[Geoserver-users] Error deploying GeoServer 2.1.x on JBoss 5.1
Hello!
I followed this instruction:
http://ccancellieri.wordpress.com/2012/01/27/geoserver-on-jboss/
<http://ccancellieri.wordpress.com/2012/01/27/geoserver-on-jboss/&gt;
As expected, I have encountered the problem described here:
http://geo-solutions.blogspot.com.au/2009/07/deploying-geoserver-on-jboss-as-5x.html
<http://geo-solutions.blogspot.com.au/2009/07/deploying-geoserver-on-jboss-as-5x.html&gt;
However, when deploying the WAR file downloaded from the GeoServer. I bumped
into the errors below:
2013-01-04 12:14:24,210 INFO [org.jboss.web.WebService] (main) Using RMI
server codebase: http://optiplex2:8083/
2013-01-04 12:14:27,358 INFO [org.jboss.wsf.stack.jbws.NativeServerConfig]
(main) JBoss Web Services - Stack Native Core
(main) 3.1.2.GA
2013-01-04 12:14:27,769 INFO
[org.jboss.dependency.plugins.AttributeCallbackItem] (main) Owner callback
not implemented.
2013-01-04 12:14:28,504 INFO [org.jboss.logbridge.LogNotificationListener]
(main) Adding notification listener for logging mbean
"jboss.system:service=Logging,type=Log4jService" to server
org.jboss.mx.server.MBeanServerImpl@anonymised.com[ defaultDomain='jboss' ]
2013-01-04 12:14:40,088 INFO
[org.jboss.ejb3.deployers.Ejb3DependenciesDeployer] (main) Encountered
deployment
AbstractVFSDeploymentContext@anonymised.com{vfsfile:/opt/jboss/server/default/deploy/profileservice-secured.jar/}
2013-01-04 12:14:40,089 INFO
deployment
deployment
deployment
2013-01-04 12:14:40,927 INFO
[org.jboss.mx.remoting.service.JMXConnectorServerService] (main) JMX
Connector server:
service:jmx:rmi://optiplex2/jndi/rmi://optiplex2:1090/jmxconnector
2013-01-04 12:14:41,004 INFO [org.jboss.mail.MailService] (main) Mail
Service bound to java:/Mail
2013-01-04 12:14:42,690 WARN
[org.jboss.jms.server.jbosssx.JBossASSecurityMetadataStore] (main) WARNING!
POTENTIAL SECURITY RISK. It has been detected that the MessageSucker
component which sucks messages from one node to another has not had its
password changed from the installation default. Please see the JBoss
Messaging user guide for instructions on how to do this.
2013-01-04 12:14:42,703 WARN
[org.jboss.annotation.factory.AnnotationCreator] (main) No ClassLoader
provided, using TCCL: org.jboss.managed.api.annotation.ManagementComponent
2013-01-04 12:14:42,752 WARN
2013-01-04 12:14:42,785 INFO
[com.arjuna.ats.jbossatx.jta.TransactionManagerService] (main) JBossTS
Transaction Service (JTA version - tag:JBOSSTS_4_6_1_GA) - JBoss Inc.
2013-01-04 12:14:42,786 INFO
[com.arjuna.ats.jbossatx.jta.TransactionManagerService] (main) Setting up
property manager MBean and JMX layer
2013-01-04 12:14:42,949 INFO
[com.arjuna.ats.jbossatx.jta.TransactionManagerService] (main) Initializing
recovery manager
2013-01-04 12:14:43,020 INFO
[com.arjuna.ats.jbossatx.jta.TransactionManagerService] (main) Recovery
manager configured
2013-01-04 12:14:43,021 INFO
[com.arjuna.ats.jbossatx.jta.TransactionManagerService] (main) Binding
TransactionManager JNDI Reference
2013-01-04 12:14:43,039 INFO
[com.arjuna.ats.jbossatx.jta.TransactionManagerService] (main) Starting
transaction recovery manager
2013-01-04 12:14:43,281 INFO
[org.apache.catalina.core.AprLifecycleListener] (main) The Apache Tomcat
Native library which allows optimal performance in production environments
was not found on the java.library.path:
/usr/lib/jvm/java-6-openjdk-amd64/jre/lib/amd64/server:/usr/lib/jvm/java-6-openjdk-amd64/jre/lib/amd64:/usr/lib/jvm/java-6-openjdk-amd64/jre/../lib/amd64:/opt/gdal//lib/::/usr/java/packages/lib/amd64:/usr/lib/x86_64-linux-gnu/jni:/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/usr/lib/jni:/lib:/usr/lib
2013-01-04 12:14:43,320 INFO [org.apache.coyote.http11.Http11Protocol]
(main) Initializing Coyote HTTP/1.1 on http-0.0.0.0-8080
2013-01-04 12:14:43,321 INFO [org.apache.coyote.ajp.AjpProtocol] (main)
Initializing Coyote AJP/1.3 on ajp-0.0.0.0-8009
2013-01-04 12:14:43,335 INFO [org.apache.catalina.core.StandardService]
(main) Starting service jboss.web
2013-01-04 12:14:43,336 INFO [org.apache.catalina.core.StandardEngine]
(main) Starting Servlet Engine: JBoss Web/2.1.3.GA
2013-01-04 12:14:43,370 INFO [org.apache.catalina.startup.Catalina] (main)
Server startup in 49 ms
2013-01-04 12:14:43,383 INFO
[org.jboss.web.tomcat.service.deployers.TomcatDeployment] (main) deploy,
ctxPath=/jbossws
2013-01-04 12:14:43,687 INFO
ctxPath=/web-console
2013-01-04 12:14:44,489 INFO
ctxPath=/invoker
2013-01-04 12:14:44,559 INFO [org.jboss.resource.deployers.RARDeployment]
(main) Required license terms exist, view
vfszip:/opt/jboss/server/default/deploy/jboss-local-jdbc.rar/META-INF/ra.xml
2013-01-04 12:14:44,571 INFO [org.jboss.resource.deployers.RARDeployment]
vfszip:/opt/jboss/server/default/deploy/jboss-xa-jdbc.rar/META-INF/ra.xml
2013-01-04 12:14:44,588 INFO [org.jboss.resource.deployers.RARDeployment]
vfszip:/opt/jboss/server/default/deploy/jms-ra.rar/META-INF/ra.xml
2013-01-04 12:14:44,601 INFO [org.jboss.resource.deployers.RARDeployment]
vfszip:/opt/jboss/server/default/deploy/mail-ra.rar/META-INF/ra.xml
2013-01-04 12:14:44,614 INFO [org.jboss.resource.deployers.RARDeployment]
vfszip:/opt/jboss/server/default/deploy/quartz-ra.rar/META-INF/ra.xml
2013-01-04 12:14:44,662 INFO [org.quartz.simpl.SimpleThreadPool] (main) Job
execution threads will use class loader of thread: main
2013-01-04 12:14:44,678 INFO [org.quartz.core.QuartzScheduler] (main)
Quartz Scheduler v.1.5.2 created.
