Thank you for your reply, which serves to remind me that I should have posted the solution to the list, because I was able to resolve this.
I realized after going through the documentation that the ImageMosaic plugin would need write permission to the mosaic directory. Once I gave the tomcat user write permission to the directory, creating the mosaic worked.
I would make two suggestions for the documentation/implementation of the ImageMosaic plugin. One, that write failures to the mosaic directory have a clear error message. As you can see from my original post, there were no hints. Two, creating an image mosaic and then viewing it caused Geoserver to throw ‘too many open files’ errors. A bit of documentation on how to increase the limit on the number of open files would be a good addition to the ImageMosaic docs. Once I figure out all of the steps, I would be glad to contribute that.
On Thu, Sep 18, 2014 at 9:03 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com.> wrote:
Hi Garey,
sorry for the late reply.
Could you please report the full log exception?
Could you also report the gdalinfo output?
Best Regards,
Daniele
Generate messages about directories that cannot be
read, files that cannot be opened … rather than being silent …
(from man du
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Mon, Sep 8, 2014 at 8:01 PM, Garey Mills <gmills@anonymised.com> wrote:
Using Geoserver 2.5.2 with GDAL extensions installed on RHEL6, I have a directory of ‘.img’ files which should form a mosaic. Using gdalinfo I can see that the ‘*.img’ files are in Erdas Imagine format. Each file is accompanied by an ‘img.xml’ and an '.rrd’ file.
When, however, I try to import the directory into Geoserver, (ImageMosaic store, when creating the store I choose the directory containing the images, I get the following message:
Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:data/ and hints null
This error message appears in the logs as well
ImageMosaic docs say that GDAL image formats can be used. What might be the problem?
Garey Mills
(from man du
Want excitement?
Manually upgrade your production database.
When you want reliability, choose Perforce
Perforce version control. Predictably reliable.
http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk
Geoserver-users mailing list
