hi list, i tried to map geoserver metadata to the inspire model, and while doing so got this exception:
javax.xml.transform.TransformerException: java.lang.ClassCastException: org.geoserver.csw.records.GenericRecordBuilder$TreeBranch cannot be cast to org.geoserver.csw.records.GenericRecordBuilder$ComplexTreeLeaf
Someone has an idea what's going on and how to debug this?
I'm using geoserver 2.7-snapshot
My MD_Metadata file looks like this:
@fileIdentifier.CharacterString=id
language.LanguageCode.@anonymised.com='http://www.loc.gov/standards/iso639-2/’
language.LanguageCode.@anonymised.com='dut'
language.LanguageCode='Nederlands'
hierarchyLevel.MD_ScopeCode.@anonymised.com='http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#MD_ScopeCode’
hierarchyLevel.MD_ScopeCode.@anonymised.com='dataset'
contact.CI_ResponsibleParty.individualName.CharacterString='Paul van Genuchten'
contact.CI_ResponsibleParty.organisationName.CharacterString='GeoCat'
contact.CI_ResponsibleParty.contactInfo.CI_Contact.address.CI_Address.electronicMailAddress.CharacterString='info@anonymised.com'
contact.CI_ResponsibleParty.role.CI_RoleCode.@anonymised.com='pointOfContact'
contact.CI_ResponsibleParty.role.CI_RoleCode.@anonymised.com='http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_RoleCode’
dateStamp.Date= if_then_else ( isNull("metadata.date") , '2015-07-22', "metadata.date")
metadataStandardName.CharacterString='ISO19139'
referenceSystemInfo.MD_ReferenceSystem.referenceSystemIdentifier.RS_Identifier.code.CharacterString='28992'
referenceSystemInfo.MD_ReferenceSystem.referenceSystemIdentifier.RS_Identifier.codeSpace.CharacterString='EPSG'
identificationInfo.MD_DataIdentification.citation.CI_Citation.title.CharacterString=if_then_else(isNull(title), name, name)
identificationInfo.MD_DataIdentification.citation.CI_Citation.identifier.MD_Identifier.code.CharacterString=id
identificationInfo.MD_DataIdentification.abstract.CharacterString=abstract
identificationInfo.MD_DataIdentification.pointOfContact.CI_ResponsibleParty.organisationName.CharacterString='Geocat'
identificationInfo.MD_DataIdentification.pointOfContact.CI_ResponsibleParty.contactInfo.CI_Contact.address.CI_Address.electronicMailAddress.CharacterString='info@anonymised.com'
identificationInfo.MD_DataIdentification.pointOfContact.CI_ResponsibleParty.role.CI_RoleCode.@anonymised.com='http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_RoleCode’
identificationInfo.MD_DataIdentification.pointOfContact.CI_ResponsibleParty.role.CI_RoleCode.@anonymised.com='pointOfContact'
identificationInfo.MD_DataIdentification.descriptiveKeywords.MD_Keywords.keyword.CharacterString=keywords
identificationInfo.MD_DataIdentification.resourceConstraints.MD_Constraints.useLimitation.CharacterString='Geen beperkingen'
identificationInfo.MD_DataIdentification.resourceConstraints.MD_LegalConstraints.accessConstraints.MD_RestrictionCode.@anonymised.com='http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_RestrictionCode’
identificationInfo.MD_DataIdentification.resourceConstraints.MD_LegalConstraints.accessConstraints.MD_RestrictionCode.@anonymised.com='otherRestrictions'
identificationInfo.MD_DataIdentification.resourceConstraints.MD_LegalConstraints.otherConstraints.CharacterString='http://creativecommons.org/publicdomain/mark/1.0/deed.nl’
identificationInfo.MD_DataIdentification.spatialRepresentationType.MD_SpatialRepresentationTypeCode.@anonymised.com='vector'
identificationInfo.MD_DataIdentification.spatialRepresentationType.MD_SpatialRepresentationTypeCode.@anonymised.com='http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_SpatialRepresentationTypeCode’
identificationInfo.MD_DataIdentification.spatialResolution.MD_Resolution.equivalentScale.MD_RepresentativeFraction.denominator.Integer='10000'
identificationInfo.MD_DataIdentification.topicCategory.MD_TopicCategoryCode='location'
distributionInfo.MD_Distribution.transferOptions.MD_DigitalTransferOptions.onLine.CI_OnlineResource.linkage.URL=list('${url.wms}')
distributionInfo.MD_Distribution.transferOptions.MD_DigitalTransferOptions.onLine.CI_OnlineResource.protocol.CharacterString=list('OGC:WMS')
distributionInfo.MD_Distribution.transferOptions.MD_DigitalTransferOptions.onLine.CI_OnlineResource.name.CharacterString=name
dataQualityInfo.DQ_DataQuality.scope.DQ_Scope.level.MD_ScopeCode.@anonymised.com='http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#MD_ScopeCode’
dataQualityInfo.DQ_DataQuality.scope.DQ_Scope.level.MD_ScopeCode.@anonymised.com='dataset'
dataQualityInfo.DQ_DataQuality.report.DQ_DomainConsistency.result.DQ_ConformanceResult.specification.CI_Citation.title.CharacterString='VERORDENING (EU) Nr. 1089/2010 VAN DE COMMISSIE van 23 november 2010 ter uitvoering van Richtlijn 2007/2/EG van het Europees Parlement en de Raad betreffende de interoperabiliteit van verzamelingen ruimtelijke gegevens en van diensten met betrekking tot ruimtelijke gegevens'
dataQualityInfo.DQ_DataQuality.report.DQ_DomainConsistency.result.DQ_ConformanceResult.specification.CI_Citation.date.CI_Date.date.Date='2010-12-08'
dataQualityInfo.DQ_DataQuality.report.DQ_DomainConsistency.result.DQ_ConformanceResult.specification.CI_Citation.date.CI_Date.dateType.CI_DateTypeCode.@anonymised.com='http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode’
dataQualityInfo.DQ_DataQuality.report.DQ_DomainConsistency.result.DQ_ConformanceResult.specification.CI_Citation.date.CI_Date.dateType.CI_DateTypeCode.@anonymised.com='publication'
dataQualityInfo.DQ_DataQuality.report.DQ_DomainConsistency.result.DQ_ConformanceResult.pass.Boolean='true'
dataQualityInfo.DQ_DataQuality.lineage.LI_Lineage.statement.CharacterString='op basis van fotogrammetrie'
Another issue with the MD_Metadata file is that the order of the protocol, name and linkage in the onlineresource are ordered alphabetically, in stead of what is defined in configuration, however alphabetical ordering breaks the schema
Thanks for your help, Paul
Hello Paul,
I think there is an error in your mapping file, you are trying to map a value to an incomplete path, i.e. a path that refers to a tag that still has children rather than a value. Is this possible? Nonetheless, I'd say this is still a kind of bug since it should properly report such an mapping error.
Could log this and the other issue on our JIRA? For the other issue, demonstrate with an example of output and desired output. Thanks!
Regards
Niels
Genuchten'
"metadata.date")
name, name)
beperkingen'
Geoserver-users mailing list
Paul,
Could it be you forgot 'CharacterString' in this one:
Niels