2013-01-04 12:14:44,680 INFO [org.quartz.simpl.RAMJobStore] (main)
RAMJobStore initialized.
2013-01-04 12:14:44,680 INFO [org.quartz.impl.StdSchedulerFactory] (main)
Quartz scheduler 'DefaultQuartzScheduler' initialized from default resource
file in Quartz package: 'quartz.properties'
Quartz scheduler version: 1.5.2
2013-01-04 12:14:44,680 INFO [org.quartz.core.QuartzScheduler] (main)
Scheduler DefaultQuartzScheduler_$_NON_CLUSTERED started.
2013-01-04 12:14:45,028 INFO
[org.jboss.resource.connectionmanager.ConnectionFactoryBindingService]
(main) Bound ConnectionManager
'jboss.jca:service=DataSourceBinding,name=DefaultDS' to JNDI name
'java:DefaultDS'
2013-01-04 12:14:45,297 INFO [org.jboss.jms.server.ServerPeer] (main) JBoss
Messaging 1.4.3.GA server [0] started
2013-01-04 12:14:45,391 INFO
[org.jboss.jms.server.connectionfactory.ConnectionFactory] (main) Connector
bisocket://optiplex2:4457 has leasing enabled, lease period 10000
milliseconds
org.jboss.jms.server.connectionfactory.ConnectionFactory@anonymised.com started
2013-01-04 12:14:45,399 INFO
milliseconds
2013-01-04 12:14:45,412 INFO
[org.jboss.jms.server.destination.QueueService] (main)
Queue[/queue/ExpiryQueue] started, fullSize=200000, pageSize=2000,
downCacheSize=2000
2013-01-04 12:14:45,413 INFO
[org.jboss.jms.server.connectionfactory.ConnectionFactoryJNDIMapper] (main)
supportsFailover attribute is true on connection factory:
jboss.messaging.connectionfactory:service=ClusteredConnectionFactory but
post office is non clustered. So connection factory will *not* support
failover
supportsLoadBalancing attribute is true on connection factory:
post office is non clustered. So connection factory will *not* support load
balancing
2013-01-04 12:14:45,414 INFO
milliseconds
2013-01-04 12:14:45,415 INFO
[org.jboss.jms.server.destination.QueueService] (main) Queue[/queue/DLQ]
started, fullSize=200000, pageSize=2000, downCacheSize=2000
2013-01-04 12:14:45,484 INFO
'jboss.jca:service=ConnectionFactoryBinding,name=JmsXA' to JNDI name
'java:JmsXA'
2013-01-04 12:14:45,765 INFO [org.jboss.ejb3.deployers.JBossASKernel]
(main) Created KernelDeployment for: profileservice-secured.jar
2013-01-04 12:14:45,768 INFO [org.jboss.ejb3.deployers.JBossASKernel]
(main) installing bean:
jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfileService,service=EJB3
(main) with dependencies:
(main) and demands:
(main)
jndi:SecureManagementView/remote-org.jboss.deployers.spi.management.ManagementView
(main) jboss.ejb:service=EJBTimerService
(main) and supplies:
(main) Class:org.jboss.profileservice.spi.ProfileService
(main) jndi:SecureProfileService/remote
(main)
jndi:SecureProfileService/remote-org.jboss.profileservice.spi.ProfileService
(main) Added
bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfileService,service=EJB3)
to KernelDeployment of: profileservice-secured.jar
2013-01-04 12:14:45,769 INFO [org.jboss.ejb3.deployers.JBossASKernel]
jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploymentManager,service=EJB3
(main) and demands:
(main)
jndi:SecureDeploymentManager/remote-org.jboss.deployers.spi.management.deploy.DeploymentManager
(main) Class:org.jboss.deployers.spi.management.deploy.DeploymentManager
(main) jndi:SecureDeploymentManager/remote
(main) Added
bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploymentManager,service=EJB3)
2013-01-04 12:14:45,770 INFO [org.jboss.ejb3.deployers.JBossASKernel]
jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagementView,service=EJB3
(main) and demands:
(main)
(main) Class:org.jboss.deployers.spi.management.ManagementView
(main) jndi:SecureManagementView/remote
(main) Added
bean(jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagementView,service=EJB3)
2013-01-04 12:14:45,775 INFO
[org.jboss.ejb3.endpoint.deployers.EJB3EndpointDeployer] (main) Deploy
AbstractBeanMetaData@anonymised.com{name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureProfileService,service=EJB3_endpoint
bean=org.jboss.ejb3.endpoint.deployers.impl.EndpointImpl
properties=[container] constructor=null autowireCandidate=true}
AbstractBeanMetaData@anonymised.com{name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureDeploymentManager,service=EJB3_endpoint
AbstractBeanMetaData@anonymised.com{name=jboss.j2ee:jar=profileservice-secured.jar,name=SecureManagementView,service=EJB3_endpoint
2013-01-04 12:14:45,901 INFO [org.jboss.ejb3.session.SessionSpecContainer]
(main) Starting
2013-01-04 12:14:45,909 INFO [org.jboss.ejb3.EJBContainer] (main) STARTED
EJB: org.jboss.profileservice.ejb.SecureDeploymentManager ejbName:
2013-01-04 12:14:45,940 INFO
[org.jboss.ejb3.proxy.impl.jndiregistrar.JndiSessionRegistrarBase] (main)
Binding the following Entries in Global JNDI:
  SecureDeploymentManager/remote - EJB3.x Default Remote Business Interface
- EJB3.x Remote Business Interface
2013-01-04 12:14:45,974 INFO [org.jboss.ejb3.session.SessionSpecContainer]
(main) Starting
2013-01-04 12:14:45,974 INFO [org.jboss.ejb3.EJBContainer] (main) STARTED
EJB: org.jboss.profileservice.ejb.SecureManagementView ejbName:
2013-01-04 12:14:45,981 INFO
  SecureManagementView/remote - EJB3.x Default Remote Business Interface
2013-01-04 12:14:46,005 INFO [org.jboss.ejb3.session.SessionSpecContainer]
(main) Starting
2013-01-04 12:14:46,006 INFO [org.jboss.ejb3.EJBContainer] (main) STARTED
EJB: org.jboss.profileservice.ejb.SecureProfileServiceBean ejbName:
2013-01-04 12:14:46,013 INFO
  SecureProfileService/remote - EJB3.x Default Remote Business Interface
  SecureProfileService/remote-org.jboss.profileservice.spi.ProfileService -
2013-01-04 12:14:46,081 INFO
ctxPath=/admin-console
2013-01-04 12:14:46,123 INFO
[javax.enterprise.resource.webcontainer.jsf.config] (main) Initializing
Mojarra (1.2_12-b01-FCS) for context '/admin-console'
2013-01-04 12:14:47,314 INFO
ctxPath=/
2013-01-04 12:14:47,355 INFO
ctxPath=/geoserver
2013-01-04 12:14:47,487 WARNING [it.geosolutions.imageio.gdalframework]
(main) Failed to load the GDAL native libs. This is not a problem unless you
need to use the GDAL plugins: they won't be enabled.
