Geoserver 2.8.1
I am migrating data from Geoserver 2.2.5 to Geoserver 2.8.1. There is some modification done to the layergroups, datastore, and featuretype xml files to make the compliant with 2.8.1. After the data is migrated into 2.8.1, I can boot up geoserver and login to the web gui. I have one layer group, and when I click on it, the page fails to load and I am presented with the stack trace below. All the necessary styles are present in the styles directory, however. Can anyone help me figure out why the current styles of layer are not available?
org.apache.wicket.WicketRuntimeException: Error calling method: public java.util.Set org.geoserver.gwc.layer.StyleParameterFilter.getLayerStyles() on object: StyleParameterFilter[allowedStyles=,availableStyles=,defaultStyle=,key=STYLES,defaultValue=] at org.apache.wicket.util.lang.PropertyResolver$MethodGetAndSet.getValue(PropertyResolver.java:1075) at org.apache.wicket.util.lang.PropertyResolver$ObjectAndGetSetter.getValue(PropertyResolver.java:596) at org.apache.wicket.util.lang.PropertyResolver.getValue(PropertyResolver.java:95) at org.apache.wicket.model.AbstractPropertyModel.getObject(AbstractPropertyModel.java:117) at org.geoserver.gwc.web.layer.StyleParameterFilterSubform$SetAsListModel.(StyleParameterFilterSubform.java:47) at org.geoserver.gwc.web.layer.StyleParameterFilterSubform.(StyleParameterFilterSubform.java:203) at org.geoserver.gwc.web.layer.ParameterFilterEditor.getSubform(ParameterFilterEditor.java:343) at org.geoserver.gwc.web.layer.ParameterFilterEditor.access$000(ParameterFilterEditor.java:59) at org.geoserver.gwc.web.layer.ParameterFilterEditor$1.populateItem(ParameterFilterEditor.java:187) at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:562) at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:131) at org.geoserver.gwc.web.layer.ParameterFilterEditor$1.onBeforeRender(ParameterFilterEditor.java:173) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.markup.html.form.Form.onBeforeRender(Form.java:2056) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.geoserver.gwc.web.layer.ParameterFilterEditor.onBeforeRender(ParameterFilterEditor.java:393) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.geoserver.gwc.web.layer.GeoServerTileLayerEditor.onBeforeRender(GeoServerTileLayerEditor.java:561) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:151) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.markup.html.form.Form.onBeforeRender(Form.java:2056) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753) at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at org.apache.wicket.Page.onBeforeRender(Page.java:1531) at org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at org.apache.wicket.Component.beforeRender(Component.java:1105) at org.apache.wicket.Component.prepareForRender(Component.java:2292) at org.apache.wicket.Page.prepareForRender(Page.java:1521) at org.apache.wicket.Component.prepareForRender(Component.java:2329) at org.apache.wicket.Page.renderPage(Page.java:892) at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:261) at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105) at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258) at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484) at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093) at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75) at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71) at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87) at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323) at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173) at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:209) at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:244) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405) at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206) at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114) at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152) at org.mortbay.jetty.Server.handle(Server.java:324) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505) at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828) at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380) at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395) at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450) Caused by: java.lang.IllegalStateException: Current styles of layer not available. at com.google.common.base.Preconditions.checkState(Preconditions.java:176) at org.geoserver.gwc.layer.StyleParameterFilter.checkInitialized(StyleParameterFilter.java:59) at org.geoserver.gwc.layer.StyleParameterFilter.getLayerStyles(StyleParameterFilter.java:152) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at org.apache.wicket.util.lang.PropertyResolver$MethodGetAndSet.getValue(PropertyResolver.java:1071) … 167 more
Michael Neynens
