[Geoserver-users] ERROR 503 (Again)
Hello all,
Since I couldn't find the sollution in previous posts with the same problem,
I need to present my problem with Geoserver here. Anyway, I installed
Geonetwork 2.10.4 and in installation process I checked installation of
Geoserver too. Geonetwork works fine, but when I try to go on
localhost:8080/geoserver I get ERROR 503 message:
HTTP ERROR: 503
Problem accessing /geoserver. Reason:
    Service Unavailable
Powered by Jetty://
Here is geoserver.log:
2010-04-14 10:54:39,069 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: D:\projects\gn24Xbranch\jetty\..\data\geoserver_data
2010-04-14 10:54:39,166 INFO [storage.DefaultStorageFinder] -
2010-04-14 10:54:39,167 INFO [storage.DefaultStorageFinder] - *** Found
System environment variable GEOSERVER_DATA_DIR set to
../data/geoserver_data, using it as the default prefix. ***
2010-04-14 10:54:39,169 INFO [config.XMLConfiguration] - Failed to find
geowebcache.xml. This is not a problem unless you are trying to use a custom
XML configuration file.
2010-04-14 10:54:40,010 INFO [jdbc.JDBCMBWrapper] - MetaStore database is
version 110
2010-04-14 10:54:40,011 INFO [jdbc.JDBCMBWrapper] - Upgrading H2 database
from 110 to 120
2010-04-14 10:54:40,011 INFO [jdbc.JDBCMBWrapper] - Running database upgrade
from 110 to 111
2010-04-14 10:54:40,060 INFO [jdbc.JDBCMBWrapper] - Database upgrade from
110 to 111 completed
2010-04-14 10:54:40,060 INFO [jdbc.JDBCMBWrapper] - Running database upgrade
from 111 to 120
2010-04-14 10:54:40,065 INFO [jdbc.JDBCMBWrapper] - Database upgrade from
111 to 120 completed
2010-04-14 10:54:40,297 INFO [geoserver.catalog] - Loaded namespace 'gn'
(http://geonetwork-opensource.org)
2010-04-14 10:54:40,322 INFO [geoserver.catalog] - Loaded namespace 'cite'
(http://www.opengeospatial.net/cite)
2010-04-14 10:54:40,346 INFO [geoserver.catalog] - Loaded namespace 'topp'
(http://www.openplans.org/topp)
2010-04-14 10:54:40,352 INFO [geoserver.catalog] - Default namespace: 'gn'
2010-04-14 10:54:40,389 INFO [geoserver.catalog] - Loaded style 'capitals'
2010-04-14 10:54:40,405 INFO [geoserver.catalog] - Loaded style
'simple_roads'
2010-04-14 10:54:40,417 INFO [geoserver.catalog] - Loaded style 'grass'
2010-04-14 10:54:40,429 INFO [geoserver.catalog] - Loaded style 'cite_lakes'
2010-04-14 10:54:40,442 INFO [geoserver.catalog] - Loaded style 'green'
2010-04-14 10:54:40,454 INFO [geoserver.catalog] - Loaded style
'giant_polygon'
2010-04-14 10:54:40,465 INFO [geoserver.catalog] - Loaded style 'restricted'
2010-04-14 10:54:40,478 INFO [geoserver.catalog] - Loaded style 'line'
2010-04-14 10:54:40,505 INFO [geoserver.catalog] - Loaded style
'simple_streams'
2010-04-14 10:54:40,519 INFO [geoserver.catalog] - Loaded style 'pophatch'
2010-04-14 10:54:40,532 INFO [geoserver.catalog] - Loaded style 'poi'
2010-04-14 10:54:40,544 INFO [geoserver.catalog] - Loaded style 'polygon'
2010-04-14 10:54:40,557 INFO [geoserver.catalog] - Loaded style 'raster'
2010-04-14 10:54:40,570 INFO [geoserver.catalog] - Loaded style 'point'
2010-04-14 10:54:40,583 INFO [geoserver.catalog] - Loaded style
'tiger_roads'
2010-04-14 10:54:40,598 INFO [geoserver.catalog] - Loaded style 'burg'
2010-04-14 10:54:40,622 INFO [geoserver.catalog] - Loaded style 'dem'
2010-04-14 10:54:40,637 INFO [geoserver.catalog] - Loaded style
'poly_landmarks'
2010-04-14 10:54:40,650 INFO [geoserver.catalog] - Loaded style 'rain'
2010-04-14 10:54:40,663 INFO [geoserver.catalog] - Loaded style 'population'
2010-04-14 10:54:41,550 INFO [geoserver.catalog] - Processed data store
'country_boundaries', enabled
2010-04-14 10:54:41,570 INFO [geoserver.catalog] - Processed coverage store
'BlueMarble_world', enabled
2010-04-14 10:54:42,960 WARN [referencing.factory] - Axis elements found in
a wkt definition, the force longitude first axis order hint might not be
respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0],
UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"],
PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y",
NORTH], AUTHORITY["EPSG","54004"]]
2010-04-14 10:54:43,169 INFO [geoserver.catalog] - Loaded feature type
'gn:gboundaries'
2010-04-14 10:54:43,963 INFO [layer.TileLayerDispatcher] -
ConfigurationLoader acquired lock, sleeping 5 seconds
2010-04-14 10:54:43,970 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked
setServletPrefix(gwc)
2010-04-14 10:54:43,978 INFO [wms.WMSService] - Will proxy requests to
backend that are not getmap or getcapabilities.
