Hi Niels, thanx for looking into this
I'll do some research which of the lines caused the error, then will file an issue in jira, the expected result is here:
http://wiki.geonovum.nl/images/Voorbeeld_Metadata_Dataset_2013.zip
Would indeed be helpfull if the error showed what element failed
Paul,
Could it be you forgot 'CharacterString' in this one:
On 23-07-15 10:56, Niels Charlier wrote:
language.LanguageCode='Nederlands'
Niels
