[Geoserver-users] Error Using the Pregeneralized Features module on Geoserver
Hello,
I am trying to use the pregeneralized features extension for limiting the
number of vertices drawn for a large dataset that resides in PostGIS
(geometry type 'MultiLineString'). I've been through the tutorials and the
help forums and adjusted my .xml config file in many different ways
according to all the info I've found. I have also set up my Generalizing
Data Store on geoserver in the exact manner that was specified in this
tutorial:
http://osgeo-org.1560.x6.nabble.com/attachment/3819796/0/pregen_tutorial.html
<http://osgeo-org.1560.x6.nabble.com/attachment/3819796/0/pregen_tutorial.html&gt;
After zooming and panning around in OpenLayers, I am still receiving the
following message in the geoserver logs:
"2014-10-08 10:00:10,973 WARN [org.geotools.data.gen] - No hint for geometry
distance in query, fallback to base feature"
From my understanding, this means that something in the config file is not
right and geoserver is defaulting to the base "the_geom" column for
rendering the pipelines.
Here is my .xml file:
<GeneralizationInfos version="1.0">
  <GeneralizationInfo dataSourceNameSpace="pipelines_pregen"
dataSourceName="pipelines"
featureName="pipelines_general_tx_1"
baseFeatureName="domestic_pipelines_tx_1" geomPropertyName="the_geom">
    <Generalization distance="5000" featureName="domestic_pipelines_tx_1"
geomPropertyName="the_geom5000"/>
  </GeneralizationInfo>
</GeneralizationInfos>
I've checked and all the parameters are populated correctly in the xml file
according to the guidelines laid out in this thread:
http://osgeo-org.1560.x6.nabble.com/New-postgis-feature-pregeneralized-tutorial-question-tp3797025p3797026.html
<http://osgeo-org.1560.x6.nabble.com/New-postgis-feature-pregeneralized-tutorial-question-tp3797025p3797026.html&gt;
Does anybody know of any reasons why this would be failing to generalize my
features? Any help would be greatly appreciated!
Thanks!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-Using-the-Pregeneralized-Features-module-on-Geoserver-tp5166527.html
Hi Joel
No, this is not an error in your configuration.
The renderer component does not pass a proper hint to the Data Source, the result is the log message
“No hint for geometry distance in query, fallback to base feature”
and the original geometry is used.
@Andrea
I think this a regression. The problem is here
org.geotools.data.gen.PreGeneralizedFeatureSource.getRequestedDistance(Query)
Should Joel Open a JIRA issue.
Christian
On Wed, Oct 8, 2014 at 6:00 PM, joel.schmitt <joel.schmitt@anonymised.com> wrote:
Hello,
(geometry type ‘MultiLineString’). I’ve been through the tutorials and the
according to all the info I’ve found. I have also set up my Generalizing
tutorial:
<http://osgeo-org.1560.x6.nabble.com/attachment/3819796/0/pregen_tutorial.html>
“2014-10-08 10:00:10,973 WARN [org.geotools.data.gen] - No hint for geometry
right and geoserver is defaulting to the base “the_geom” column for
I’ve checked and all the parameters are populated correctly in the xml file
<http://osgeo-org.1560.x6.nabble.com/New-postgis-feature-pregeneralized-tutorial-question-tp3797025p3797026.html>
Thanks!
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Christian-- Thank you for responding to my issue. I'm assuming Andrea is an
admin for this forum as I've seen her in plenty of other threads giving very
helpful, Geoserver-specific advice.
Do you think I should go ahead and open a JIRA issue?
Thanks again,
Joel
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-Using-the-Pregeneralized-Features-module-on-Geoserver-tp5166527p5167240.html
On Mon, Oct 13, 2014 at 4:13 PM, joel.schmitt <joel.schmitt@anonymised.com
very
That would be a "him" :-p
Please do open
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
