On Mon, Jul 18, 2016 at 3:09 PM, Annalisa Schiavon <
annalisa.schiavon@anonymised.com> wrote:
Oh, the matter was "se:Title" !!!! I've added that line to the original
sld saved by QGIS. Thank you so much!
Yes the scaled image was not very good ... now I'll try with an svg.
There is a suggested place where to download free svg / png for QGIS and /
or for Geoserver?
Someone told me about a project to share free QGIS styles between users,
maybe there is already something for geoserver?
I'm not aware of a style repository, but I believe you can get a good
result if you take a dedicated image
processing tool (even just IrfanView), that icon, and scale it down to the
desired size using a high quality
filter, like the sinc/lanczos one.
I've taken your example in Gimp, and scaled it down with sync/lanczos and
it was still ugly,
the noticed it was using a color palette, expanded it to RGB, applied the
scaling again, and the
result is better (maybe not great, but it's hard to get a crisp looking
image with just 15 pixels):
I've attached the image to this mail, just in case.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
