I suppose it should be
<gml:posList dimension=“2”>1.1 1.1 2.2 2.2</gml:posList>
-Jukka Rahkonen-
Sondre B. Rabbe wrote:
Thank for the suggestion, Ian. Unfortunately the result remains the same:
10 Mar 12:25:58 INFO [geoserver.filters] - “POST /geoserver/wfs” “Mozilla/5.0 (Windows NT 10.0; WOW64; rv:44.0) Gecko/20100101 Firefox/44.0” “” " “text/xml” request-size: 785 body:
<wfs:Transaction xmlns:wfs=“http://www.opengis.net/wfs” service=“WFS” version=“1.1.0” xsi:schemaLocation=“http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”>
<feature:my-feature xmlns:feature=“http:///kladd”>
<gml:MultiCurve xmlns:gml=“http://www.opengis.net/gml” srsName=“EPSG:32632”>
<gml:posList srsDimension=“2”>564540.06551504 6686293.0582683 564562.99605821 6685986.1417674 565088.63466325 6686063.7528366 565085.10688738 6686335.3915788 564538.3016271 6686291.2943804</gml:posList>
</gml:LineString>
</gml:curveMember>
</gml:MultiCurve>
</feature:the_geom>
</feature: my-feature >
</wfs:Insert>
</wfs:Transaction>
10 Mar 12:25:58 INFO [geoserver.wfs] -
Request: getServiceInfo
10 Mar 12:25:58 INFO [geoserver.gwc] - DataStoreChange: {http:///kladd}my-feature PreInsert
10 Mar 12:25:58 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Error performing insert: Invalid output dimension (must be 2 or 3)
I’ll also include a snipped response from a describeFeatureType request:
<xsd:schema elementFormDefault=“qualified” targetNamespace=“http:///kladd”>
<xsd:import namespace=“http://www.opengis.net/gml” schemaLocation=“http:///geoserver-ext/schemas/gml/3.1.1/base/gml.xsd”/>
<xsd:complexType name=“my-featureType”>
<xsd:extension base=“gml:AbstractFeatureType”>
<xsd:element maxOccurs=“1” minOccurs=“0” name=“the_geom” nillable=“true” type=“gml:GeometryPropertyType”/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name=“my-feature” substitutionGroup=“gml:_Feature” type=“kladd:my-featureType”/>
</xsd:schema>
Best Regards,
Sondre Rabbe
Fra: Ian Turton [mailto:ijturton@…84…]
Sendt: torsdag 10. mars 2016 11:19
Til: Sondre B. Rabbe <sondre.rabbe@…7483…>
Kopi: geoserver-users@lists.sourceforge.net
Emne: Re: [Geoserver-users] Error inserting or updating using WFS
I haven’t got the whole GML spec to hand but I seem to recall that posList requires an attribute srsDimension that says how many coordinates there are to the point. So try something like
In your request and every thing should work.
I can’t recall if it is optional and should default to 2 but I suspect not.
Ian
On 10 March 2016 at 00:29, Sondre B. Rabbe <sondre.rabbe@…7483…> wrote:
Hi list!
We are having a problem inserting or updating our data using WFS and receiving the Exception “Error performing insert: Invalid output dimension (must be 2 or 3)”.
