[Geoserver-users] Error seeding vector tiles in GeoServer 2.12
Folks,
I have tried building a Docker container with GeoServer 2.12.0, and while the ReST API worked when adding layers, seeding layers with a vector tile format failed with:
com.thoughtworks.xstream.mapper.CannotResolveClassException: seedRequest
(It worked from the UI though.)
I then tried with 2.11.3, where everything worked fine.
Am I missing something?
Environment for all tests:
Linux:
Distributor ID: Debian
Description: Debian GNU/Linux 8.7 (jessie)
Release: 8.7
Codename: jessie
JVM:
openjdk version "1.8.0_131"
OpenJDK Runtime Environment (build 1.8.0_131-8u131-b11-1~bpo8+1-b11)
OpenJDK 64-Bit Server VM (build 25.131-b11, mixed mode)
Tomcat:
8.0
Luca Morandini
Data Architect - AURIN project
Melbourne eResearch Group
Department of Computing and Information Systems
University of Melbourne
Room 3.32, Level 3, 333 Exhibition St.
Melbourne, 3000 VIC
Tel. +61 03 903 58 380
Skype: lmorandini
LinkedIn: https://www.linkedin.com/in/lmorandini
Ciao Luca,
two questions:
  • Is it really limited to vector tiles only? Could you try seeding pngs?
  • There was a thread on devel about releasing 2.12.0 with a known GWC REST API regression and devs involved claimed it was solved later (so it should be solved in the nightly). Could you try a nightly build here? https://build.geoserver.org/geoserver/2.12.x/
On Wed, Nov 15, 2017 at 7:11 AM, Luca Morandini <lmorandini@anonymised.com> wrote:
Folks,
Linux:
Release: 8.7
Codename: jessie
JVM:
openjdk version “1.8.0_131”
Tomcat:
8.0
Luca Morandini
Melbourne, 3000 VIC
Skype: lmorandini
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.comrge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On 15/11/17 19:41, Andrea Aime wrote:
Ciao Luca,
two questions:
  * Is it really limited to vector tiles only? Could you try seeding pngs?
Same issue with raster tiles.
  * There was a thread on devel about releasing 2.12.0 with a known GWC REST API
No joy:
[2017-11-15 23:00:10.710Z] ERROR [geoserver.rest] - seedRequest
         at com.thoughtworks.xstream.mapper.DefaultMapper.realClass(DefaultMapper.java:81)
         at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:125)
Luca Morandini
Melbourne, 3000 VIC
Skype: lmorandini
we already discussed this problem in October under the subject 'REST API, User endpoints' but I didn't have the time to investigate further and/or file a bug...
See also https://sourceforge.net/p/geoserver/mailman/geoserver-users/?viewmonth=201710&limit=250&viewday=19#msg36082856 for more information.
Daniel Calliess
-----Original Message-----
From: Luca Morandini [mailto:lmorandini@anonymised.com]
Sent: Thursday, November 16, 2017 12:07 AM
Subject: Re: [Geoserver-users] Error seeding vector tiles in GeoServer 2.12
Ciao Luca,
two questions:
No joy:
         at
         at
Luca Morandini
Melbourne, 3000 VIC
Skype: lmorandini
Check out the vibrant tech community on one of the world's most
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
Hi David and Torben,
I thought these REST api migration issues (regressions in 2.12.x) were already solved by
a recent commit of yours, but looks like they have not been?
Any chance a fix can land before the 2.12.1 release next week?
On Fri, Nov 17, 2017 at 1:18 PM, Calliess Daniel Ing. <Daniel.Calliess@anonymised.com> wrote:
we already discussed this problem in October under the subject ‘REST API, User endpoints’ but I didn’t have the time to investigate further and/or file a bug…
Daniel Calliess
To: geoserver-users@anonymised.comsourceforge.net
Ciao Luca,
two questions:
No joy:
at
at
Luca Morandini
Melbourne, 3000 VIC
Skype: lmorandini
Geoserver-users@anonymised.com.382…sourceforge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
I had thought so as well.
PR for the seeding fix is here: https://github.com/GeoWebCache/geowebcache/pull/544 and was merged (and backported) a few weeks ago.
Looking at the associated bug reports, they describe slightly different errors (blank page, or HTTP 400 error) than the above. Searching JIRA, I don’t see any issues that match the above report, so this might be a new/different issue. I’ll see if I can reproduce.
Torben
On Fri, Nov 17, 2017 at 5:44 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Nov 17, 2017 at 1:18 PM, Calliess Daniel Ing. <Daniel.Calliess@anonymised.com.8567…salzburg.at> wrote:
Daniel Calliess
To: geoserver-users@anonymised.comrge.net
Ciao Luca,
two questions:
No joy:
at
at
Luca Morandini
Melbourne, 3000 VIC
Skype: lmorandini
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Reproduced the issue, JIRA ticket here: https://osgeo-org.atlassian.net/browse/GEOS-8401
Looks like this only affects embedded GWC. I have a fix, and have gotten hung up a bit on test cases, as GWC doesn’t seem to have any test cases at all for the seed endpoint. Hope to have a fix in before the release Monday.
Torben
On Fri, Nov 17, 2017 at 9:15 AM, Torben Barsballe <tbarsballe@anonymised.com.> wrote:
Torben
On Fri, Nov 17, 2017 at 5:44 AM, Andrea Aime <andrea.aime@anonymised.com…> wrote:
On Fri, Nov 17, 2017 at 1:18 PM, Calliess Daniel Ing. <Daniel.Calliess@anonymised.comg.at> wrote:
Daniel Calliess
Ciao Luca,
two questions:
No joy:
at
at
Luca Morandini
Melbourne, 3000 VIC
Skype: lmorandini
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Nov 18, 2017 at 1:50 AM, Torben Barsballe <
hung up a bit on test cases, as GWC doesn't seem to have any test cases at
That would be awesome, thank you!
Ing. Andrea Aime
@geowolf
Technical Lead