java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
2013-01-04 12:14:47,701 WARN [org.geoserver.logging] (main) Could not find
configuration file for logging
2013-01-04 12:14:47,717 INFO
[org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/geoserver]]
(main) Initializing Spring root WebApplicationContext
[org.springframework.web.context.ContextLoader] (main) Root
WebApplicationContext: initialization started
2013-01-04 12:14:47,747 INFO
[org.springframework.web.context.support.XmlWebApplicationContext] (main)
Refreshing
org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com:
display name [Root WebApplicationContext]; startup date [Fri Jan 04 12:14:47
EST 2013]; root of context hierarchy
2013-01-04 12:14:47,857 INFO
[org.springframework.beans.factory.xml.XmlBeanDefinitionReader] (main)
Loading XML bean definitions from URL
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/restconfig-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:47,899 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/wfs-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:47,936 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/main-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:47,950 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/web-core-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:47,979 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/web-security-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:47,987 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/wcs-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:47,993 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/wcs1_0-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:48,005 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/rest-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:48,010 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/web-wfs-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:48,016 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/web-wms-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:48,024 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/wms-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:48,060 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/web-demo-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:48,065 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/wcs1_1-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:48,072 INFO
[org.springframework.beans.factory.support.DefaultListableBeanFactory]
(main) Overriding bean definition for bean 'wcsLogger': replacing [Generic
bean: class [org.geoserver.ows.util.EMFLogger]; scope=singleton;
abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0;
autowireCandidate=true; primary=false; factoryBeanName=null;
factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined
in URL
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/wcs1_0-2.1-SNAPSHOT.jar/applicationContext.xml]]
with [Generic bean: class [org.geoserver.ows.util.EMFLogger];
scope=singleton; abstract=false; lazyInit=false; autowireMode=0;
dependencyCheck=0; autowireCandidate=true; primary=false;
factoryBeanName=null; factoryMethodName=null; initMethodName=null;
destroyMethodName=null; defined in URL
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/wcs1_1-2.1-SNAPSHOT.jar/applicationContext.xml]]
2013-01-04 12:14:48,076 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/web-gwc-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:48,082 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/web-wcs-2.1-SNAPSHOT.jar/applicationContext.xml]
2013-01-04 12:14:48,088 INFO
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/main-2.1-SNAPSHOT.jar/applicationSecurityContext.xml]
2013-01-04 12:14:48,100 INFO
Bean factory for application context
[org.springframework.web.context.support.XmlWebApplicationContext@anonymised.com.]:
org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com4...
2013-01-04 12:14:48,447 INFO
Bean 'resourceLoader' is not eligible for getting processed by all
BeanPostProcessors (for example: not eligible for auto-proxying)
2013-01-04 12:14:48,491 INFO
Bean 'wfsService' is not eligible for getting processed by all
2013-01-04 12:14:48,500 INFO
Bean 'wcs100Service' is not eligible for getting processed by all
2013-01-04 12:14:48,502 INFO
Bean 'wmsService2' is not eligible for getting processed by all
2013-01-04 12:14:48,507 INFO
Bean 'wcs111Service' is not eligible for getting processed by all
2013-01-04 12:14:48,531 INFO
Bean 'wmsSVGStrategyExclusionFilter' is not eligible for getting processed
by all BeanPostProcessors (for example: not eligible for auto-proxying)
2013-01-04 12:14:48,584 ERROR [org.vfny.geoserver.global] (main)
- GEOSERVER_DATA_DIR: /opt/data/geoserver
2013-01-04 12:14:48,935 INFO [org.geoserver] (main) Loaded style 'point'
2013-01-04 12:14:48,936 INFO [org.geoserver] (main) Loaded style 'polygon'
2013-01-04 12:14:48,937 INFO [org.geoserver] (main) Loaded style 'raster'
2013-01-04 12:14:48,937 INFO [org.geoserver] (main) Loaded style 'line'
2013-01-04 12:14:48,938 WARN [org.geoserver] (main) No 'workspaces'
directory found, unable to load any stores.
2013-01-04 12:14:48,949 INFO
(main) Destroying singletons in
org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com4...:
defining beans
[restConfigMapping,abstractCatalogFinder,workspaceFinder,namespaceFinder,dataStoreFinder,coverageStoreFinder,wmsStoreFinder,storeFileFinder,featureTypeFinder,coverageFinder,wmsLayerFinder,styleFinder2,layerFinder2,layerGroupFinder2,catalogReloader,catalogResetter,fontFinder,catalogLocker,filterFactory,wfsLegacyLoader,wfsLoader,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElementHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandler,wfsService-1.0.0,wfsService-1.1.0,wfsExceptionHandler,xsdSchemaCleaner,gml2SchemaBuilder,gml3SchemaBuilder,wfsXsd-1.0,xmlConfiguration-1.0,wfsXsd-1.1,xmlConfiguration-1.1,getCapabilitiesResponse,lockFeatureResponse,transactionResponse-1.0.0,geometryResponse,featureResponse,citeComplianceHack,xmlPostRequestLogBufferSize,wfsTestServlet,wfsURLMapping,typeNameKvpParser,getFeatureNamespaceKvpParser,dftNamespaceKvpParser,featureIdKvpParser,bboxKvpParser,filter1_0_0_KvpParser,filter1_1_0_KvpParser,filter1_1_0_KvpParserDefault,cqlKvpParser,propertyNameKvpParser,maxFeatureKvpParser,countKvpParser,wfsStartIndexKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpParser,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsFormatOptionsKvpParser,charsetKvpParser,wfsSqlViewKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpReader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,transactionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,lockFeatureXmlReader,transactionXmlReader,xmlReader-1.1.