[Geoserver-users] error when creating FeatureType for SQL Server 2008 datastore
I got exception when creating FeatureType for a SQL Server datastore. My environment is Windows 2003 Server with sp2, SQL Server 2008 ent edition.
I did followings
  1. Download and installed geoserver 1.7.3
  2. download sql server extension and copy gt-jdbc-core-2.5.4.jar, gt-jdbc-core-2.5.4-tests.jar, gt-jdbc-sqlserver-2.5.4.jar to
c:\Program Files\GeoServer 1.7.3\webapps\geoserver\WEB-INF\lib
  1. download Microsoft SQL Server 2005 Driver 1.2 and copy sqljdbc.jar to the same directory as above
  2. download GIS data st99_d00.shp and other files
  3. import the shape data to a database in PostGre server with table name us_states by PostGIS tool
  4. import the shape data to a database in SQL Server 2008 server with table name us_states by a downloaded tool Shape2Sql.exe
  5. create a datastore for the PostGre database
  6. create a datastore for the SQL Server database (I can see the datastore created with its name plus table name when creating FeatureType)
  7. create FeatureType for the PostGre datastore
select Polygon for Styles, enter 4326 for SRS, then click button Generate. It populated values for Long, Lat. Then click Submit, Apply, Save buttons.
  1. Create FeatureType for the SQL Server datastore
I did samething as 9., but when clicking button Generate, it shown error message
GeoServer - Exception
The following exception was thrown:
class java.lang.RuntimeException: java.io.IOException
class java.io.IOException:
class org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:0” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
Details:
at org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:439)
at org.geotools.jdbc.JDBCFeatureStore.getBoundsInternal(JDBCFeatureStore.java:141)
at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:357)
at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:329)
at org.geoserver.feature.FeatureSourceUtils.getBoundingBoxEnvelope(FeatureSourceUtils.java:44)
at org.vfny.geoserver.util.DataStoreUtils.getBoundingBoxEnvelope(DataStoreUtils.java:318)
at org.vfny.geoserver.action.data.TypesEditorAction.executeBBox(TypesEditorAction.java:236)
at org.vfny.geoserver.action.data.TypesEditorAction.execute(TypesEditorAction.java:138)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.io.IOException
at org.geotools.data.sqlserver.SQLServerDialect.decodeGeometry(SQLServerDialect.java:188)
at org.geotools.data.sqlserver.SQLServerDialect.decodeGeometryEnvelope(SQLServerDialect.java:212)
at org.geotools.jdbc.JDBCDataStore.getBounds(JDBCDataStore.java:850)
at org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:432)
… 61 more
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code “EPSG:0” from authority “European Petroleum Survey Group” found for object of type “IdentifiedObject”.
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:314)
at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:388)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:420)
at org.geotools.referencing.CRS.decode(CRS.java:348)
at org.geotools.data.sqlserver.SQLServerDialect.decodeGeometry(SQLServerDialect.java:185)
… 64 more
Thanks
Keith
