Geoserver 2.2
Win 2008 R2 64bit
Geoserver is running fine, occupying just over 1.2GB of memory, no problems except… every few days it stops responding to WMS requests properly. All requests are affected. The error reported in the log is “Error migrating GWC Tile Layer settings for Layer” which I have googled for but can find no solution. Perhaps oddly after anything between 10 minutes and a couple of hours it will right itself and start serving requests properly again.
What could be causing this problem please? Complete error message listed below.
Tom
2013-01-05 17:05:38,080 WARN [gwc.config] - Error migrating GWC Tile Layer settings for Layer ‘MYLAYER’
java.lang.NullPointerException
at org.geoserver.gwc.layer.LegacyTileLayerInfoLoader.load(LegacyTileLayerInfoLoader.java:76)
at org.geoserver.gwc.config.GWCInitializer.moveTileLayerInfosToTileLayerCatalog(GWCInitializer.java:117)
at org.geoserver.gwc.config.GWCInitializer.initialize(GWCInitializer.java:99)
at org.geoserver.config.GeoServerLoader.loadInitializers(GeoServerLoader.java:154)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:134)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:54)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:394)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1448)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:284)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:385)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:284)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:238)
at java.lang.Thread.run(Unknown Source)