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatureTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1.0,transactionXmlReader-1.1.0,getGmlObjectXmlReader-1.1.0,gml2FeatureTypeEncoder,gml3FeatureTypeEncoder,gml32FeatureTypeEncoder,gml2OutputFormat,gml3OutputFormat,gml32OutputFormat,hitsOutputFormat,shapezipOutputFormat,geojsonOutputFormat,CSVOutputFormat,wfsWorkspaceQualifier,wfsLocalWorkspaceURLManger,resourceLoader,dataDirectory,extensions,rawCatalog,secureCatalog,geoServer,geoServerLoader,serviceStrategyFactory,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditorConfigurer,dispatcher,filePublisher,classpathPublisher,jaiInitializer,coverageAccessInitializer,loggingInitializer,resourcePoolInitializer,defaultDataSecurityFactory,defaultCatalogSecurityFactory,disabledServiceChecker,dispatcherMapping,filePublisherMapping,classpathPublisherMapping,catalogRepository,proxyfier,owsDispatcherLocalWorkspaceURLManger,xstreamPersisterFactory,workspaceLocal,updateSequenceListener,namespaceWorkspaceConsistencyListener,localWorkspaceFilter,advertisedResourceFilter,configurationLock,enviromentInjector,webApplication,wicket,webDispatcherMapping,aboutStatusCategory,dataCategory,servicesCategory,settingsCategory,statusMenuPage,logsPage,contactMenuPage,aboutMenuPage,globalSettingsMenuPage,JAIMenuPage,coverageAccessMenuPage,workspaceMenuPage,storeMenuPage,layerMenuPage,layerGroupMenuPage,demoMenuPage,toolMenuPage,basicResourceConfigPanel,featureResourceConfigPanel,coverageResourceConfigPanel,basicLayerConfigPanel,httpLayerConfigPanel,defaultDataStorePanel,defaultCoverageStorePanel,geotiffStorePanel,arcGridStorePanel,gtopo30StorePanel,worldImageStorePanel,genericGDALStorePanel,postgisDataStorePanel,shapefileDataStorePanel,shapefileDirectoryDataStorePanel,propertyDataStorePanel,wfsDataStorePanel,ServiceInfoCapabilitiesProvider,wicketConfigurationLocker,wicketEnvVariableInjector,securityCategory,userSecurityPage,dataSecurityPage,serviceSecurityPage,catalogSecurityPage,legacyWcsLoader,wcsLoader,wcsAbstractService,wcsURLMapping,wcsLocalWorkspaceURLManger,wcs100ServiceTarget,wcsLogger,wcs100Service,wcsService-1.0.0,wcs100ExceptionHandler,wcs100AxisSubsetKvpParser,wcs100BBoxKvpParser,wcs100CoverageKvpParser,wcs100SourceCoverageKvpParser,wcs100SectionKvpParser,wcs100GetCapabilitiesKvpReader,wcs100DescribeCoverageKvpReader,wcs100GetCoverageRequestReader,wcs-1.0.0-configuration,wcs100CapabilitiesRequestReader,wcs100DescribeCoverageRequestReader,wcs100GetCoverageRequestXMLReader,wcs100GetCapabilitiesResponse,wcs100DescribeCoverageResponse,wcs100GetCoverageResponse,workspaceQualifier,restWrapper,restletDispatcherMapping,wfsServicePage,wfsLayerConfig,wmsServicePage,wmsLayerConfig,wmsLayerGroupConfig,attributionLayerConfig,kmlLayerConfig,styleMenuPage,wmsLegacyLoader,wmsLoader,wms,wmsRegisterar,wmsGetCapabilities,wmsGetStyles,wmsDescribeLayer,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetFeatureInfoPlainText,wmsGetFeatureInfoGML2,wmsGetFeatureInfoHTML,wmsServiceTarget,wmsLogger,wmsService2,wms-1_1_1-ServiceDescriptor,wmsExceptionHandler,wms-1_3_0-ServiceDescriptor,AnimatedGIFDelayKvpParser,AnimatedGIFLoopContinuoslyKvpParser,widthKvpParser,heightKvpParser,wmsFormatOptionsKvpParser,wmsEnviromentKvpParser,wmsLegendOptionsKvpParser,wmsSqlViewKvpParser,bgColorKvpParser,transparentKvpParser,tiledKvpParser,tilesOriginKvpParser,bufferKvpParser,paletteKvpParser,timeKvpParser,elevationKvpParser,validateSldKvpParser,sldKvpParser,startIndexKvpParser,angleKvpParser,stylesKvpParser,dpiKvpParser,wmsGetCapabilitiesKvpReader,describeLayerKvpReader,getMapKvpReader,getFeatureInfoKvpReader,getLegendGraphicKvpReader,getStylesKvpReader,wmsCapabilitiesXmlReader,getMapXmlReader,sldXmlReader,wms_1_1_1_GetCapabilitiesResponse,wms_1_3_0_GetCapabilitiesResponse,describeLayerResponse,getFeatureInfoResponse,stylesResponse,wmsURLMapping,wmsGIFLegendOutputFormat,wmsGIFLegendGraphicResponse,wmsJPEGLegendGraphicOutputFormat,wmsJPEGLegendGraphicResponse,wmsPNGLegendOutputFormat,wmsPNGLegendGraphicResponse,wmsXMLTransformerResponse,PNGMapProducer,PNG8MapProducer,PNGMapResponse,GeoTiffMapProducer,GeoTiffMapProducer8,GeoTiffMapResponse,TiffMapProducer,Tiff8MapProducer,TiffMapResponse,GIFMapProducer,GIFMapResponse,JPEGMapProducer,JPEGMapResponse,PDFMapProducer,PDFMapResponse,KMLMapProducer,KMZMapProducer,KMZMapResponse,NetworkLinkMapProducer,OpenLayersMapProducer,OpenLayersMapResponse,AtomGeoRSSMapProducer,RSSGeoRSSMapProducer,SVGBatikMapOutputFormat,SVGBatikMapResponse,SVGStreamingMapOutputFormat,SVGStreamingMapResponse,wmsSVGStrategyExclusionFilter,kmlURLMapping,animateURLMapping,superOverlayKvpParser,legendKvpParser,kmatrrKvpParser,kmscoreKvpParser,kmplacemarkKvpParser,metaTileCache,nativeSortingRegionator,externalSortingRegionator,geometryRegionator,randomRegionator,bestGuessRegionator,image,legend,scaleratio,scaleline,text,wmsWorkspaceQualifier,wmsLocalWorkspaceURLManger,wmsLifecycleHandler,wmsCatalogValidator,rasterCleaner,wmsClasspathPublisherMapping,layerListDemo2,demoRequests,srsList,wcs111ServiceTarget,wcs111Service,wcsService-1.1.0,wcsService-1.1.1,wcs111ExceptionHandler,ows11AcceptVersionsKvpParser,ows11SectionsKvpParser,wcs111RangeSubsetKvpParser,wcs111IdentifierKvpParser,wcs111BoundingBoxKvpParser,wcs111GridBaseCRSKvpParser,wcs111TimeSequenceKvpParser,wcs111GridTypeKvpParser,wcs111GridCSKvpParser,wcs111GridOriginKvpParser,wcs111GridOffsetsKvpParser,wcs111GetCapabilitiesKvpReader,wcs111DescribeCoverageKvpReader,wcs111GetCoverageRequestReader,wcs111StoreKvpParser,wcs-1.1.1-configuration,wcs111CapabilitiesRequestReader,wcs111DescribeCoverageRequestReader,wcs111GetCoverageRequestXMLReader,wcs111GetCapabilitiesResponse,wcs111DescribeCoverageResponse,wcs111GetCoverageMultipartResponse,wcs111GetCoverageStoreResponse,wcs111DispatcherMapping,wcs111TempStorageCleaner,wcs111TempStorageCleanerTask,wcs111timerFactory,wcs11WorkspaceQualifier,GWCCapabilitiesHomePageProvider,gwcSettingsMenuPage,cachedLayersMenuPage,wcsServicePage,wcsLayerConfig,wcsRequestBuilder,filterChainProxy,restFilterInvocationInterceptor,restFilterDefinitionMap,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,httpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProcessingFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,basicProcessingFilter,basicProcessingFilterWithoutRememberMeService,basicProcessingFilterEntryPoint,consoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices,authenticationManager,daoAuthenticationProvider,userDetailsService,accessRulesDao,serviceRulesDao,restRulesDao,operationCallback];
root of factory hierarchy
2013-01-04 12:14:48,950 WARN
[org.springframework.beans.factory.support.DisposableBeanAdapter] (main)
Invocation of destroy method failed on bean with name 'geoServerLoader':
java.lang.NullPointerException
2013-01-04 12:14:48,950 ERROR
[org.springframework.web.context.ContextLoader] (main) Context
initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'wmsLifecycleHandler' defined in URL
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/wms-2.1-SNAPSHOT.jar/applicationContext.xml]:
Cannot resolve reference to bean 'wms' while setting constructor argument;
nested exception is org.springframework.beans.factory.BeanCreationException:
Error creating bean with name 'wms' defined in URL
Cannot resolve reference to bean 'geoServer' while setting constructor
argument; nested exception is
with name 'geoServer' defined in URL
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/main-2.1-SNAPSHOT.jar/applicationContext.xml]:
Cannot resolve reference to bean 'catalog' while setting bean property
'catalog'; nested exception is
with name 'accessRulesDao' defined in URL
[vfszip:/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/main-2.1-SNAPSHOT.jar/applicationSecurityContext.xml]:
Instantiation of bean failed; nested exception is
org.springframework.beans.BeanInstantiationException: Could not instantiate
bean class [org.geoserver.security.impl.DataAccessRuleDAO]: Constructor
threw exception; nested exception is java.io.FileNotFoundException: class
path resource [security] cannot be resolved to absolute file path because it
does not reside in the file system:
vfszip:/opt/jboss/common/lib/jboss-ejb3-core.jar/security/
  at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
  at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
  at
org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:479)
  at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
  at java.security.AccessController.doPrivileged(Native Method)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
  at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
  at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
  at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
  at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
  at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
  at
org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:308)
  at
org.springframework.context.support.AbstractApplicationContext.getBeansOfType(AbstractApplicationContext.java:948)
  at
