I have this code
function init(){
var options = {
projection: new OpenLayers.Projection('EPSG:900913'),
displayProjection: new OpenLayers.Projection('EPSG:4326'),
numZoomLevels: 18,
maxResolution: 'auto',
units: 'degrees',
maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
20037508, 20037508.34)
map = new OpenLayers.Map('mapa', options);
backmap = new OpenLayers.Layer.WMS( "WMS",
"http://labs.metacarta.com/wms/vmap0",
{layers: 'basic'} );
map.addLayer(backmap);
And the geoserver return this error in image
msProcessProjection(); no options found in 'init' file
The problem is the projection EPSG:900913, but i need this projection for
add layer base google.
What can be wrong?
Thank
Regards
Abel
View this message in context: http://www.nabble.com/Error-Projection-EPSG%3A900913-with-WMS-tp23278463p23278463.html
