[Geoserver-users] Error: Failed to load attribute list
Greetings–
I’m pretty new to Geoserver, but I have been figuring things out until now…and I could use some help or advice.
I’m loading shapefiles into a directory on the server, publishing the directory as a store (Directory of Shapefiles), and then publishing each shapefile individually as a layer. I have ~100 shapefiles in the directory, and it has been going well until recently.
At about the 90th shapefile in the store, I am able to publish the layer but then when I go back to look at it, I see:
“Failed to load attribute list, internal error is: null” in a red line along the top.
I tried searching for this error, but haven’t found anything.
And if I try to reload the feature type and then recompute the bounds, I get an error log (see below). Any ideas? It’s exactly the same data and I have used exactly the same steps for each layer. I have tried putting the shapefiles in a different directory, but I still get the same error.
Any help is appreciated!
-Carolin
java.lang.NullPointerException at org.geoserver.catalog.impl.DefaultCatalogFacade.getResource(DefaultCatalogFacade.java:288) at org.geoserver.catalog.impl.CatalogImpl.getResource(CatalogImpl.java:413) at org.geoserver.catalog.impl.CatalogImpl.getFeatureType(CatalogImpl.java:507) at org.geoserver.catalog.ResourcePool$FeatureTypeCache.removeLRU(ResourcePool.java:1392) at org.apache.commons.collections.map.LRUMap.addMapping(LRUMap.java:239) at org.apache.commons.collections.map.AbstractHashedMap.put(AbstractHashedMap.java:282) at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:687) at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:599) at org.geoserver.catalog.ResourcePool.loadAttributes(ResourcePool.java:482) at org.geoserver.catalog.ResourcePool.getAttributes(ResourcePool.java:458) at org.geoserver.catalog.impl.FeatureTypeInfoImpl.attributes(FeatureTypeInfoImpl.java:82) at org.geoserver.catalog.ResourcePool.getFeatureSource(ResourcePool.java:877) at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureSource(FeatureTypeInfoImpl.java:91) at sun.reflect.GeneratedMethodAccessor329.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144) at $Proxy11.getFeatureSource(Unknown Source) at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:546) at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:528) at org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResourceConfig.java:115) at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68) at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143) at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177) at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300) at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119) at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92) at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250) at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484) at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160) at javax.servlet.http.HttpServlet.service(HttpServlet.java:641) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511) at javax.servlet.http.HttpServlet.service(HttpServlet.java:641) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74) at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394) at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109) at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185) at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407) at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:200) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:565) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:307) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:662)
Apologies for the double emails, but the error log was jumbled in my last message. Please see below.
On Mon, Mar 10, 2014 at 3:31 PM, Carolin Ferwerda <cferwerda@anonymised.com> wrote:
Greetings–
-Carolin
On Mon, Mar 10, 2014 at 8:35 PM, Carolin Ferwerda
Which version of GeoServer is this? This line does not seem to match any of
the currently supported versions of GeoServer (2.5.x and 2.4.x)
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ah, that would be because we’re running version 2.1.4…
-Carolin
On Tue, Mar 11, 2014 at 1:09 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Mar 10, 2014 at 8:35 PM, Carolin Ferwerda <cferwerda@anonymised.com> wrote:
Which version of GeoServer is this? This line does not seem to match any of the currently supported versions of GeoServer (2.5.x and 2.4.x)
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Mar 11, 2014 at 7:57 PM, Carolin Ferwerda
Ah, that would be because we're running version 2.1.4...
Ah, pretty old one, I remember it suffered from catalog data structure
corruption when
there were multiple admins, or a single amdin + parallel rest config, doing
changes to the
configuration.
We made a number of fixes to prevent catalog corruption since then, you
should try upgrading
to GeoServer 2.5.0 (which also has some measures to deal with an already
corrupted catalog,
that are yet missing from 2.4.x):
http://geoserver.org/display/GEOS/GeoServer+2.5-RC2
When trying to upgrade make sure you do a backup of the data directory
though, 2.5.x will
add new configuration elements that 2.1.4 won't be able to understand, in
case you want
to go back later.
Ing. Andrea Aime
@geowolf
Technical Lead
We have the option of doing a clean install or upgrading. Would a clean install have a greater likelihood of resolving the problem than upgrading?
Thanks very much for your help, Andrea!
-Carolin
On Wed, Mar 12, 2014 at 7:07 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Mar 11, 2014 at 7:57 PM, Carolin Ferwerda <cferwerda@anonymised.com> wrote:
Ah, pretty old one, I remember it suffered from catalog data structure corruption when
there were multiple admins, or a single amdin + parallel rest config, doing changes to the
configuration.
We made a number of fixes to prevent catalog corruption since then, you should try upgrading
to GeoServer 2.5.0 (which also has some measures to deal with an already corrupted catalog,
When trying to upgrade make sure you do a backup of the data directory though, 2.5.x will
add new configuration elements that 2.1.4 won’t be able to understand, in case you want
to go back later.
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Mar 13, 2014 at 2:57 PM, Carolin Ferwerda
Yes, a clean install should be better if you can afford it
Ing. Andrea Aime
@geowolf
Technical Lead