org.springframework.context.support.AbstractApplicationContext.registerListeners(AbstractApplicationContext.java:702)
  at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:378)
  at
org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
  at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
  at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
  at
org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
  at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3910)
  at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4393)
  at
org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeployInternal(TomcatDeployment.java:310)
  at
org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeploy(TomcatDeployment.java:142)
  at
org.jboss.web.deployers.AbstractWarDeployment.start(AbstractWarDeployment.java:461)
  at org.jboss.web.deployers.WebModule.startModule(WebModule.java:118)
  at org.jboss.web.deployers.WebModule.start(WebModule.java:97)
  at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  at java.lang.reflect.Method.invoke(Method.java:616)
  at
org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157)
  at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96)
  at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
  at
org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
  at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:668)
  at
org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206)
  at $Proxy38.start(Unknown Source)
  at
org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:42)
  at
org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:37)
  at
org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62)
  at
org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71)
  at
org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51)
  at
org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:348)
  at
org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:286)
  at
org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:1631)
  at
org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:934)
  at
org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1082)
  at
org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:984)
  at
org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:822)
  at
org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:553)
  at org.jboss.system.ServiceController.doChange(ServiceController.java:688)
  at org.jboss.system.ServiceController.start(ServiceController.java:460)
  at
org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:163)
  at
org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:99)
  at
org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:46)
  at
org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62)
  at
org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:50)
  at
org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:171)
  at
org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1439)
  at
org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1157)
  at
org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1178)
  at
org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1098)
  at
  at
  at
  at
  at
  at
  at
  at
org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:781)
  at
org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:702)
  at
org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117)
  at
org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70)
  at
org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53)
  at
org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:361)
  at
  at
  at
  at
  at
  at
  at
  at
org.jboss.system.server.profileservice.repository.AbstractProfileService.activateProfile(AbstractProfileService.java:306)
  at
org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:271)
  at
org.jboss.bootstrap.AbstractServerImpl.start(AbstractServerImpl.java:461)
  at org.jboss.Main.boot(Main.java:221)
  at org.jboss.Main$1.run(Main.java:556)
  at java.lang.Thread.run(Thread.java:679)
Caused by: org.springframework.beans.factory.BeanCreationException: Error
  at
  at
  at
org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
  ... 91 more
creating bean with name 'geoServer' defined in URL
  at
  at
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
  at
  at
  at
  at
  at
  at
  at
  at
  ... 106 more
creating bean with name 'accessRulesDao' defined in URL
  at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:254)
  at
  at
  at
  ... 119 more
Caused by: org.springframework.beans.BeanInstantiationException: Could not
instantiate bean class [org.geoserver.security.impl.DataAccessRuleDAO]:
Constructor threw exception; nested exception is
java.io.FileNotFoundException: class path resource [security] cannot be
resolved to absolute file path because it does not reside in the file
system: vfszip:/opt/jboss/common/lib/jboss-ejb3-core.jar/security/
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
  at
org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
  at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
  ... 134 more
Caused by: java.io.FileNotFoundException: class path resource [security]
cannot be resolved to absolute file path because it does not reside in the
file system: vfszip:/opt/jboss/common/lib/jboss-ejb3-core.jar/security/
  at org.springframework.util.ResourceUtils.getFile(ResourceUtils.java:198)
  at
org.springframework.core.io.ClassPathResource.getFile(ClassPathResource.java:174)
  at
org.geoserver.platform.GeoServerResourceLoader.find(GeoServerResourceLoader.java:229)
  at
org.geoserver.platform.GeoServerResourceLoader.findOrCreateDirectory(GeoServerResourceLoader.java:332)
  at
org.geoserver.platform.GeoServerResourceLoader.findOrCreateDirectory(GeoServerResourceLoader.java:318)
  at
org.geoserver.config.GeoServerDataDirectory.securityRoot(GeoServerDataDirectory.java:192)
  at
org.geoserver.config.GeoServerDataDirectory.findOrCreateSecurityRoot(GeoServerDataDirectory.java:188)
  at
org.geoserver.security.impl.AbstractAccessRuleDAO.<init>(AbstractAccessRuleDAO.java:76)
  at
org.geoserver.security.impl.DataAccessRuleDAO.<init>(DataAccessRuleDAO.java:68)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
  at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
  ... 136 more
2013-01-04 12:14:48,953 ERROR
(main) Exception sending context initialized event to listener instance of
class org.geoserver.platform.GeoServerContextLoaderListener
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 91 more
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 106 more
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 119 more
  at
  at
  ... 134 more
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  ... 136 more
2013-01-04 12:14:49,017 ERROR [org.apache.catalina.core.StandardContext]
(main) Error listenerStart
(main) Context [/geoserver] startup failed due to previous errors
2013-01-04 12:14:49,017 INFO
(main) Closing Spring root WebApplicationContext
2013-01-04 12:14:49,017 INFO [org.geoserver.logging] (main) Beginning
GeoServer cleanup sequence
2013-01-04 12:14:49,091 INFO [org.geotools.referencing.factory] (main) The
EPSG factory org.geotools.referencing.factory.epsg.DefaultFactory will not
timeout
2013-01-04 12:14:49,106 INFO [org.geotools.referencing.factory] (main) The
EPSG factory org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory
will not timeout
2013-01-04 12:14:49,109 INFO [org.geotools.referencing.factory] (main) The
timeout
2013-01-04 12:14:49,146 INFO [org.geotools.referencing.factory] (main) The
will not timeout
2013-01-04 12:14:49,147 INFO [org.geotools.referencing.factory.epsg] (main)
Building new data source for
2013-01-04 12:14:49,149 INFO [org.geotools.referencing.factory.epsg] (main)
Building backing store for
2013-01-04 12:14:49,227 INFO [org.geotools.referencing.factory] (main)
Connected to EPSG database
"jdbc:hsqldb:file:/tmp/Geotools/Databases/HSQL/v7.9.0/EPSG;shutdown=true" on
"HSQL Database Engine".
