
Sent: Friday, June 08, 2007 3:36 PM
Subject: [Geoserver-users] EPSG Error
Thanks
Jerry
ing level
Thanks for the suggestions Stephen…
after much install and uninstalling (which was probably unnecessary) I think the problem was due to the fact that some of the GeoTools files in the temp directory (C:\Documents and Settings\username\Local Settings\Temp) were missing. Completely removing the geotools directory did the trick as the SRS database was rebuilt when geoserver was launched
Steve
Stephen Crawford
GeoVISTA Center
Thanks
Jerry
ing level
