[Geoserver-users] Error rendering sfdem with GS 2.5 snapshot
Layer preview of the sfdem layer works fine with release version of GS 2.5 on Win-7 and jre7-64 bit (Oracle). With a snapshot version I get always on error " org.geoserver.platform.ServiceException: Error rendering coverage on the fast path". Any idea what could be wrong?
With the snapshot I am getting this after clicking the layer preview link.
Request: getMap
        Time =
        Buffer = 0
        Format = application/openlayers
        Filter = null
        Filters = null
        Width = 512
        Styles = [StyleImpl[ name=dem]]
        Height = 385
        Crs = PROJCS["NAD27 / UTM zone 13N",
  GEOGCS["NAD27",
    DATUM["North American Datum 1927",
      SPHEROID["Clarke 1866", 6378206.4, 294.9786982138982, AUTHORITY["EPSG","7008"]],
      TOWGS84[2.478, 149.752, 197.726, 0.526, -0.498, 0.501, 0.685],
      AUTHORITY["EPSG","6267"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Geodetic longitude", EAST],
    AXIS["Geodetic latitude", NORTH],
    AUTHORITY["EPSG","4267"]],
  PROJECTION["Transverse_Mercator", AUTHORITY["EPSG","9807"]],
  PARAMETER["central_meridian", -105.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["scale_factor", 0.9996],
  PARAMETER["false_easting", 500000.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["Easting", EAST],
  AXIS["Northing", NORTH],
  AUTHORITY["EPSG","26713"]]
        Bbox = SRSEnvelope[589980.0 : 609000.0, 4913700.0 : 4928010.0]
        Env = {}
        Angle = 0.0
        CQLFilter = null
        Elevation =
        FeatureId = null
        BgColor = java.awt.Color[r=255,g=255,b=255]
        Palette = null
        Tiled = false
        MaxFeatures = null
        SRS = EPSG:26713
        FeatureVersion = null
        SldBody = null
        Sld = null
        Transparent = false
        ValidateSchema = false
        SldVersion = null
        TilesOrigin = null
        Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
        RemoteOwsType = null
        RemoteOwsURL = null
        FormatOptions = {}
        StartIndex = null
        ViewParams = null
        Exceptions = SE_XML
        Version = 1.1.0
        Request = GetMap
        RawKvp = {BBOX=589980.0,4913700.0,609000.0,4928010.0, VERSION=1.1.0, FORMAT=application/open
layers, SERVICE=WMS, HEIGHT=385, REQUEST=GetMap, LAYERS=sf:sfdem, STYLES=, WIDTH=512, SRS=EPSG:26713
        Get = true
        BaseUrl = http://localhost:8080/geoserver/
        RequestCharset = UTF-8
15 touko 17:22:25 INFO [geoserver.wms] -
Request: getServiceInfo
15 touko 17:22:25 ERROR [geoserver.ows] -
        at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputForma
t.java:331)
t.java:251)
t.java:123)
        at org.geoserver.wms.GetMap.executeInternal(GetMap.java:509)
        at org.geoserver.wms.GetMap.run(GetMap.java:253)
        at org.geoserver.wms.GetMap.run(GetMap.java:124)
        at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:328)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319
        at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMe
thodInvocation.java:183)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvo
cation.java:150)
        at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
cation.java:172)
        at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
        at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
cation.java:172)
        at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:73)
        at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
cation.java:172)
        at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
cation.java:172)
        at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
        at $Proxy66.getMap(Unknown Source)
        at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
        at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
        at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.j
ava:153)
        at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControlle
rHandlerAdapter.java:48)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
        at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
        at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:2
7)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
        at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:7
4)
        at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
0)
        at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
        at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
        at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChain
Proxy.java:311)
        at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServ
erCompositeFilter.java:68)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(Filter
SecurityInterceptor.java:116)
        at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(Filt
erSecurityInterceptor.java:83)
erCompositeFilter.java:72)
        at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.
java:91)
Proxy.java:323)
        at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTran
slationFilter.java:113)
java:91)
Proxy.java:323)
        at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAn
onymousAuthenticationFilter.java:53)
Proxy.java:323)
        at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(Ba
sicAuthenticationFilter.java:150)
java:91)
        at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicA
uthenticationFilter.java:82)
Proxy.java:323)
        at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(Securi
tyContextPersistenceFilter.java:87)
        at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoSer
verSecurityContextPersistenceFilter.java:52)
java:91)
Proxy.java:323)
        at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
        at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilter
ChainProxy.java:134)
        at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy
.java:346)
        at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:
259)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
        at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
        at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter
.java:109)
        at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
        at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
        at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
        at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
        at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
        at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:2
06)
        at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
        at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
        at org.mortbay.jetty.Server.handle(Server.java:324)
        at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
        at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
        at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
        at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: org.geoserver.platform.ServiceException: java.lang.IndexOutOfBoundsException: Index: 0, S
ize: 0
        at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOut
putFormat.java:898)
t.java:329)
        ... 107 more
Caused by: java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
        at java.util.ArrayList.rangeCheck(Unknown Source)
        at java.util.ArrayList.get(Unknown Source)
        at org.geoserver.catalog.CoverageDimensionCustomizerReader$WrappedSampleDimension.<init>(Cov
erageDimensionCustomizerReader.java:609)
        at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerR
eader.java:215)
eader.java:190)
        at org.geoserver.wms.map.RenderedImageMapOutputFormat.readBestCoverage(RenderedImageMapOutpu
tFormat.java:1296)
putFormat.java:861)
        ... 108 more
-Jukka Rahkonen-
On Thu, May 15, 2014 at 4:33 PM, Rahkonen Jukka (Tike) <
jukka.rahkonen@anonymised.com> wrote:
Sigh, this is a regression against legacy configurations due to the work
done in GEOS-6372, thanks for spotting it
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