2013-01-04 12:14:49,286 INFO [org.geoserver.logging] (main) Disposing
referencing factory LongitudeFirstFactory["European Petroleum Survey Group"]
  FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
  FORCE_STANDARD_AXIS_DIRECTIONS = false
  FORCE_STANDARD_AXIS_UNITS = false
  CS_AUTHORITY_FACTORY =
OrderedAxisAuthorityFactory["European Petroleum Survey Group"]
    DATUM_AUTHORITY_FACTORY =
ThreadedHsqlEpsgFactory["European Petroleum Survey Group"]
      EPSG_DATA_SOURCE = java:comp/env/jdbc/EPSG
      DATUM_AUTHORITY_FACTORY = FactoryUsingHSQL["European
        FORCE_LONGITUDE_FIRST_AXIS_ORDER = false
        VERSION = 7.9
        CRS_FACTORY = ReferencingObjectFactory
        CS_FACTORY = (same as CRS_FACTORY)
        DATUM_FACTORY = DatumAliases
        MATH_TRANSFORM_FACTORY = DefaultMathTransformFactory
      CS_AUTHORITY_FACTORY = (same as
DATUM_AUTHORITY_FACTORY)
      CRS_AUTHORITY_FACTORY = (same as
      COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as
CS_AUTHORITY_FACTORY)
2013-01-04 12:14:50,164 INFO [org.geoserver.logging] (main) Disposing
referencing factory HTTP_AuthorityFactory["URL in OGC namespace"]
  DATUM_AUTHORITY_FACTORY = AllAuthoritiesFactory["All"]
  CS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY)
  CRS_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY)
  COORDINATE_OPERATION_AUTHORITY_FACTORY = (same as DATUM_AUTHORITY_FACTORY)
2013-01-04 12:14:50,166 INFO [org.geotools.referencing.factory] (main)
Using
"/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/main-2.1-SNAPSHOT.jar/org/vfny/geoserver/crs/override_epsg.properties"
as EPSG factory.
2013-01-04 12:14:50,169 INFO [org.geotools.referencing.factory.epsg] (main)
2013-01-04 12:14:50,192 INFO [org.geotools.referencing.factory] (main)
2013-01-04 12:14:50,200 INFO [org.geoserver.logging] (main) Disposing
referencing factory GeoserverOverridingWKTFactory["European Petroleum Survey
Group"]
  CRS_AUTHORITY_EXTRA_DIRECTORY = null
  DATUM_AUTHORITY_FACTORY = PropertyAuthorityFactory["European
2013-01-04 12:14:50,203 INFO [org.geotools.referencing.factory] (main)
Using
"/opt/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/main-2.1-SNAPSHOT.jar/org/vfny/geoserver/crs/user_epsg.properties"
as EPSG factory.
2013-01-04 12:14:50,206 INFO [org.geoserver.logging] (main) Disposing
        VERSION = 7.9
2013-01-04 12:14:50,865 INFO [org.geoserver.logging] (main) Disposing
referencing factory GeoserverCustomWKTFactory["European Petroleum Survey
Group"]
referencing factory WebCRSFactory["Web Map Service CRS"]
referencing factory AutoCRSFactory["Automatic Projections"]
2013-01-04 12:14:50,866 INFO [org.geoserver.logging] (main) Disposing
2013-01-04 12:14:50,869 INFO [org.geotools.referencing.factory] (main) The
will not timeout
timeout
2013-01-04 12:14:50,870 INFO [org.geotools.referencing.factory.epsg] (main)
2013-01-04 12:14:50,892 INFO [org.geotools.referencing.factory] (main)
2013-01-04 12:14:50,900 INFO [org.geoserver.logging] (main) Disposing
        VERSION = 7.9
2013-01-04 12:14:51,557 INFO [org.geoserver.logging] (main) Disposing
2013-01-04 12:14:51,557 INFO [org.geotools.util] (WeakCollectionCleaner)
Weak collection cleaner stopped
2013-01-04 12:14:51,573 INFO [org.geoserver.logging] (main) Shut down GT
referencing threads
2013-01-04 12:14:51,575 INFO [org.geoserver.logging] (main) Shut down GT
SPI
coverage thread pool
2013-01-04 12:14:51,576 INFO [org.geoserver.logging] (main) Unregistering
Image I/O provider
com.sun.media.imageioimpl.plugins.bmp.BMPImageReaderSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageWriterSpi@anonymised.com
Image I/O provider
it.geosolutions.imageio.stream.input.spi.StringImageInputStreamSpi@anonymised.com..
Image I/O provider
it.geosolutions.imageio.stream.output.spi.FileImageOutputStreamExtImplSpi@anonymised.com..5308...
Image I/O provider
com.sun.media.imageioimpl.plugins.tiff.TIFFImageWriterSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.plugins.pnm.PNMImageReaderSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.plugins.bmp.BMPImageWriterSpi@anonymised.com
Image I/O provider
it.geosolutions.imageio.stream.input.spi.FileImageInputStreamExtImplSpi@anonymised.com5312...
Image I/O provider
it.geosolutions.imageio.stream.input.spi.URLImageInputStreamSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.plugins.wbmp.WBMPImageReaderSpi@anonymised.com
Image I/O provider
it.geosolutions.imageio.plugins.arcgrid.spi.AsciiGridsImageReaderSpi@anonymised.com5...
Image I/O provider
it.geosolutions.imageioimpl.plugins.tiff.TIFFImageWriterSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.stream.ChannelImageOutputStreamSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.stream.ChannelImageInputStreamSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReaderSpi@anonymised.com
2013-01-04 12:14:51,577 INFO [org.geoserver.logging] (main) Unregistering
Image I/O provider
com.sun.media.imageioimpl.plugins.wbmp.WBMPImageWriterSpi@anonymised.com
Image I/O provider
it.geosolutions.imageio.plugins.arcgrid.spi.AsciiGridsImageWriterSpi@anonymised.com1...
Image I/O provider
com.sun.media.imageioimpl.plugins.raw.RawImageWriterSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.plugins.gif.GIFImageWriterSpi@anonymised.com
Image I/O provider
it.geosolutions.imageio.plugins.jp2kakadu.JP2GDALKakaduImageWriterSpi@anonymised.com24...
