[Geoserver-users] Epsg problem
All,
I accidentally posted this to GeoTools list instead of GeoServer....so for
any cross posting:
I'm running Geoserver 1.4, with postGIS datastore. I'm trying to create a
custom srs for a project, something I've successfully done a few times
before.....I unpack the gt2-epsg.jar, add the wkt to the epsg.properties
file, repack the jar. However this time I get a message saying "Could not
construct a SRS tranformation- No tranform for classification
'Lambert_Azimuthal_Equal_Area'". I looked at the existing srs's in the epsg
table, and at least a few use this tranformation...so I tried using one of
these srs's jut to test, and I get the same message. This implies (to me,
anyway) that some of the projections listed by geoserver actually don't
work. Is this true? Is there a list of the available tranformations for
Geoserver? Can I add a tranformation to Geoserver?
Lambert_Azimuthal_Equal_Area is listed in proj4, with code -proj laea.
Thanks Again,
Steve
Stephen Crawford
Center for Environmental Informatics
GeoVISTA Center
The Pennsylvania State University
814.865.9905
src176@anonymised.com
