[Geoserver-users] Error loading jdbc driver
I get these (might be the same ones before I moved the postgresql-9.3-1101.jdbc41.jar into C:\Program Files\Apache Software Foundation\Tomcat 8.0\lib
Caused by: java.lang.RuntimeException: Unable to obtain connection: Cannot load JDBC driver class 'org.postgresql.driver'
  at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1778)
  at org.geotools.jdbc.JDBCDataStore.createTypeNames(JDBCDataStore.java:905)
  at org.geotools.data.store.ContentDataStore.getTypeNames(ContentDataStore.java:300)
  at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:114)
  at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:547)
  ... 112 more
Caused by: java.sql.SQLException: Cannot load JDBC driver class 'org.postgresql.driver'
  at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createConnectionFactory(BasicDataSource.java:2000)
  at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:1896)
  at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1412)
  at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1764)
  ... 116 more
Caused by: java.lang.ClassNotFoundException: org.postgresql.driver
  at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1333)
  at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1180)
  at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createConnectionFactory(BasicDataSource.java:1991)
  ... 119 more
---- Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Jun 13, 2014 at 5:25 PM, <ebarker111@anonymised.com> wrote:
> Andrea,
> Until now, no, so I did that. I do get a different error in the logs
> (so a step closer):
> 2014-06-13 15:20:52,501 ERROR [geotools.jdbc] - There's code using JDBC
> based datastore and not disposing them. This may lead to temporary loss of
> database connections. Please make sure all data access code calls
> DataStore.dispose() before freeing all references to it
> 2014-06-13 15:20:52,502 ERROR [geotools.jdbc] - There's code using JDBC
Eh, not sure about these. Aren't you getting any other error or stack trace
before? These are normally by-products of some
other issue
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