Image I/O provider
it.geosolutions.imageio.stream.output.spi.URLImageOutputStreamSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.plugins.raw.RawImageReaderSpi@anonymised.com
Image I/O provider
it.geosolutions.imageio.stream.output.spi.StringImageOutputStreamSpi@anonymised.com7...
Image I/O provider
com.sun.media.imageioimpl.plugins.tiff.TIFFImageReaderSpi@anonymised.com
Image I/O provider
com.sun.media.imageioimpl.plugins.pnm.PNMImageWriterSpi@anonymised.com
Image I/O provider
it.geosolutions.imageioimpl.plugins.tiff.TIFFImageReaderSpi@anonymised.com
2013-01-04 12:14:51,942 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.mlib.MlibMultiplyRIF
JAI factory class com.sun.media.jai.opimage.MultiplyCRIF
JAI factory class com.sun.media.jai.mlib.MlibLogRIF
JAI factory class com.sun.media.jai.opimage.LogCRIF
2013-01-04 12:14:51,943 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.opimage.PNMRIF
JAI factory class com.sun.media.jai.opimage.IIPCRIF
JAI factory class com.sun.media.jai.mlib.MlibGradientRIF
JAI factory class com.sun.media.jai.opimage.GradientRIF
JAI factory class com.sun.media.jai.opimage.PatternRIF
JAI factory class com.sun.media.jai.opimage.PNGRIF
JAI factory class javax.media.jai.NullCRIF
JAI factory class com.sun.media.jai.opimage.FileStoreRIF
JAI factory class com.sun.media.jai.imageioimpl.ImageWriteCRIF
JAI factory class com.sun.media.jai.mlib.MlibBandCombineRIF
2013-01-04 12:14:51,944 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.opimage.BandCombineCRIF
JAI factory class com.sun.media.jai.mlib.MlibTranslateRIF
JAI factory class com.sun.media.jai.opimage.TranslateCRIF
JAI factory class com.sun.media.jai.mlib.MlibConvolveRIF
JAI factory class com.sun.media.jai.opimage.ConvolveRIF
JAI factory class com.sun.media.jai.mlib.MlibDCTRIF
JAI factory class com.sun.media.jai.opimage.DCTCRIF
JAI factory class com.sun.media.jai.opimage.GIFRIF
JAI factory class com.sun.media.jai.opimage.IIPResolutionRIF
JAI factory class com.sun.media.jai.opimage.FormatCRIF
2013-01-04 12:14:51,945 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.mlib.MlibAddRIF
JAI factory class com.sun.media.jai.opimage.AddCRIF
JAI factory class com.sun.media.jai.mlib.MlibMaxRIF
JAI factory class com.sun.media.jai.opimage.MaxCRIF
JAI factory class com.sun.media.jai.opimage.BorderRIF
JAI factory class com.sun.media.jai.mlib.MlibRescaleRIF
JAI factory class com.sun.media.jai.opimage.RescaleCRIF
JAI factory class com.sun.media.jai.mlib.MlibBinarizeRIF
JAI factory class com.sun.media.jai.opimage.BinarizeCRIF
JAI factory class com.sun.media.jai.opimage.DivideComplexCRIF
2013-01-04 12:14:51,946 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.mlib.MlibDilateRIF
JAI factory class com.sun.media.jai.opimage.DilateRIF
JAI factory class com.sun.media.jai.mlib.MlibHistogramRIF
JAI factory class com.sun.media.jai.opimage.HistogramRIF
JAI factory class com.sun.media.jai.opimage.AddCollectionCRIF
JAI factory class com.sun.media.jai.opimage.URLRIF
JAI factory class com.sun.media.jai.opimage.PolarToComplexCRIF
JAI factory class com.sun.media.jai.mlib.MlibSubtractConstRIF
JAI factory class com.sun.media.jai.opimage.SubtractConstCRIF
JAI factory class com.sun.media.jai.mlib.MlibMaxFilterRIF
JAI factory class com.sun.media.jai.opimage.MaxFilterRIF
2013-01-04 12:14:51,947 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.opimage.JPEGRIF
JAI factory class com.sun.media.jai.opimage.ErrorDiffusionRIF
JAI factory class com.sun.media.jai.imageioimpl.ImageReadCRIF
JAI factory class com.sun.media.jai.mlib.MlibMeanRIF
JAI factory class com.sun.media.jai.opimage.MeanRIF
JAI factory class com.sun.media.jai.opimage.EncodeRIF
JAI factory class com.sun.media.jai.opimage.PhaseCRIF
JAI factory class com.sun.media.jai.opimage.ConjugateCRIF
JAI factory class com.sun.media.jai.opimage.OrderedDitherRIF
JAI factory class com.sun.media.jai.mlib.MlibOrRIF
2013-01-04 12:14:51,948 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.opimage.OrCRIF
JAI factory class com.sun.media.jai.opimage.BandMergeCRIF
JAI factory class com.sun.media.jai.opimage.CropCRIF
JAI factory class com.sun.media.jai.mlib.MlibExtremaRIF
JAI factory class com.sun.media.jai.opimage.ExtremaRIF
JAI factory class com.sun.media.jai.mlib.MlibSubtractRIF
JAI factory class com.sun.media.jai.opimage.SubtractCRIF
JAI factory class com.sun.media.jai.opimage.ConstantCRIF
JAI factory class com.sun.media.jai.mlib.MlibIDFTRIF
JAI factory class com.sun.media.jai.opimage.IDFTCRIF
2013-01-04 12:14:51,949 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.mlib.MlibInvertRIF
JAI factory class com.sun.media.jai.opimage.InvertCRIF
JAI factory class com.sun.media.jai.opimage.PiecewiseCRIF
JAI factory class com.sun.media.jai.mlib.MlibDivideByConstRIF
JAI factory class com.sun.media.jai.opimage.DivideByConstCRIF
JAI factory class com.sun.media.jai.mlib.MlibOrConstRIF
JAI factory class com.sun.media.jai.opimage.OrConstCRIF
JAI factory class com.sun.media.jai.mlib.MlibMosaicRIF
JAI factory class com.sun.media.jai.opimage.MosaicRIF
JAI factory class com.sun.media.jai.mlib.MlibRotateRIF
JAI factory class com.sun.media.jai.opimage.RotateCRIF
2013-01-04 12:14:51,950 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.mlib.MlibXorConstRIF
JAI factory class com.sun.media.jai.opimage.XorConstCRIF
JAI factory class com.sun.media.jai.mlib.MlibShearRIF
JAI factory class com.sun.media.jai.opimage.ShearRIF
JAI factory class com.sun.media.jai.opimage.MagnitudeSquaredCRIF
JAI factory class com.sun.media.jai.mlib.MlibAddConstRIF
JAI factory class com.sun.media.jai.opimage.AddConstCRIF
JAI factory class com.sun.media.jai.mlib.MlibAndRIF
JAI factory class com.sun.media.jai.opimage.AndCRIF
JAI factory class com.sun.media.jai.opimage.StreamRIF