To help the problem solving process I include a brief view of our setup (for what it’s worth):
· CentOS 6.3
· Java version “1.7.0_80”
o Java™ SE Runtime Environment (build 1.7.0_80-b15)
o Java HotSpot™ 64-Bit Server VM (build 24.80-b11, mixed mode)
· Geoserver 2.7.6
· PostgreSQL 9.1.8
· PostGIS library: 1.5.3
· Tomcat 6
When we are trying to POST a transaction (using OpenLayers v2.11), we get the following reponse:
“<ows:ExceptionReport xmlns:xs=“http://www.w3.org/2001/XMLSchema” xmlns:ows=“http://www.opengis.net/ows” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” version=“1.0.0” xsi:schemaLocation=“http://www.opengis.net/ows http://xxx/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd”>
<ows:Exception exceptionCode=“InvalidParameterValue”>
ows:ExceptionTextError performing insert: Invalid output dimension (must be 2 or 3)</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>”
The output from catalina.out:
10 Mar 00:38:11 INFO [geoserver.filters] - “POST /geoserver/wfs” “Mozilla/5.0 (Windows NT 10.0; WOW64; rv:44.0) Gecko/20100101 Firefox/44.0” “” " “text/xml” request-size: 767 body:
wfs:Insert
feature:the_geom
gml:curveMember
gml:LineString
gml:posList564540.06551504 6686293.0582683 564562.99605821 6685986.1417674 565088.63466325 6686063.7528366 565085.10688738 6686335.3915788 564538.3016271 6686291.2943804</gml:posList>
</gml:LineString>
</gml:curveMember>
</gml:MultiCurve>
</feature:the_geom>
</feature:my-feature>
</wfs:Insert>
</wfs:Transaction>10 Mar 00:38:11 INFO [geoserver.wfs] -
10 Mar 00:38:11 INFO [geoserver.gwc] - DataStoreChange: {http:///kladd}my-feature PreInsert
10 Mar 00:38:11 ERROR [geoserver.wfs] - Transaction failed
at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:215)
at org.geoserver.wfs.Transaction.execute(Transaction.java:322)
at org.geoserver.wfs.Transaction.transaction(Transaction.java:106)
at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:171)
at sun.reflect.GeneratedMethodAccessor412.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy54.transaction(Unknown Source)
at sun.reflect.GeneratedMethodAccessor411.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:845)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:83)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.IllegalArgumentException: Invalid output dimension (must be 2 or 3)
at com.vividsolutions.jts.io.WKTWriter.(WKTWriter.java:184)
at org.geotools.data.postgis.PostGISDialect.encodeGeometryValue(PostGISDialect.java:984)
at org.geotools.jdbc.JDBCDataStore.insertSQL(JDBCDataStore.java:3858)
at org.geotools.jdbc.JDBCDataStore.insert(JDBCDataStore.java:1592)
at org.geotools.jdbc.JDBCDataStore.insert(JDBCDataStore.java:1547)
at org.geotools.jdbc.JDBCInsertFeatureWriter.write(JDBCInsertFeatureWriter.java:76)
at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:337)
at org.geotools.data.store.ContentFeatureStore.addFeature(ContentFeatureStore.java:309)
at org.geotools.data.store.ContentFeatureStore.addFeatures(ContentFeatureStore.java:263)
at org.vfny.geoserver.global.GeoServerFeatureStore.addFeatures(GeoServerFeatureStore.java:80)
at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:188)
… 97 more
Request: transaction
service = WFS
version = 1.1.0
baseUrl = http://:8080/geoserver/
group[0] = wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@…7484… (feature: [SimpleFeatureImpl:my-feature=[SimpleFeatureImpl.Attribute: the_geom<the_geom id=fid–22c325f0_1535ac81ba5_-7f14>=MULTILINESTRING ((564540.06551504 6686293.0582683, 564562.99605821 6685986.1417674, 565088.63466325 6686063.7528366, 565085.10688738 6686335.3915788, 564538.3016271 6686291.2943804))]], handle: null, idgen: , inputFormat: , srsName: null)
insert[0]:
feature[0] = SimpleFeatureImpl:my-feature=[SimpleFeatureImpl.Attribute: the_geom<the_geom id=fid–22c325f0_1535ac81ba5_-7f14>=MULTILINESTRING ((564540.06551504 6686293.0582683, 564562.99605821 6685986.1417674, 565088.63466325 6686063.7528366, 565085.10688738 6686335.3915788, 564538.3016271 6686291.2943804))]
idgen = GenerateNew
inputFormat = text/xml; subtype=gml/3.1.1
releaseAction = ALL
10 Mar 00:38:11 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Error performing insert: Invalid output dimension (must be 2 or 3)
at org.geoserver.wfs.response.TransactionResponse.v_1_1(TransactionResponse.java:196)
at org.geoserver.wfs.response.TransactionResponse.write(TransactionResponse.java:66)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:996)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:279)
10 Mar 00:38:11 INFO [geoserver.filters] - “POST /geoserver/wfs” took 28msI have tried to post the same XML using “poster” to rule out the OpenLayers library or our javascripts, but the result is still the same.
When I google the error, I can find one similar situation that is never solved (or the OP never posted the solution…).
Can anyone please assist me on this matter?
Best Regards,
Sondre Rabbe
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785111&iu=/4140
Geoserver-users mailing list
Ian Turton
