while working with geoserver when i’m making changes in web.xml for cross origin and uncommenting cross origin filters to remove this error as under: Cross-Origin Read Blocking (CORB) blocked cross-origin response with MIME type application/vnd.ogc.se_xml. See for more details. Cross-Origin Read Blocking (CORB) blocked cross-origin response…
i am getting the error as: HTTP ERROR: 503 Problem accessing /geoserver/. Reason: Service Unavailable Powered by Jetty://
and it’s not running the geoserver website.
so both of these things are contradicting. Please resolve the issue if possible attaching the web.xml please make changes in that file and comment where you have made changes so that i get to know what is there that we can do with those types of errors.
Can you please share web.xml changes you have made?
Thank you,
Krishna G. Lodha
Personal email : me@anonymised.com
Office email : krishna@anonymised.com
On 12 Jul 2023 at 19:36 +0530, Ujwal Vohra <ujwalvohra42452@anonymised.com>, wrote:
while working with geoserver when i'm making changes in web.xml for cross origin and uncommenting cross origin filters to remove this error as under:
Cross-Origin Read Blocking (CORB) blocked cross-origin response <URL> with MIME type application/vnd.ogc.se_xml. See <URL> for more details.
Cross-Origin Read Blocking (CORB) blocked cross-origin response........
and it's not running the geoserver website.
Thanks & Regards
Ujwal Singh Vohra
Geoserver-users mailing list
