Folowing up on my previous post:
It turns out that the service always successfully gives 'Error' when returning a python dict object.
Here's how to reproduce:
from geoserver.wps import process
@process(
title='Test WPS',
description='None..',
inputs={
'name': (str,'Name of process')
outputs={
#,'bogus':(str,'Bogus output')
def run(name):
return {'name':name} # succeeds but actually returns 'Error'
#return name #succeeds
#return {'name':name,'bogus':'Hello world'} # fails: Process failed during execution java.lang.IllegalStateException: Process returned 1 values, should have returned 2 Process returned 1 values, should have returned 2
#return name, 'Hello world' #fails: Process failed during execution java.lang.ClassCastException: java.lang.String cannot be cast to org.python.core.PyObject java.lang.String cannot be cast to org.python.core.PyObject
Result of return {'name':name} :
<wps:ExecuteResponsexmlns:wps="http://www.opengis.net/wps/1.0.0"xmlns:ows="http://www.opengis.net/ows/1.1"xmlns:xlink="http://www.w3.org/1999/xlink"xml:lang="en"service="WPS"serviceInstance="http://localhost/geoserver/ows?"version="1\.0\.0">
<wps:Processwps:processVersion="1.0.0">
<ows:Identifier>py:test</ows:Identifier>
<ows:Title>Test WPS</ows:Title>
<ows:Abstract>None..</ows:Abstract>
</wps:Process>
<wps:StatuscreationTime="2013-04-19T08:56:25.508Z">
<wps:ProcessSucceeded>Process succeeded.</wps:ProcessSucceeded>
</wps:Status>
<wps:ProcessOutputs>
<wps:Output>
<ows:Identifier>name</ows:Identifier>
<ows:Title>Name of process</ows:Title>
<wps:Data>
<wps:LiteralData>Error</wps:LiteralData>
</wps:Data>
</wps:Output>
</wps:ProcessOutputs>
</wps:ExecuteResponse>
On 17-4-2013 13:51, Tom van Tilburg wrote:
I'm working on a python WPS script in geoserver. Therefore I use the following manual:
ref: http://docs.geoserver.org/latest/en/user/community/scripting/py/index.html
According to the manual I return my values like:
return {
'mykey1':myvalue1,
'mykey2':myvalye2,
'mykey3':myvalye3
However, this is the error I get:
ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: java.lang.IllegalStateException: Process returned 1 values, should have returned 3
Aside from that, there is a warn on the Responsedocument:
WARN [geoserver.wps] - cvc-complex-type.2.4.b: The content of element 'wps:ResponseDocument' is not complete. One of '{"http://www.opengis.net/wps/1.0.0":Output\}' is expected.
Using only 1 output value it works correctly.
Does anyone have a clue?
Tom
