On Tue, Jul 9, 2013 at 1:42 PM, Kolosov Sergey <sergey.kolosof@anonymised.com>wrote:
Kolosov Sergey wrote
> Hi List.
> I have a problem with saving modified feature from OpenLayers. GeoServer
> returns error "A transformation exception occurred while reprojecting
data
> on the fly". Reprojection policy is set to "Reproject native to
declared".
> If i set it to "Keep native", changes are saved without any errors. Is
> there a way to save edited features with server's reprojection?
I've tried different projections and settings on the client without any
success.
To be sure i rechecked this behavior in Quantum GIS. I can see the same
error there.
It seems to be a bug in geoserver reprojecting.
It could be, or the reprojection you're asking for is impossible to make
(projections
have a limited area of validity in which their math makes sense, out of it
they fail).
If you want you can open a bug report at jira.codehaus.org, adding a sample
of
the data you loaded, the configuration of your layer, and the WFS
transaction
you're sending to GeoServer, so that others can reproduce the problem.
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Error-saving-through-WSF-T-tp5061514p5064970.html
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
