[Geoserver-users] Error: Could not load the propery file 'output_xml.properties' for output method 'xml' (check CLASSPATH)
Hello all
I've inherited a CentOS box, and am trying to get Geoserver running under
Tomcat. I'm not a very competent Linux user. I have installed Java, Tomcat,
and Geoserver. When I try to add a new user, I get the following:
An error occurred while saving the user:
com.sun.org.apache.xml.internal.serializer.utils.WrappedRuntimeException:
How can I fix this? I have found the following information:
https://xalan.apache.org/xalan-j/faq.html#faq-10
Other search results point to the same information. It says:
"Place the xalan.jar, serializer.jar, xercesImpl.jar and xml-apis.jar in the
<java-home>\lib\endorsed directory"
However, I have no endorsed directory.
Can anyone help?
Thanks
Tom
Geoserver 2.9.0
Tomcat 8.0.35
Java 1.8.0_71-b15
CentOS 6.8
Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-Could-not-load-the-propery-file-output-xml-properties-for-output-method-xml-check-CLASSPATH-tp5281162.html
Upgrading to 2.9.1 and rebooting fixed this issue. Don't know if the reboot
alone would have sorted it.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-Could-not-load-the-propery-file-output-xml-properties-for-output-method-xml-check-CLASSPATH-tp5281162p5281210.html
