[Geoserver-users] Error creating ImageMosaic coverage store
mosaicint.zip
​I am trying to create an ImageMosaic coverage store which includes
with time dimension, but I am getting the following error:
“Could not list layers for this store, an error occurred retrieving
them: Failed to create reader from file:data/dev3/mosaicpng and hints
null”
I have tried using different raster formats (geotiffs and pngs) to try
to workaround the problem, but the error persists. Any idea?
The log shows the following error:
Caused by: java.io.IOException: Failed to create reader from
file:data/dev3/mosaicpng and hints null
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1443)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1369)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:59)
at sun.reflect.GeneratedMethodAccessor231.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
at com.sun.proxy.$Proxy8.getGridCoverageReader(Unknown Source)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:90)
… 115 more
I attach the contents of the data folder (they are just junk layers
created for testing purposes).
César
César Martínez Izquierdo
GIS developer
Blog: http://geotechnotes.wordpress.com/
ETC-SIA: http://sia.eionet.europa.eu/
Universitat Autònoma de Barcelona (SPAIN)
Hi Cesar,
only had a cursory look so far (could not test it), but if memory serves me right, this
kind of mosaic won’t load because GeoServer cannot read the georeferencing
in the XML files, and needs a .prj sidecar instead
On Sun, Dec 13, 2015 at 8:43 PM, César Martínez Izquierdo <cesar.izq@anonymised.com> wrote:
mosaicint.zip
null”
… 115 more
César
GIS developer
Geoserver-users mailing list
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea for the answer. Unfortunately, I have added the .prj files with no luck. I have also tried different file formats (png, geotiff) and pixel types (integer and float), and I’ve always got the same error.
Moreover, I haven’t been able to publish a mosaic that is correctly published on a different server (I mean, copying the same files to my test server and publishing them from Geoserver interface fails).
I am starting to think that there is some bug on the plugin, and that it may only arise under some environment circumstances. But it doesn’t seem to be related with Geoserver version, as both the successfully and the failing server are using 2.8.1 version (and I’ve got the same error on a 3rd test server using version 2.8.0).
Any idea?
mosaicintpng.zip
On 14 December 2015 at 08:56, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Cesar,
mosaicint.zip
null”
… 115 more
César
GIS developer
Ing. Andrea Aime
@geowolf
Technical Lead
GIS developer
