it is stated that
“A workspace name is a identifier describing your project. It must not exceed ten characters or contain spaces”
I am not sure if in the past this limit was present, but as for 2.x release of GeoServer I have been able to create workspace name longer than 10 characters.
It may not be enforced by the UI, but it is worth keeping the restriction in mind.
I expect the restriction comes from:
a) the XML Schema specification[1]
b) the WMS / WFS / WCS specification
I also noted that you can type illegal characters when naming a Layer resulting in a GetCapabilities document that cannot be parsed. Basically do not view the web administrative (or the REST API) validation as authoritative (or even consistent).
it is stated that
Is your legacy SCM system holding you back? Join Perforce May 7 to find out:
� 3 signs your SCM is hindering your productivity
� Requirements for releasing software faster
� Expert tips and advice for migrating your SCM now http://p.sf.net/sfu/perforce
