[Geoserver-users] Error starting geoserver
Hello list,
I’ve installed GeoServer 1.7.2 and when starting I get the following errors.
25 may 14:54:03 INFO [geoserver.catalog] - Loaded feature type ‘topp:tasmania_roads’
25 may 14:54:03 INFO [geoserver.catalog] - Loaded feature type ‘topp:tasmania_state_boundaries’
25 may 14:54:03 INFO [geoserver.catalog] - Loaded feature type ‘topp:tasmania_water_bodies’
25 may 14:54:04 WARN [referencing.factory] - Unavailable authority factory “European Petroleum Survey Group”.
25 may 14:54:04 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295]], PROJECTION[“Merca
tor_1SP_Google”], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”,
1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
25 may 14:54:04 WARN [geoserver.catalog] - Error loading ‘arcGridSample_Arc_Sample/info.xml’, ignoring
25 may 14:54:04 INFO [geoserver.catalog] -
org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:4326” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:314)
at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:388)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:420)
at org.geoserver.catalog.util.LegacyCatalogImporter.readCoverage(LegacyCatalogImporter.java:562)
at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:221)
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:112)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:76)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
The last one “Error loading 'arcGridSample_Arc_Sample/info.xml” is repeated for all other .xml files (arc_sample/info.xml,img_sample/info.xml,img_sample2_Pk50095/info.xml, etc…). and also “http://localhost:8080/geoserver/welcome.do” don’t works. I have no idea what happens.
Hi José,
A couple of questions:
* what platform are you running on?
* are you running standalone or in a servlet container?
* is this an upgrade?
I have seen this issue before while upgrading. One thing to try is to remove the "GeoTools" directory which should be in your temporary folder. On *nix platforms this will be under /tmp or something, under windows in the Local Settings/Temp directory under your users home directory.
Try deleting that file and starting geoserver again.
-Justin
José Carrizo wrote:
Hello list,
I've installed GeoServer 1.7.2 and when starting I get the following errors.
25 may 14:54:03 INFO [geoserver.catalog] - Loaded feature type 'topp:tasmania_roads'
25 may 14:54:03 INFO [geoserver.catalog] - Loaded feature type 'topp:tasmania_state_boundaries'
25 may 14:54:03 INFO [geoserver.catalog] - Loaded feature type 'topp:tasmania_water_bodies'
25 may 14:54:04 WARN [referencing.factory] - Unavailable authority fac/tory/ "European Petroleum Survey Group".
25 may 14:54:04 WARN [referencing.factory] - Unavailable authority factory "European Petroleum Survey Group".
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295]], PROJECTION["Merca
tor_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m",
1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
25 may 14:54:04 WARN [geoserver.catalog] - Error loading 'arcGridSample_Arc_Sample/info.xml', ignoring
org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:4326" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
The last one "Error loading 'arcGridSample_Arc_Sample/info.xml" is repeated for all other .xml files (arc_sample/info.xml,img_sample/info.xml,img_sample2_Pk50095/info.xml, etc...). and also "http://localhost:8080/geoserver/welcome.do" don't works. I have no idea what happens.
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals. Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, & iPhoneDevCamp asthey present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://www.creativitycat.com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
If you are using tomcat I would also clean up the work and tmp dir for
it, after you have stopped it, of course.
Simone.
On Mon, May 25, 2009 at 10:39 PM, Justin Deoliveira
<jdeolive@anonymised.com> wrote:
Hi José,
directory.
-Justin
José Carrizo wrote:
Hello list,
respected:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
etc...). and also "http://localhost:8080/geoserver/welcome.do&quot; don't
Justin Deoliveira
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
Thanks for your answer Simone, actually i have solved it deleting temp folder from local settings directory. I’m working with a clean installation that runs (i think) with Jetty.
I’ll put here my response to Justin because I forget copy it on CC:
It works!
  • what platform are you running on?
Windows XP SP3
  • are you running standalone or in a servlet container?
standalone
  • is this an upgrade?
    No, but actually i’ve changed my jdk version before getting this errors and didn’t mention it because after that I’ve trying and trying getting my jdk version back, reinstalling geoserver and nothing works.
thank you so much Justin! It works now!
Greets!
2009/5/25 Simone Giannecchini <simone.giannecchini@anonymised.com>
Simone.
Hi José,
remove the “GeoTools” directory which should be in your temporary
directory.
-Justin
José Carrizo wrote:
Hello list,
fac/tory/ “European Petroleum Survey Group”.
respected:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Justin Deoliveira
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
