Hello group!
i am using geoserver 2.8.3 on Tomcat 7.0.42 with this JVM:
java version “1.7.0_99”
OpenJDK Runtime Environment (IcedTea 2.6.5) (suse-24.33.2-x86_64)
OpenJDK 64-Bit Server VM (build 24.95-b01, mixed mode)
What i did: I was playing around with the postgis rasterdata tutorial. While importing the data some error occured which solved wit symlinking some libs from the geoserver lib-dir into the jre-lib/ext directory. After this the import worked. After this i tried to create a datastore on the raster which didnt work. But while trying it must have destroyed something in the data structure, becaus after that i could not create new datastores or layers and the below attached error shows up.
I found some posts on this list which say, that this has to do with errors in the definition of datastores or workspace etc. So my question is, how do i find and the wrong entries and get rid of them? Or has this some other issues?
I tried to delete every single workspace one by one until nothing left with no effort. Deleting the files for the rasterlayer id not help.I updated geoserver from 2.8.0 to 2.8.3, but this did not help. A empty installation works fine, but i dont want to reconfigure everything. Single datastores can be opened by clicking on the name in the layerlist.
Thank you in advance for any hints and help
Uwe Seher
2016-04-19 14:50:04,183 ERROR [wicket.RequestCycle] - Error attaching this container for rendering: [MarkupContainer [Component id = 6]]
org.apache.wicket.WicketRuntimeException: Error attaching this container for rendering: [MarkupContainer [Component id = 6]]
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1765)
at org.apache.wicket.Component.onBeforeRender(Component.java:3946)
at org.apache.wicket.Component.internalBeforeRender(Component.java:1071)
at org.apache.wicket.Component.beforeRender(Component.java:1105)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:151)
at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:121)
at org.apache.wicket.Page.onBeforeRender(Page.java:1531)
at org.apache.wicket.Component.prepareForRender(Component.java:2292)
at org.apache.wicket.Page.prepareForRender(Page.java:1521)
at org.apache.wicket.Component.prepareForRender(Component.java:2329)
at org.apache.wicket.Page.renderPage(Page.java:892)
at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:261)
at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1852)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.NullPointerException
at com.sun.proxy.$Proxy125.equals(Unknown Source)
at org.geoserver.catalog.impl.DefaultCatalogFacade.getStoreByName(DefaultCatalogFacade.java:181)
at org.geoserver.catalog.impl.CatalogImpl.getStoreByName(CatalogImpl.java:248)
at org.geoserver.catalog.impl.CatalogImpl.getStoreByName(CatalogImpl.java:260)
at org.geoserver.security.SecureCatalogImpl.getStoreByName(SecureCatalogImpl.java:431)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.getStoreByName(AbstractFilteredCatalog.java:345)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.getStoreByName(AbstractCatalogDecorator.java:110)
at org.geoserver.web.data.store.StorePanel.storeNameLink(StorePanel.java:101)
at org.geoserver.web.data.store.StorePanel.getComponentForProperty(StorePanel.java:81)
at org.geoserver.web.wicket.GeoServerTablePanel$4.populateItem(GeoServerTablePanel.java:212)
at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:562)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:131)
… 126 more
