[Geoserver-users] Error using function Interpolate in COLOR mode from SLD
Hi there,
I’ve updated one of our GeoServes from version 2.22.2 to latest stable 2.25.1. When requesting SLD-styled maps via WMS I’m getting this OWS exception:
Error rendering layer mga.bl: Trying to evaluate the function as Object but the method parameter is set as COLOR
I guess, it’s about the Interpolate function, which we use to vary line colors depending on wms_scale_denominator:
wms_scale_denominator 2132 #202020 17471320 #404040 color
There’s no longer any error after removing that function from SLDs.
The styles have not been changed. These used to work well with the 2.22.2 version.
I haven’t found any breaking changes in the documentation for filter function Interpolate. Actually, my SLD seems quite identical to what the documentation shows:
https://docs.geoserver.org/main/en/user/styling/sld/tipstricks/transformation-func.html#id2
Any help and ideas are very appreciated.
Carsten
H there x 2,
That is quite a puzzle.
It may be a case of:
  1. Trying to reproduce the error with the standard data directory and making a bug report
  2. Trying the different version between 2.22.2 and 2.25.1 to see when it breaks (and then we could learn more)
    If doing this approach it is best to bisect debugging approach: take a version in the middle, and then you know to test higher or lower. Take in the middle of the new range etc…
Jody Garnett
Hi Jody,
why a puzzle? I’ve just checked this: The error is reproducible with the latest GeoServer main branch, by simply adding an Interpolate filter function in color mode to one of the standard SLD styles (e.g. simple_roads) in standard data directory.
Making CSSParameter stroke depend on wms_scale_denominator:
#AA3333 wms_scale_denominator 2132 #AA3333 17471320 #AA9999 color 2
leads to exception:
Caused by: java.lang.IllegalArgumentException: Trying to evaluate the function as Object but the method parameter is set as COLOR
at org.geotools.filter.function.InterpolateFunction.evaluate(InterpolateFunction.java:323)
at org.geotools.filter.function.InterpolateFunction.evaluate(InterpolateFunction.java:301)
at org.geotools.filter.visitor.SimplifyingFilterVisitor.visit(SimplifyingFilterVisitor.java:484)
at org.geotools.filter.function.InterpolateFunction.accept(InterpolateFunction.java:296)
at org.geotools.styling.visitor.DuplicatingStyleVisitor.copy(DuplicatingStyleVisitor.java:379)
at org.geotools.styling.visitor.DuplicatingStyleVisitor.visit(DuplicatingStyleVisitor.java:655)
at org.geotools.styling.StrokeImpl.accept(StrokeImpl.java:420)
thrown here:
https://github.com/geotools/geotools/blob/f0c9961dc4d40c5acfce2169fab92805738de5ea/modules/library/main/src/main/java/org/geotools/filter/function/InterpolateFunction.java#L320
Seems like Class context does not implement Color It works fine if method is “numeric” (in contrast to “color”).
Carsten
Am 10.06.2024 um 20:55 schrieb Jody Garnett:
H there x 2,
Jody Garnett
On Jun 9, 2024 at 11:59:07 PM, Carsten Klein <c.klein@anonymised.com> wrote:
Hi there,
Carsten
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
It is more that I am not aware of any change that could cause this regression.
Were you able to determine when the problem was introduced and report the issue to the issue tracker?
I am curious to what you will find. Determing which release the problem started in will help a great deal.
Jody Garnett
Jody Garnett
There isn’t enough of the stack trace provided but this commit is a possible source of the regression (GeoServer 2.23.3+): https://github.com/geotools/geotools/commit/d7991fdcd1630ea1c18b5dfad91d4e291b8bb95b
Steve Ikeoka
Sent: Monday, June 17, 2024 10:17 AM
To: Carsten Klein <c.klein@…5805…>
Cc: GeoServer Mailing List List geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Error using function Interpolate in COLOR mode from SLD
It is more that I am not aware of any change that could cause this regression. Were you able to determine when the problem was introduced and report the issue to the issue tracker? I am curious to what you will find. Determing which release
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
Please use caution with links, attachments, and any requests for credentials.
ZjQcmQRYFpfptBannerEnd
Jody Garnett
On Jun 13, 2024 at 8:07:09 AM, Carsten Klein <c.klein@…5805…> wrote:
Hi Jody,
leads to exception:
thrown here:
Carsten
H there x 2,
Jody Garnett
On Jun 9, 2024 at 11:59:07 PM, Carsten Klein <c.klein@…5805…> wrote:
Hi there,
Carsten
I had a look at this error and can confirm that it’s a legit error with the main branch. So an Issue in Jira would be welcomed.
