[Geoserver-users] Error creating COG Mosaic via REST API
Hello,
I’m trying to create a COG ImageMosaic on Geoserver, following the instruction described at:
https://docs.geoserver.org/main/en/user/community/cog/mosaic.html
I succeeded with step 1 (create an empty store) via rest API
curl -u : -XPUT --write-out %{http_code} -H “Content-type:application/zip” --data-binary @modis.zip http://localhost:8080/geoserver/rest/workspaces/cite/coveragestores/modis/file.imagemosaic?configure=none
(201)
But when I try to add a granule to the store, I have the following error:
curl -u : -XPOST -H “Content-type: text/plain” --write-out %{http_code} -d https://modis-vi-nasa.s3-us-west-2.amazonaws.com/MOD13A1.006/2018.01.01.tif http://localhost:8080/geoserver/rest/workspaces/cite/coveragestores/modis/remote.imagemosaic
java.io.IOException: Failed to create reader from file:data/dea/modis and hints Hints:
REPOSITORY = org.geoserver.catalog.CatalogRepository@anonymised.com
EXECUTOR_SERVICE = [java.util.concurrent.ThreadPoolExecutor@anonymised.comRunning, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0]
System defaults:
FORCE_AXIS_ORDER_HONORING = http
STYLE_FACTORY = StyleFactoryImpl
FEATURE_FACTORY = org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com
FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
LENIENT_DATUM_SHIFT = true
GRID_COVERAGE_FACTORY = GridCoverageFactory
TILE_ENCODING = null
FILTER_FACTORY = FilterFactoryImpl
COMPARISON_TOLERANCE = 1.0E-8
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1571)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1514)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:57)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144)
at com.sun.proxy.$Proxy46.getGridCoverageReader(Unknown Source)
at org.geoserver.rest.catalog.CoverageStoreFileController.coverageStorePost(CoverageStoreFileController.java:98)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:190)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:138)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:105)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:878)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:792)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1043)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:909)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:696)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:779)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:227)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:162)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:189)
at org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:357)
at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:176)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:73)
at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:194)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:43)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:215)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:54)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:687)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:360)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:399)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:893)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1789)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:829)
I installed Geoserver with docker, using the image docker.osgeo.org/geoserver:2.21.4
Here are my installation options (plugin for COG support is installed, too):
docker run -d --mount type=bind,src=/data/geoserver/data=/opt/geoserver_data/data --mount type=bind,src=/data/geoserver /geo_plugins/lib,target=/opt/apache-tomcat-9.0.68/webapps/geoserver/WEB-INF/lib -it -p 8080:8080 --env CORS_ENABLED=true --env INSTALL_EXTENSIONS=true --env STABLE_EXTENSIONS=“css,db2,gdal,grib,netcdf-out,netcdf,pyramid,wmts-multi-dimensional,xslt,jp2k” --env EXTRA_JAVA_OPTS=‘-Xms1g -Xmx16g -Duser.timezone=GMT -Dorg.geotools.shapefile.datetime=true’ docker.osgeo.org/geoserver:2.21.4
Any help will be appreciated.
Cristina Arcari
I think your mime type is wrong, should it not be an image of some type, I forget what COGs use.
Ian
On Tue, 24 Oct 2023, 17:29 , <cristinaarcari@anonymised.com> wrote:
Hello,
(201)
System defaults:
Cristina Arcari
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
But it is a zip file that is uploaded and application/zip is used in the manual so I guess that at least it has worked when the manual was written https://docs.geoserver.org/main/en/user/community/cog/mosaic.html
COGs are TIFFs with some extra features and this is how the mime type is defined in the OGC standard:
When required, a COG file should use the MIME type image/tiff with the application parameter value geotiff and the profile parameters value cloud-optimized, therefore as follows:
image/tiff; application=geotiff; profile=cloud-optimized
-Jukka Rahkonen-
Lähettäjä: Ian Turton <ijturton@anonymised.com4…>
Lähetetty: keskiviikko 25. lokakuuta 2023 10.47
Vastaanottaja: cristinaarcari@anonymised.com
Kopio: geoserver-users geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Error creating COG Mosaic via REST API
Ian
Hello,
(201)
System defaults:
Cristina Arcari
In the message Cristina posted they used ‘-H “Content-type: text/plain”’ which will confuse GeoServer for sure
Ian
Ian Turton
Thank you everybody.
I tried both the following:
But nothing changed, the error is the same.
Please note that I have no error uploading a file using method “external”. It seems an issue related to method “remote”. Is the file URL correct?
Cristina
Sent: Wednesday, October 25, 2023 10:40 AM
To: Rahkonen Jukka jukka.rahkonen@anonymised.com
Cc: cristinaarcari@anonymised.com; geoserver-users geoserver-users@anonymised.comt
Subject: Re: [Geoserver-users] Error creating COG Mosaic via REST API
Ian
On Wed, 25 Oct 2023 at 09:33, Rahkonen Jukka <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Lähettäjä: Ian Turton <ijturton@anonymised.com>
Kopio: geoserver-users <geoserver-users@lists.sourceforge.net>
Ian
Hello,
(201)
System defaults:
Cristina Arcari
Geoserver-users@anonymised.come.net
Ian Turton
