[Geoserver-users] Error adding raster jpg's mosaic
hi,
I 'am using Geoserver 1.5.0-RC 1 and i try to add raster mosaic data source (composed of 134 jpg files)
I manage to add the coveragestore i used FWTOOLS to create my “.properties” my “.shp” and i also create the “.proj”
but when i try to add a coverage using the new coveragestore i have the following error.
GeoServer - Exception
The following exception was thrown:
*org.vfny.geoserver.global.ConfigurationException: Could not obtain a reader for the CoverageDataSet. Please check the CoverageDataSet configuration!*
any suggestion would be wellcome.
David
Ce message ou ses pieces jointes peuvent contenir des informations confidentielles a l'intention exclusive de son destinataire et est couvert par le secret professionnel.
Toute utilisation, divulgation ou reproduction de son contenu sont strictement interdits. Si vous avez recu ce message par erreur, merci de le notifier a son expediteur et d'en detruire toute copie.
Le present message pouvant-etre altere a notre insu, le groupe ARES ne peut pas etre engage par son contenu. www.ares.fr
DAUDAIRE@anonymised.com ha scritto:
hi,
I manage to add the coveragestore i used FWTOOLS to create my ".properties" my ".shp" and i also create the ".proj"
That may be a million things. Which file did you try to add as the mosaic URL in the configuration?
Can you provide us with the .properties content?
Anyways, the error message is very generic... Alessio, given that the user already specified the format, is there any way to get a better
error message, coming from the mosaic format, explaining why data was
not accepted as a proper mosaic?
Andrea you are right, I will spend some time to try to give those error messages a nicer aspect … about the problem, I think that the CoverageStore points to a wrong URL.
I any case, for the mosaic, you need to point to the .shp file, no the .properties.
hi,
following error.
Anyways, the error message is very generic… Alessio, given that the
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
i have 134 “.jpg” files with their “.jpgw” L_11ur.jpg and L_11UR.JPGW for example
i copied all the files in
[geoserver_install]/data/coverages/paris_plu_mosaic/
i configure the coverage store
namespace: TOPP
Type: ImageMosaic
URL: file:data/coverages/paris_plu_mosaic/test.shp
Here is my .properties
Name=test
Levels=0.254,0.254
LevelsNum=1
Envelope2D=593499.873000,123800.065000 606499.871000,133550.127000
NumFiles=134
Here is my .proj
GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“4326”]]
the test.shp seem’s ok
if you have any ideas for a deeper investigation…
Thank you
David Audaire
Andrea Aime aaime@anonymised.com
Envoyé par : geoserver-users-bounces@lists.sourceforge.net
01/03/2007 11:09
A
cc
Alessio Fabiani <alessio.fabiani@…84…>, geoserver-users@lists.sourceforge.net
Objet
Re: [Geoserver-users] Error adding raster jpg’s mosaic
> hi,
> following error.
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-users mailing list
2 problems:
1- URL: file:coverages/paris_plu_mosaic/test.shp
2- the CRS file should be named .prj not .proj
On 3/1/07, DAUDAIRE@anonymised.com <DAUDAIRE@anonymised.com> wrote:
namespace: TOPP
Type: ImageMosaic
Name=test
Levels=0.254,0.254
LevelsNum=1
NumFiles=134
Here is my .proj
GEOGCS[“WGS 84”,
Thank you
David Audaire
Envoyé par : geoserver-users-bounces@anonymised.com.sourceforge.net
01/03/2007 11:09
A
cc
Alessio Fabiani <alessio.fabiani@anonymised.com>, geoserver-users@anonymised.comsts.sourceforge.net
Objet
hi,
following error.
------------------------------------------------------------------------- Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net’s Techsay panel and you’ll get the chance to share your opinions on IT & business topics through brief surveys-and earn cash http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV _______________________________________________ Geoserver-users mailing list Geoserver-users@anonymised.comsts.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users`
[www.ares.fr](http://www.ares.fr)
Alessio Fabiani ha scritto:
2 problems:
Curious... mosaic will fall back on world image to read
the tiles. Is jpgw a supported extension for world files?
Shoulnd't it be .wld?
Donìt know exactly … it depends on the plugin reader. There are several checks for different file extensions.
However, if it’s not supported we can add the support easily and quickly.
2 problems:
Curious… mosaic will fall back on world image to read
Shoulnd’t it be .wld?
Back in Arc/Info Unix times world file extension were named by adding "w" after image file extension. So originally extensions were like .tifw (or tiffw), .jpgw etc. For three character DOS-extensions the second letter was dropped, therefore they came .tfw, .jgw etc. So in principal those extensions named according to image file should be used, but in reality this varies. Some software accept .tfw for all image types. In gdal packege some of the ESRI style extensions are accepted and in addition .wld can be used for any image format. I don't know how it is in Geoserver, but even .jpgw is a valid Arc/Info extension, it is not supported by many other software.