Carsten provided two different sld. Here is the one I’ve been using:
And here is a full stack trace:
18 007 08:07:53 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Rendering process failed. Layers: tasmania_roads
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:593)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:205)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:1)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:347)
at org.geoserver.wms.GetMap.run(GetMap.java:204)
at org.geoserver.wms.GetMap.run(GetMap.java:114)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:250)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:344)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:198)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:38)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:57)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:1)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:74)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:1)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:29)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:241)
at com.sun.proxy.$Proxy88.getMap(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:905)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:269)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:51)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1072)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:965)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1459)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1656)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:193)
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1626)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:73)
at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.HTTPMethodFilter.doFilter(HTTPMethodFilter.java:36)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:194)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:43)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:337)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:115)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:81)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:346)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:122)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:116)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:164)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:117)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilterInternal(GeoServerSecurityContextPersistenceFilter.java:72)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:221)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:186)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:141)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:116)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:552)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:505)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
at java.base/java.lang.Thread.run(Thread.java:829)
at org.geotools.filter.function.InterpolateFunction.evaluate(InterpolateFunction.java:321)
at org.geotools.styling.visitor.DuplicatingStyleVisitor.copy(DuplicatingStyleVisitor.java:442)
at org.geotools.styling.visitor.DuplicatingStyleVisitor.visit(DuplicatingStyleVisitor.java:713)
at org.geotools.styling.LineSymbolizerImpl.accept(LineSymbolizerImpl.java:103)
at org.geotools.styling.visitor.DuplicatingStyleVisitor.copy(DuplicatingStyleVisitor.java:504)
at org.geotools.styling.visitor.DuplicatingStyleVisitor.lambda$0(DuplicatingStyleVisitor.java:283)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1655)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:913)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578)
at org.geotools.styling.visitor.DuplicatingStyleVisitor.visit(DuplicatingStyleVisitor.java:285)
at org.geotools.styling.RuleImpl.accept(RuleImpl.java:223)
at org.geotools.renderer.lite.SimplifyingStyleVisitor.lambda$1(SimplifyingStyleVisitor.java:72)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:177)
at org.geotools.renderer.lite.SimplifyingStyleVisitor.visit(SimplifyingStyleVisitor.java:76)
at org.geotools.styling.FeatureTypeStyleImpl.accept(FeatureTypeStyleImpl.java:142)
at org.geotools.renderer.lite.StreamingRenderer.createLiteFeatureTypeStyles(StreamingRenderer.java:2015)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2251)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:918)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:546)
… 141 more
To: Carsten Klein <c.klein@anonymised.com>
Cc: GeoServer Mailing List List <geoserver-users@anonymised.comists.sourceforge.net>
Jody Garnett
On Jun 13, 2024 at 8:07:09 AM, Carsten Klein <c.klein@anonymised.com> wrote:
Hi Jody,
#AA3333 wms_scale_denominator 2132 #AA3333 17471320 #AA9999 color 2 leads to exception: [...] Caused by: java.lang.IllegalArgumentException: Trying to evaluate the function as Object but the method parameter is set as COLOR at org.geotools.filter.function.InterpolateFunction.evaluate(InterpolateFunction.java:323) at org.geotools.filter.function.InterpolateFunction.evaluate(InterpolateFunction.java:301) at org.geotools.filter.visitor.SimplifyingFilterVisitor.visit(SimplifyingFilterVisitor.java:484) at org.geotools.filter.function.InterpolateFunction.accept(InterpolateFunction.java:296) at org.geotools.styling.visitor.DuplicatingStyleVisitor.copy(DuplicatingStyleVisitor.java:379) at org.geotools.styling.visitor.DuplicatingStyleVisitor.visit(DuplicatingStyleVisitor.java:655) at org.geotools.styling.StrokeImpl.accept(StrokeImpl.java:420) [....] thrown here: [https://github.com/geotools/geotools/blob/f0c9961dc4d40c5acfce2169fab92805738de5ea/modules/library/main/src/main/java/org/geotools/filter/function/InterpolateFunction.java#L320](https://urldefense.us/v3/__https://github.com/geotools/geotools/blob/f0c9961dc4d40c5acfce2169fab92805738de5ea/modules/library/main/src/main/java/org/geotools/filter/function/InterpolateFunction.java*L320__;Iw!!JRQnnSFuzw7wjAKq6ti6!xut7MRht1ecLGteZ1aKGg5roShoUSjG5tqvW0u3NMBIcQXEZEhSwHmbskJ-MFnqjKx-G314NqB5naHhV1L1EZOg$) Seems like *Class context* does not implement *Color* It works fine if method is "numeric" (in contrast to "color"). Carsten
H there x 2,
Jody Garnett
Hi there,
Carsten
Hello there,
I exactly have the same issue: has someone already created a JIRA ticket? I haven’t found one so I would like to confirm the fact before creating one.
Regards
Alexandre
Hello Alexandre,
I haven’t yet created a JIRA ticket as I’m quite busy at the moment. Also, due to lack of time, I wasn’t able to track down the exact version which first introduced this issue.
Regards
Carsten
Am 21.06.2024 um 14:40 schrieb Alexandre Gacon:
Hello there,
Regards
Alexandre
Hi Steve,
yes, that commit is involved, as it triggers a bug in the function implementation.
A function must not rely on the context object being set, the context is provided only so that the function can try to covert
its result towards it. Passing in “null” or “object” means “do what you want, we’re not asking for a particular type of output”,
but the current implementation throws an exception instead. Looks like the error predates the git history (14+ years)
In any case, that needs to be fixed.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
I initiated the ticket https://osgeo-org.atlassian.net/browse/GEOT-7607.
Regards
Alexandre
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Alexandre Gacon
Gabriel Roldan is taking care of it.
Alexandre
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Alexandre Gacon
Alexandre Gacon
Hi, I’ll give it a shot.
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Gabriel Roldán
Geospatial Developer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Alexandre Gacon
Moving the discussion to the devel list.
Please check the following pull request: https://github.com/geotools/geotools/pull/4819
camptocamp
Gabriel Roldán
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Alexandre Gacon
Alexandre Gacon
