To follow up on this for anyone googling later, I couldn’t recreate this on a local VM and when I reinstalled on the original system it went away.
On 30 November 2016 at 11:45, Ian Turton <ijturton@anonymised.com> wrote:
The odd thing is that I don’t have any workspace settings.
I’ll see if I can set up a test server to work out what’s up.
Ian
On 30 November 2016 at 11:27, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Ian,
for the record this one popped up a few times, latest incarnation here:
https://osgeo-org.atlassian.net/browse/GEOS-7253
You might want to check if there is anything related in the issue and its path for your case
Ian Turton
On Wed, Nov 30, 2016 at 12:09 PM, Ian Turton <ijturton@anonymised.com> wrote:
Did you find a fix for this? I’m seeing the same issue with master on a Windows 2012 server, but not on a linux box.
Ian
Geoserver-users mailing list
Geoserver-users@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On 3 November 2016 at 13:50, <romulo.silva@anonymised.com.4913…> wrote:
Hello.
I’m using Geoserver 2.10 with Wildfly 9.0.2 and java 1.8.0_112 and this error appears in the server log:
2016-11-03 10:50:03,739 ERROR [config.impl] - Could not locate service of type interface org.geoserver.wps.WPSInfo, local workspace is null
2016-11-03 10:50:03,748 ERROR [config.impl] - Error occurred processing a configuration change listener
java.lang.NullPointerException
at org.geoserver.wps.WPSInitializer.initWPS(WPSInitializer.java:75)
at org.geoserver.wps.WPSInitializer$1.handlePostGlobalChange(WPSInitializer.java:67)
at org.geoserver.config.impl.GeoServerImpl.fireGlobalPostModified(GeoServerImpl.java:311)
Even with this error all looks fine.
It started when I added WPS extension. I tried to disable the extension but still logging this error.
I searched in this list and the JIRA lists (https://osgeo-org.atlassian.net/browse/GEOS-6510?jql=project%20%3D%20GEOS%20AND%20issuetype%20%3D%20Bug%20AND%20text%20~%20%22org.geoserver.wps.WPSInfo%22) and found some reports about this problem but they were all fixed.
Does anyone know anything about this?
Thank you guys.
Romulo Silva
Programador
SIC - NDS - Núcleo de Desenvolvimento de Software
DÍGITRO TECNOLOGIA
E-mail: romulo.silva@anonymised.com
Fone: +55 48 3281-7000 Ramal: 8146
Fax: +55 48 3281-7299
Site: www.digitro.com
“Antes de imprimir, pense na sua responsabilidade e no seu compromisso com o meio ambiente”
Esta mensagem, incluindo seus anexos, é reservada somente à Dígitro e ao destinatário da mensagem. Caso você tenha recebido esta mensagem por engano, queira por favor, retorná-la ao remetente e apagá-la de seus arquivos.
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today. http://sdm.link/xeonphi
Ian Turton
Ian Turton
