[Geoserver-users] Error publishing data store as layer
I'm receiving an error publishing a data store a layer. The data store
is a collection of jp2 files using the mosaic plugin. It's a lof files
actually.
The root cause is
org.opengis.referencing.operation.OperationNotFoundException. No
transformation available from system "EngineeringCRS(Wildcard 2D
cartesian plane in metric unit" to "GeographicCRS(WGS84(DD))"
It would super helpful if you all could print more information about
the error condition, such as which file is the problem child or to
skip files that can't be imported.
That said, any idea how to fix this?
Could you check that your files all have their extents sorted (bounds and crs). The “EngineeringCRS” is often used for things like a CAD, where the system cannot determine where they are on the earth without help. This is why we have the ability to provide a spatial reference system in the GeoServer UI - to override raster files that do not provide this information as part of their header.
You can see the internal description here: http://docs.geotools.org/latest/javadocs/org/opengis/referencing/crs/EngineeringCRS.html
On 27 May 2016 at 10:16, Alex O’Ree <spyhunter99@anonymised.com> wrote:
I’m receiving an error publishing a data store a layer. The data store
is a collection of jp2 files using the mosaic plugin. It’s a lof files
actually.
The root cause is
transformation available from system “EngineeringCRS(Wildcard 2D
cartesian plane in metric unit” to “GeographicCRS(WGS84(DD))”
skip files that can’t be imported.
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Jody Garnett
Jody
I literally have a directory of 1000s of jp2 files. Would it be too
much to ask to include the offensive path/to/file in the error
message? It would make troubleshooting sooo much easier.
On Fri, May 27, 2016 at 4:30 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
crs). The "EngineeringCRS" is often used for things like a CAD, where the
Jody Garnett
actually.
The root cause is
traffic
are