-Jukka Rahkonen-
Lähettäjä: geoserver-users-bounces@lists.sourceforge.net puolesta: Andrea Aime
Lähetetty: to 1.3.2007 12:44
Vastaanottaja: Alessio Fabiani
Kopio: DAUDAIRE@anonymised.com; geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Error adding raster jpg's mosaic
2 problems:
Ciao,
as Alessio pointed out, I think that the problem with your mosaic is the .proj file which is not recognized since the plugin is expecting a .prj file. Moreover you need to make geoser5ver pointing to the .shp file in order to load correctly.
You said you used fwtools for this preparing the mosaic. I would suggest in the future to use the coveragetools that alessio and andrea bundled together.
To clarify for the other people that asked questions:
jpgw is not supported as a world file exension by the WorldImage plugin but it would be quite easy to fix that. Could anyone open up a jira task for this and assign it tome?
The mosaic plugin does not fall back on WorldImage when it fails to read a tile. If it fails it fails!
Eng. Simone Giannecchini
President/CEO GeoSolutions
Via Carignoni 51
550141 Camaiore (LU)
Mobile: +39 333 81 28928
----- Original Message ----- From: DAUDAIRE@anonymised.com
To: Andrea Aime ; geoserver-users@lists.sourceforge.net
Sent: Thursday, March 01, 2007 11:41 AM
Subject: Re: [Geoserver-users] Error adding raster jpg's mosaic
i have 134 ".jpg" files with their ".jpgw" L_11ur.jpg and L_11UR.JPGW for example
namespace: TOPP
Type: ImageMosaic
Name=test
Levels=0.254,0.254
LevelsNum=1
NumFiles=134
Here is my .proj
GEOGCS["WGS 84",
  DATUM["World Geodetic System 1984",
    SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
    AUTHORITY["EPSG","6326"]],
  PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
  UNIT["degree", 0.017453292519943295],
  AXIS["Geodetic longitude", EAST],
  AXIS["Geodetic latitude", NORTH],
  AUTHORITY["EPSG","4326"]]
the test.shp seem's ok
if you have any ideas for a deeper investigation..
Thank you
David Audaire
01/03/2007 11:09 ADAUDAIRE@anonymised.com
ccAlessio Fabiani <alessio.fabiani@anonymised.com>, geoserver-users@lists.sourceforge.net
ObjetRe: [Geoserver-users] Error adding raster jpg's mosaic
hi,
following error.
****************************************************************************************************-------------------------------------------------------------------------Take Surveys. Earn Cash. Influence the Future of ITJoin SourceForge.net's Techsay panel and you'll get the chance to share youropinions on IT & business topics through brief surveys-and earn cashhttp://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV_______________________________________________Geoserver-users mailing listGeoserver-users@anonymised.com://lists.sourceforge.net/lists/listinfo/geoserver-users
>jpgw is not supported as a world file exension by the WorldImage plugin...
On a similar note, .jgw extension is supported I think...
Alex
Ciao Alex,
I confirm that :-).
Simone.
Via Carignoni 51
----- Original Message ----- From: "Alexander Petkov" <greenkov@anonymised.com>
To: "Simone" <simboss1@anonymised.com>
Cc: "Andrea Aime" <aaime@anonymised.com>; <geoserver-users@lists.sourceforge.net>; <DAUDAIRE@anonymised.com>
Sent: Thursday, March 01, 2007 1:55 PM
>jpgw is not supported as a world file exension by the WorldImage >plugin...
Alex
Thank you for the answers, in fact i 'am back to Geoserver after a while and it seems i have missed discussions about data_dir.
My file is .prj as needed but i have to change the data directory to my test.shp and i have no more error msg.
i add the coverage in geoserver, and i can see the name in the map preview list.
I am not able yet to see my rasters but i think i am on the good way.
thank you.
“Simone” simboss1@anonymised.com
01/03/2007 12:19
A
“Andrea Aime” <aaime@anonymised.com.1…>, geoserver-users@lists.sourceforge.net, DAUDAIRE@anonymised.com
cc
Objet
Ciao,
together.
Via Carignoni 51
example
namespace: TOPP
Type: ImageMosaic
Name=test
Levels=0.254,0.254
LevelsNum=1
NumFiles=134
Here is my .proj
GEOGCS["WGS 84",
Thank you
David Audaire
> hi,
> following error.
Ciao,
what error are you getting now?
Simone.
Via Carignoni 51
To: Simone
Cc: Andrea Aime ; geoserver-users@anonymised.comts.sourceforge.net
Sent: Thursday, March 01, 2007 2:44 PM
Subject: Re: [Geoserver-users] Error adding raster jpg’s mosaic
thank you.
“Simone” <simboss1@anonymised.com>
01/03/2007 12:19
A
“Andrea Aime” <aaime@anonymised.com>, <geoserver-users@lists.sourceforge.net>, DAUDAIRE@anonymised.com
cc
Objet
Ciao,
together.
Via Carignoni 51
example
namespace: TOPP
Type: ImageMosaic
Name=test
Levels=0.254,0.254
LevelsNum=1
NumFiles=134
Here is my .proj
GEOGCS["WGS 84",
Thank you
David Audaire
> hi,
> following error.
