[Geoserver-users] Error in Projection: No transform
Hello,
I am having an issue with visualizing a raster dataset using the dataset projection tool. I have added the modis projection definition to my epsg.properties file
http://spatialreference.org/ref/sr-org/6974/html/
68420=PROJCS[“MODIS Sinusoidal”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS 84”,6378137,298.257223563, AUTHORITY[“EPSG”,“7030”]], AUTHORITY[“EPSG”,“6326”]], PRIMEM[“Greenwich”,0, AUTHORITY[“EPSG”,“8901”]], UNIT[“degree”,0.01745329251994328, AUTHORITY[“EPSG”,“9122”]], AUTHORITY[“EPSG”,“4326”]], PROJECTION[“Sinusoidal”], PARAMETER[“false_easting”,0.0], PARAMETER[“false_northing”,0.0], PARAMETER[“central_meridian”,0.0],PARAMETER[“semi_major”,6371007.181], PARAMETER[“semi_minor”,6371007.181], UNIT[“m”,1.0], AUTHORITY[“SR-ORG”,“6974”]]
I restarted geoserver and I can select it from the list and the spatial reference has also been added to my postgresql database table (spatial_ref_sys). I have found my user defined projection (68420) in the web_app and when I choose it I receive this error.
Caused by: java.text.ParseException: Error in “PROJECTION”: No transform for classification “Sinusoidal”.
How/where do I define the Transformation
– previous thread here had no solution
http://sourceforge.net/p/geoserver/mailman/message/22908908/
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
www.terrapop.org
The sinusoidal projection support has been added quite recently in the development series only, it will be available
in the 2.8.0 series to be released September 2015.
If you want to try it now, you can ither download a nightly build here:
http://ares.boundlessgeo.com/geoserver/master/
or try out the now slightly outdated M0 release:
http://blog.geoserver.org/2015/05/29/geoserver-2-8-m0-released/
On Tue, Jul 14, 2015 at 11:13 PM, David Haynes II <dahaynes@anonymised.com851…> wrote:
Hello,
David Haynes, Ph.D.
www.terrapop.org
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
