Hello!
I’m trying to add an ImageMosaicJDBC data store to my Geoserver 2.8.0 instance, but am receiving this error:
Error: could not list layers for this store, an error occurred retrieving them: Failed to create reader from …. and hints null.
I’ve spent some time searching for solutions, but thus far have been stumped. A little background about the process:
-Followed this link as tutorial/Mastering Geoserver book:
http://docs.geotools.org/latest/userguide/library/coverage/pgraster.html
-local Geoserver version (2.8.0) matches ImageMosaicJDBC Plugin version (gt-imagemosaic-jdbc-14.0), which is the 2.8.0 extension jar
-able to create ImagePyramid in local data directory using same dataset, able to preview layer created from ImagePyramid
Dataset:
3 inch imagery from USGS covering small section of Maryland
Preprocessing:
-ImagePyramid processed using gdal_retile
-ImageMosaicJDBC imported to Postgres using raster2pgsql
-populated public schema with md_3inch, o_2_md_3inch, o_4_md_3inch, o_8_md_3inch, o_16_md_3inch
Metadata table:
CREATE TABLE watersuite_raster_metadata ( coverage_name character varying(254) NOT NULL, tiletable character varying(254) NOT NULL, minx double precision, miny double precision, maxx double precision, maxy double precision, resx double precision, resy double precision, CONSTRAINT watersuite_raster_metadata_pkey PRIMARY KEY (coverage_name, tiletable)
-Metadata table populated with record for each table.
XML Configuration files:
connect.pgraster.xml.inc
mapping.pgraster.xml.inc
md3inch.pgraster.xml
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <!DOCTYPE ImageMosaicJDBCConfig [ ]> &mapping; &connect;Any help would be greatly appreciated!
Ty Swavely
GIS Analyst
Corona Environmental Consulting