Well i got no response the server is going really slow and i must restart tomcat.
no error message
in tomcat catalina logs it seems that i need to increase memory. the french message is something like not enough memory for the tiling cache capacity.
David Audaire
Ingénieur d’étude
Systèmes d’Informations Techniques
Branche Solutions Progiciels
tel : 33.(0).1.69.86.76.72
fax : 33.(0).1.69.86.76.69
web : http://www.ares.fr
01/03/2007 14:46
A
cc
Objet
Ciao,
Simone.
Via Carignoni 51
To: Simone
Cc: Andrea Aime ; geoserver-users@anonymised.comsts.sourceforge.net
thank you.
01/03/2007 12:19
A
“Andrea Aime” <aaime@anonymised.com>, <geoserver-users@anonymised.comge.net>, DAUDAIRE@anonymised.com
cc
Objet
Ciao,
together.
Via Carignoni 51
example
namespace: TOPP
Type: ImageMosaic
Name=test
Levels=0.254,0.254
LevelsNum=1
NumFiles=134
Here is my .proj
GEOGCS["WGS 84",
Thank you
David Audaire
> hi,
> following error.
Ciao David,
a coupe of observations.
Jpeg support through java is pretty bad for big images, at least as of now. If you have a large mosaic of images encoded as jpeg it will require a lot of memory to actually load it, especially when you are loading it at low resolution. When you zoom a lot things should be quite good.
My suggestion is to use geotiff files instead of jpegs so that you can add overviews to them prior to making a mossaic. You can still compress them using various algorithms but they have better feaftures like internal overviews and tiling which make them more attractive for serving large mosaics.
Simone.
Via Carignoni 51
To: Simone
Cc: geoserver-users@anonymised.comts.sourceforge.net ; geoserver-users-bounces@lists.sourceforge.net
Sent: Thursday, March 01, 2007 3:19 PM
no error message
David Audaire
Ingénieur d’étude
01/03/2007 14:46
A
cc
Objet
Ciao,
Simone.
Via Carignoni 51
To: Simone
Cc: Andrea Aime ; geoserver-users@lists.sourceforge.net
thank you.
01/03/2007 12:19
A
cc
Objet
Ciao,
together.
Via Carignoni 51
example
namespace: TOPP
Type: ImageMosaic
Name=test
Levels=0.254,0.254
LevelsNum=1
NumFiles=134
Here is my .proj
GEOGCS["WGS 84",
Thank you
David Audaire
> hi,
> following error.
hi,
I have tried a getmap on my jpeg mosaic on a small area, i found an error in catalina logs. and geoserver return a white page
javax.imagio.IIOException: Improper call to JPEG Library in state 202
besides i can’t do nothing in the server admin page when i commit i have a memory error about JAI footprint in Memory
I Have tried things like java -Xmx512m but nothing changes.
any ideas.
David Audaire
Ingénieur d’étude
hi,
*javax.imagio.IIOException: Improper call to JPEG Library in state 202*
besides i can't do nothing in the server admin page when i commit i have a memory error about JAI footprint in Memory
any ideas.
Unfortunately I don't really know how to solve this issue directly.
To solve these, we would really need the original data, if you could
provide it to us by some private means (ftp for example) that would
be indeed great.
Yet, if you want a workaround, try this:
* download gdal (www.gdal.org)
* usa gdal_merge to merge all your jpegs into a big tiled Geotiff (see
the creation options to force tiling)
* use gdaladdo to add overviews
* add to geoserver and enjoy.
This should work well, at least if the resulting Geotiff is under
1GB in size.
If it becomes bigger, once you have turned all your jpeg data into
a single geotiff, you can use the Coverage tools to create an image pyramid out of it, this should give you top notch performance:
http://www.geo-solutions.it/index.php?option=com_content&task=view&id=35&Itemid=2
Hope this helps
I am not the owner of the data so i have no right to share them anyway.
Whatever i 'll stop my tests with jpeg, i 'll try to use raster with Geotiff.
thank’s
David Audaire
HI
hi
I changed my “jpeg” images using gdal_merge with parameters below ( in a batch file as seen on the web to process all the files).
setlocal enabledelayedexpansion
set infiles=
for %%a in (.*.JPG) do set infiles=!infiles! %%a
gdal_merge -o paris_plu.tif -co “TILED=YES” -v -of GTiff %infiles%
the jgw files are close to the JPG.
i go on with gdaladdo.
Then i try to add the geotiff in geoserver no problem with the Coveragestore but when i want to add the data as new coverage using my new coveragestore…
__*java.lang.UnsupportedOperationException: GeoKey directory does not exist*__
do you have any suggestion.
thank you
David Audaire
Ingénieur d’étude
well
I must precise that i have no “.prj” file but a “.aux” maybe the tools can’t read those file to extract coordonate system.
is there a way to extract data from “.aux” file ??
David Audaire
Ingénieur d’étude
15/03/2007 14:20
A
geoserver-users@anonymised.come.net, geoserver-users-bounces@lists.sourceforge.net
cc
Objet
HI
hi
set infiles=
thank you
David Audaire
Ingénieur d’étude
