[Geoserver-users] error building ND Geoserver
I downloaded a version of Geoserver from
https://svn.codehaus.org/geoserver/branches/1.6.x-Cov-nD/geoserver/ but I am
getting an error building it:
Missing:
1) org.geotools:gt2-grib1:jar:2.4-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geotools -DartifactId=gt2-grib1
-Dv
ersion=2.4-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file
there:
      mvn deploy:deploy-file -DgroupId=org.geotools -DartifactId=gt2-grib1
-Dver
sion=2.4-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url]
-DrepositoryI
d=[id]
  Path to dependency:
        1) org.geoserver:main:jar:1.6-beta4
        2) org.geotools:gt2-grib1:jar:2.4-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  ibiblio (http://www.ibiblio.org/maven2),
  refractions (http://lists.refractions.net/m2/),
  Sateh (http://maven.sateh.com/repository),
  mortbay (http://www.mortbay.org/maven2/release),
  geotools (http://maven.geotools.fr/repository/)
I have tried looking for this jar file from the repositories but haven't
found one yet.
Adit
Mr. Adityarajsingh Santokhee Tel: +44 118 378 5126 (direct line)
Data Manager Tel: +44 118 378 8741 (ESSC)
Reading e-Science Centre Fax: +44 118 378 6413
ESSC Email: ads@anonymised.com
University of Reading
3 Earley Gate
Reading RG6 6AL, UK
Adit Santokhee ha scritto:
I downloaded a version of Geoserver from https://svn.codehaus.org/geoserver/branches/1.6.x-Cov-nD/geoserver/ but I am getting an error building it:
Hum, strange? It's included in the gt2 2.4.x_rs branch under modules/plugins, it should have been built when you worked on that
branch?
Hi Adit, hi all,
GeoServer-ND actually needs GeoTools 2.4.x-rs.
We are looking right now to change the version on the poms of both GeoTools 2.4.x-rs and GeoServer 1.6.x-nd in order to avoid ambiguity among the various library versions, and also we are fixing dependencies by creating a maven-repo containing the latest ImageIO-ND plugins needed to compile the projects.
I’ll send an alert as soon as the projects will be updated.
Alessio.
On Jan 31, 2008 3:33 PM, Adit Santokhee <ads@anonymised.com> wrote:
Missing:
  1. org.geotools:gt2-grib1:jar:2.4-SNAPSHOT
mvn install:install-file -DgroupId=org.geotools -DartifactId=gt2-grib1 -Dv
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.geotools -DartifactId=gt2-grib1 -Dver
sion=2.4-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryI
d=[id]
Path to dependency:
  1. org.geoserver:main:jar:1.6-beta4
  2. org.geotools:gt2-grib1:jar:2.4-SNAPSHOT
for artifact:
I have tried looking for this jar file from the repositories but haven’t found one yet.
Adit
3 Earley Gate
Reading RG6 6AL, UK
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-devel mailing list
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 349 8227000
Changes committed.
In order to compile geoserver-1.6.x-nd (https://svn.codehaus.org/geoserver/branches/1.6.x-Cov-nD) you first have to compile geotools-2.4.x-rs (http://svn.geotools.org/geotools/branches/2.4.x_rs).
On Jan 31, 2008 3:39 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hi Adit, hi all,
Alessio.
Missing:
d=[id]
Path to dependency:
for artifact:
Adit
3 Earley Gate
Reading RG6 6AL, UK
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hello Alessio,
I downloaded geotools-2.4.x-rs but there are a few problems compiling it:
[INFO] snapshot org.geotools.maven:gt2-jjtree-javacc:2.4-RS-SNAPSHOT:
checking f
or updates from codehaus-snapshot-plugins
checking f
or updates from refractions
Downloading:
http://snapshots.repository.codehaus.org//org/geotools/maven/gt2-jjtree-java
cc/2.4-RS-SNAPSHOT/gt2-jjtree-javacc-2.4-RS-SNAPSHOT.jar
Downloading:
http://lists.refractions.net/m2/org/geotools/maven/gt2-jjtree-javacc/2.4-RS-
[INFO]
[ERROR] BUILD FAILURE
[INFO]
[INFO] A required plugin was not found: Plugin could not be found - check
that t
he goal name is correct: Unable to download the artifact from any repository
I checked the repositories and the jar files, 2.4-RS-SNAPSHOT extensions,
aren't there yet. Can I use the 2.4-SNAPSHOT ones?
Adit
  _____
From: Alessio Fabiani [mailto:alessio.fabiani@anonymised.com]
Sent: 31 January 2008 17:00
To: Adit Santokhee
Cc: Geoserver-devel; geoserver users
Subject: Re: [Geoserver-devel] error building ND Geoserver
Changes committed.
Hi Adit, hi all,
projects.
I'll send an alert as soon as the projects will be updated.
           Alessio.
Missing:
-Dv
there:
-Dver
-DrepositoryI
d=[id]
  Path to dependency:
for artifact:
found one yet.
Adit
3 Earley Gate
Reading RG6 6AL, UK
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Adit,
I guess that you can solve this problem by simply compile the gt_2.4.x-rs\build\maven alone first … despite that is quite strange since it should be compiled automatically. I’ll check this issue.
However if you continue getting this error, you can also use the 2.4.x-SNAPSHOT plugin.
On Feb 1, 2008 11:51 AM, Adit Santokhee <ads@anonymised.com> wrote:
Hello Alessio,
[INFO] snapshot org.geotools.maven:gt2-jjtree-javacc:2.4-RS-SNAPSHOT: checking f
Downloading: http://snapshots.repository.codehaus.org//org/geotools/maven/gt2-jjtree-javacc/2.4-RS-SNAPSHOT/gt2-jjtree-javacc-2.4-RS-SNAPSHOT.jar
Downloading: http://lists.refractions.net/m2/org/geotools/maven/gt2-jjtree-javacc/2.4-RS-SNAPSHOT/gt2-jjtree-javacc-2.4-RS-SNAPSHOT.jar
[INFO] A required plugin was not found: Plugin could not be found - check that t
I checked the repositories and the jar files, 2.4-RS-SNAPSHOT extensions, aren’t there yet. Can I use the 2.4-SNAPSHOT ones?
Adit
To: Adit Santokhee
Changes committed.
Hi Adit, hi all,
Alessio.
Missing:
d=[id]
Path to dependency:
for artifact:
Adit
3 Earley Gate
Reading RG6 6AL, UK
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