2010-04-14 10:54:43,996 INFO [wfs.WFSService] - Configured to forward to
http://localhost:8080/geoserver/wfs , timeout is 600000ms regex filter
2010-04-14 10:54:44,109 INFO [rest.RESTDispatcher] - Created RESTDispatcher
with 7 paths
2010-04-14 10:54:44,234 INFO [geoserver.confg] - Loading service 'wcs'
2010-04-14 10:54:44,270 INFO [geoserver.confg] - Loading service 'wfs'
2010-04-14 10:54:44,311 INFO [geoserver.confg] - Loading service 'wms'
2010-04-14 10:54:45,965 INFO [layer.TileLayerDispatcher] -
ConfigurationLoader woke up, initializing
2010-04-14 10:54:46,048 INFO [layer.TileLayerDispatcher] - Adding layers
from GeoServer Catalog Listener
2010-04-14 10:54:46,048 INFO [layer.TileLayerDispatcher] - Adding:
gn:gboundaries
2010-04-14 10:54:46,048 INFO [layer.TileLayerDispatcher] - Adding: gn:world
2010-04-14 10:54:46,049 ERROR [config.XMLConfiguration] - Configuration file
cannot be read or does not exist!
2010-04-14 10:54:46,049 INFO [config.XMLConfiguration] - Found configuration
file in D:\projects\gn24Xbranch\web\geoserver\..\resources
2010-04-14 10:54:46,049 INFO [layer.TileLayerDispatcher] - Adding layers
from D:\projects\gn24Xbranch\web\geoserver\..\resources
2010-04-14 10:54:46,049 ERROR [layer.TileLayerDispatcher] - Configuration
D:\projects\gn24Xbranch\web\geoserver\..\resources contained no layers.
2010-04-14 10:54:46,058 ERROR [layer.TileLayerDispatcher] - Error reading
service information from D:\projects\gn24Xbranch\web\geoserver\..\resources:
Error parsing file
D:\projects\gn24Xbranch\web\geoserver\..\resources\geowebcache.xml
2010-04-14 10:54:46,059 INFO [layer.TileLayerDispatcher] -
ConfigurationLoader completed
2010-04-14 10:58:48,864 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException:
org.geoserver.platform.ServiceException: Service WCS is disabled
  at
org.geoserver.ows.DisabledServiceCheck.serviceDispatched(DisabledServiceCheck.java:58)
  at
org.geoserver.ows.Dispatcher.fireServiceDispatchedCallback(Dispatcher.java:387)
  at org.geoserver.ows.Dispatcher.service(Dispatcher.java:382)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:213)
  at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
  at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
  at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
  at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
  at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:502)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1124)
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1115)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
  at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
  at
  at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at
  at
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
  at
  at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
  at
  at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
  at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at
  at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
  at
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:361)
  at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:766)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:417)
  at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:230)
  at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:534)
  at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:879)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:741)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:213)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:403)
  at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
  at
org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:522)
Caused by: org.geoserver.platform.ServiceException: Service WCS is disabled
  at
org.geoserver.ows.DisabledServiceCheck.serviceDispatched(DisabledServiceCheck.java:53)
  ... 52 more
2010-04-14 10:59:06,277 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Could not find layer topp:states
  at
org.geoserver.wms.kvp.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1099)
  at
org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:179)
  at
org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:71)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1114)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:457)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:226)
  at
  at
  at
  at
  at
  at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:864)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:533)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:207)
  at
  at
2010-04-14 11:00:56,433 INFO [geowebcache.GeoWebCacheDispatcher] -
GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2010-04-14 11:00:56,439 INFO [storage.StorageBroker] - Destroying
StorageBroker
2010-04-14 11:00:56,440 WARN [jdbc.JDBCMBWrapper] - SHUTDOWN call to JDBC
resulted in: La base de datos ya esta cerrada (para des-habilitar el cerrado
automatico durante el shutdown de la VM, agregue ";DB_CLOSE_ON_EXIT=FALSE" a
la URL de conexión)
Database is already closed (to disable automatic closing at VM shutdown, add
";DB_CLOSE_ON_EXIT=FALSE" to the db URL) [90121-104]
2010-04-14 11:00:58,598 INFO [geoserver.catalog] - Disposing datastore
'DataStoreInfoImpl-71ad414c:127fb86fd45:-7fe6'
2010-04-14 11:00:58,599 INFO [geoserver.catalog] - Disposing grid coverage
reader 'BlueMarble_world'
Any idea how to fix this? Thanks.
Obrad
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-503-Again-tp5269025.html
