[Geoserver-users] Error building trunk
I got an error trying to build the trunk
main\src\main\java\org\geoserver\catalog\impl\ModificationProxy.java:[221,51]
incompatible types found java.util.List<java.lang.Class<?>> required java.util.List<java.lang.Class>
changed line 221 in
ModificationProxy class to: List<Class<?>> proxyInterfaces = Arrays.asList( proxyObject.getClass().getInterfaces() );
and it works again.
hope this is valuable info to anyone :wink:
Cheers Kris
Kris Geusebroek
Consultant
cid:image001.jpg@anonymised.com
Email: kgeusebroek@anonymised.com
Tel: +31 (0)35 538 1921
Fax: +31 (0)35 538 1922
Mobile: +31 (0)6 30 697 223
http://www.xebia.com
Utrechtseweg 49
1213 TL Hilversum
The Netherlands
Xebia Blog ! http://blog.xebia.com/
Xebia Podcast! http://podcast.xebia.com/
changed line 221 in
and it works again.
Interesting error... are you trying to build with Java 6?
GeoServer is meant to be buildable only with java 5 (to ensure it
actually can run there), thought we had talks about setting
up an automated daily build to check it builds with java 6 also.
Andrea Aime
OpenGeo - http://opengeo.org
Hi Andrea,
I'm building with java 1.6.0_11 yes.
After fixing it did run successfully (although I saw some exceptions in
tests)
Cheers Kris
-----Original Message-----
Sent: Tuesday, March 10, 2009 8:45 AM
To: Kris Geusebroek
Subject: Re: [Geoserver-users] Error building trunk
1,51]
changed line 221 in
and it works again.
Andrea Aime
Should not be hard to get the build to compile in java 6. I will throw that on my todo list for today.
-Justin
Kris Geusebroek wrote:
Hi Andrea,
tests)
Cheers Kris
From: Andrea Aime [mailto:aaime@anonymised.com] Sent: Tuesday, March 10, 2009 8:45 AM
To: Kris Geusebroek
1,51]
changed line 221 in
and it works again.
Justin Deoliveira
