Hi, I'm trying to install geoserver (I started with 2.4.3, but also tested
2.4.0 and 2.2.4) with apache tomcat 8 on Ubuntu 12.04.
Tomcat is working fine, and can run example servlets, Geoserver is deployed
from the .war file, but will not start, giving generic error message "FAIL -
Application at context path /geoserver could not be started".
Checking the logs shows:
`ERROR [context.ContextLoader] - context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'geoServerLoader' defined in URL
[jar:file:/home/XXX/tomcat/webapps/geoserver/WEB-INF/lib/main-2.2.4.jar!/applicationContext.xml]:
Cannot resolve reference to bean 'resourceLoader' while setting constructor
argument; nested exception is
with name 'resourceLoader' defined in URL
initialization of bean failed; nested exception is
java.lang.IllegalArgumentException: The resource path [WEB-INF] is not
valid.`
I haven't modified geoserver or tomcat in any way.
I tried looking through tomcat/webapps/geoserver/WEB-INF/lib/main-2.2.4.jar
for either geoServerLoader or resourceLoader, but could find neither?
WEB-INF definitely exists, and has appropriate permissions.
Any help would be greatly appreciated.
Chengarda.
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-context-ContextLoader-Error-creating-geoServerLoader-tp5097884.html