JAI factory class com.sun.media.jai.opimage.ColorConvertCRIF
2013-01-04 12:14:51,951 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.mlib.MlibXorRIF
JAI factory class com.sun.media.jai.opimage.XorCRIF
JAI factory class com.sun.media.jai.mlib.MlibAbsoluteRIF
JAI factory class com.sun.media.jai.opimage.AbsoluteCRIF
JAI factory class com.sun.media.jai.mlib.MlibSubtractFromConstRIF
JAI factory class com.sun.media.jai.opimage.SubtractFromConstCRIF
JAI factory class com.sun.media.jai.mlib.MlibCompositeRIF
JAI factory class com.sun.media.jai.opimage.CompositeCRIF
JAI factory class com.sun.media.jai.opimage.BMPRIF
JAI factory class com.sun.media.jai.opimage.TIFFRIF
JAI factory class com.sun.media.jai.mlib.MlibBoxFilterRIF
2013-01-04 12:14:51,952 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.opimage.BoxFilterRIF
JAI factory class com.sun.media.jai.mlib.MlibBandSelectRIF
JAI factory class com.sun.media.jai.opimage.BandSelectCRIF
JAI factory class com.sun.media.jai.mlib.MlibDFTRIF
JAI factory class com.sun.media.jai.opimage.DFTCRIF
JAI factory class com.sun.media.jai.mlib.MlibErodeRIF
JAI factory class com.sun.media.jai.opimage.ErodeRIF
JAI factory class com.sun.media.jai.mlib.MlibMultiplyConstRIF
JAI factory class com.sun.media.jai.opimage.MultiplyConstCRIF
JAI factory class com.sun.media.jai.mlib.MlibUnsharpMaskRIF
JAI factory class com.sun.media.jai.opimage.UnsharpMaskRIF
2013-01-04 12:14:51,953 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.mlib.MlibMinFilterRIF
JAI factory class com.sun.media.jai.opimage.MinFilterRIF
JAI factory class com.sun.media.jai.mlib.MlibExpRIF
JAI factory class com.sun.media.jai.opimage.ExpCRIF
JAI factory class com.sun.media.jai.opimage.ColorQuantizerRIF
JAI factory class com.sun.media.jai.opimage.OverlayCRIF
JAI factory class com.sun.media.jai.mlib.MlibAndConstRIF
JAI factory class com.sun.media.jai.opimage.AndConstCRIF
JAI factory class com.sun.media.jai.opimage.FileLoadRIF
JAI factory class com.sun.media.jai.mlib.MlibSubsampleAverageRIF
JAI factory class com.sun.media.jai.opimage.SubsampleAverageCRIF
2013-01-04 12:14:51,954 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.mlib.MlibThresholdRIF
JAI factory class com.sun.media.jai.opimage.ThresholdCRIF
JAI factory class com.sun.media.jai.opimage.MatchCDFCRIF
JAI factory class com.sun.media.jai.opimage.MultiplyComplexCRIF
JAI factory class com.sun.media.jai.mlib.MlibScaleRIF
JAI factory class com.sun.media.jai.opimage.ScaleCRIF
JAI factory class com.sun.media.jai.mlib.MlibDivideRIF
JAI factory class com.sun.media.jai.opimage.DivideCRIF
JAI factory class com.sun.media.jai.mlib.MlibClampRIF
JAI factory class com.sun.media.jai.opimage.ClampCRIF
JAI factory class com.sun.media.jai.mlib.MlibAffineRIF
2013-01-04 12:14:51,955 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.opimage.AffineCRIF
JAI factory class com.sun.media.jai.opimage.AWTImageRIF
JAI factory class com.sun.media.jai.opimage.MagnitudeCRIF
JAI factory class com.sun.media.jai.mlib.MlibLookupRIF
JAI factory class com.sun.media.jai.opimage.LookupCRIF
JAI factory class com.sun.media.jai.mlib.MlibSubsampleBinaryToGrayRIF
JAI factory class com.sun.media.jai.opimage.SubsampleBinaryToGrayCRIF
JAI factory class com.sun.media.jai.mlib.MlibNotRIF
JAI factory class com.sun.media.jai.opimage.NotCRIF
JAI factory class com.sun.media.jai.mlib.MlibIDCTRIF
JAI factory class com.sun.media.jai.opimage.IDCTCRIF
2013-01-04 12:14:51,956 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.mlib.MlibDivideIntoConstRIF
JAI factory class com.sun.media.jai.opimage.DivideIntoConstCRIF
JAI factory class com.sun.media.jai.opimage.ImageFunctionRIF
JAI factory class com.sun.media.jai.mlib.MlibMedianFilterRIF
JAI factory class com.sun.media.jai.opimage.MedianFilterRIF
JAI factory class com.sun.media.jai.mlib.MlibFilteredSubsampleRIF
JAI factory class com.sun.media.jai.opimage.FilteredSubsampleRIF
JAI factory class com.sun.media.jai.mlib.MlibMinRIF
JAI factory class com.sun.media.jai.opimage.MinCRIF
JAI factory class com.sun.media.jai.mlib.MlibWarpRIF
JAI factory class com.sun.media.jai.opimage.WarpRIF
2013-01-04 12:14:51,957 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.opimage.PeriodicShiftCRIF
JAI factory class com.sun.media.jai.opimage.FPXRIF
JAI factory class com.sun.media.jai.mlib.MlibTransposeRIF
JAI factory class com.sun.media.jai.opimage.TransposeCRIF
2013-01-04 12:14:51,958 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.imageioimpl.ImageReadCIF
JAI factory class com.sun.media.jai.opimage.AddConstToCollectionCIF
JAI factory class com.sun.media.jai.imageioimpl.ImageWriteCIF
JAI factory class com.sun.media.jai.tilecodec.RawTileDecoderFactory
JAI factory class com.sun.media.jai.tilecodec.JPEGTileDecoderFactory
JAI factory class com.sun.media.jai.tilecodec.GZIPTileDecoderFactory
2013-01-04 12:14:51,959 INFO [org.geoserver.logging] (main) Unregistering
JAI factory class com.sun.media.jai.tilecodec.RawTileEncoderFactory
JAI factory class com.sun.media.jai.tilecodec.JPEGTileEncoderFactory
JAI factory class com.sun.media.jai.tilecodec.GZIPTileEncoderFactory
2013-01-04 12:14:51,959 INFO [org.geoserver.logging] (main) Cleaned up
javabean caches
These are my settings:
OS: Windows 7 Professional 64-bit
JDK 7u5 64-bit
JBoss 7.1.1.Final
GeoServer 2.1.4
Environment variables:
Path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program
Files\BroadcomBroadcom 802.11\Driver;C:\Program Files (x86)\Microsoft
Visual Studio 10.0\VC\bin\amd64;C:\gdal;C:\gdal\bin
GDAL_DATA=C:\gdal\data
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-deploying-GeoServer-2-1-x-on-JBoss-5-1-tp5025562.html
Anyone can help?
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-deploying-GeoServer-2-1-x-on-JBoss-5-1-tp5025562p5025852.html
