I am using GeoServer 2.5.1 with Monitoring extension.
The machine is a Windows XP, sic
, with Java 6 and Tomcat 7.
I configured the storage to hibernate and PostgreSQL.
I checked that monitoring data are properly written in the request and request_resoruces data and reports from the Monitor>Reports section of the GeoServer interface work just fine.
If I try to use the monitoring HTTP API with this simple request:
http://localhost:8080/geoserver/rest/monitor/requests.html
I get this as output:
:2
I checked the log and there is an error (enclosed below).
Am I missing something or this could be a bug?
Thank you for any hint
Stefano
2014-06-27 10:34:13,031 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: ‘/rest/monitor/requests.html’; to: ‘/rest/monitor/requests.html’ and httpMethod= GET
2014-06-27 10:34:13,031 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2014-06-27 10:34:13,031 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/monitor/requests.html’; antPath is /**; matchedPath=true; matchedMethods=true
2014-06-27 10:34:13,031 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
2014-06-27 10:34:13,031 DEBUG [org.geoserver.monitor] - Testing /rest/monitor/requests.html for monitor filtering
2014-06-27 10:34:13,031 DEBUG [org.geoserver.monitor] - /geoserver/rest/monitor/requests.html was filtered from monitoring
2014-06-27 10:34:13,031 DEBUG [org.geoserver.monitor.OpenSessionInViewFilter] - Using SessionFactory ‘hibSessionFactory’ for OpenSessionInViewFilter
2014-06-27 10:34:13,031 DEBUG [org.geoserver.monitor.OpenSessionInViewFilter] - Opening single Hibernate Session in OpenSessionInViewFilter
2014-06-27 10:34:13,031 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/monitor/requests.html]
2014-06-27 10:34:13,078 ERROR [org.geoserver.rest] - :2
2014-06-27 10:34:13,078 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/plain
org.geoserver.rest.RestletException: java.lang.ArrayIndexOutOfBoundsException: 2
at org.geoserver.rest.ReflectiveResource.handleException(ReflectiveResource.java:325)
at org.geoserver.rest.ReflectiveResource.handleGet(ReflectiveResource.java:91)
at org.restlet.Finder.handle(Finder.java:292)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.springframework.orm.hibernate3.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:198)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:88)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:92)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 2
at org.postgresql.util.PGbytea.toBytes(PGbytea.java:76)
at org.postgresql.jdbc2.AbstractJdbc2ResultSet.getBytes(AbstractJdbc2ResultSet.java:2271)
at org.postgresql.jdbc2.AbstractJdbc2ResultSet.getBytes(AbstractJdbc2ResultSet.java:2451)
at org.apache.commons.dbcp.DelegatingResultSet.getBytes(DelegatingResultSet.java:291)
at org.hibernate.type.AbstractBynaryType.get(AbstractBynaryType.java:78)
at org.hibernate.type.NullableType.nullSafeGet(NullableType.java:163)
at org.hibernate.type.NullableType.nullSafeGet(NullableType.java:154)
at org.hibernate.type.AbstractType.hydrate(AbstractType.java:81)
at org.hibernate.persister.entity.AbstractEntityPersister.hydrate(AbstractEntityPersister.java:2101)
at org.hibernate.loader.Loader.loadFromResultSet(Loader.java:1380)
at org.hibernate.loader.Loader.instanceNotYetLoaded(Loader.java:1308)
at org.hibernate.loader.Loader.getRow(Loader.java:1206)
at org.hibernate.loader.Loader.getRowFromResultSet(Loader.java:580)
at org.hibernate.loader.Loader.doQuery(Loader.java:701)
at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:236)
at org.hibernate.loader.Loader.loadEntity(Loader.java:1860)
at org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:48)
at org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:42)
at org.hibernate.persister.entity.AbstractEntityPersister.load(AbstractEntityPersister.java:3049)
at org.hibernate.event.def.DefaultLoadEventListener.loadFromDatasource(DefaultLoadEventListener.java:399)
at org.hibernate.event.def.DefaultLoadEventListener.doLoad(DefaultLoadEventListener.java:375)
at org.hibernate.event.def.DefaultLoadEventListener.load(DefaultLoadEventListener.java:139)
at org.hibernate.event.def.DefaultLoadEventListener.proxyOrLoad(DefaultLoadEventListener.java:195)
at org.hibernate.event.def.DefaultLoadEventListener.onLoad(DefaultLoadEventListener.java:103)
at org.hibernate.impl.SessionImpl.fireLoad(SessionImpl.java:878)
at org.hibernate.impl.SessionImpl.internalLoad(SessionImpl.java:846)
at org.hibernate.type.EntityType.resolveIdentifier(EntityType.java:557)
at org.hibernate.type.EntityType.resolve(EntityType.java:379)
at org.hibernate.type.EntityType.nullSafeGet(EntityType.java:204)
at org.hibernate.impl.IteratorImpl.next(IteratorImpl.java:112)
at org.geoserver.monitor.hib.HibernateMonitorDAO2.query(HibernateMonitorDAO2.java:273)
at org.geoserver.monitor.hib.HibernateMonitorDAO2.getRequests(HibernateMonitorDAO2.java:168)
at org.geoserver.monitor.Monitor.query(Monitor.java:148)
at org.geoserver.monitor.rest.RequestResource.handleRequests(RequestResource.java:285)
at org.geoserver.monitor.rest.RequestResource$HTMLFormat.toRepresentation(RequestResource.java:317)
at org.geoserver.rest.ReflectiveResource.handleGet(ReflectiveResource.java:88)
… 98 more
2014-06-27 10:34:13,093 DEBUG [org.geoserver.monitor.OpenSessionInViewFilter] - Closing single Hibernate Session in OpenSessionInViewFilter
2014-06-27 10:34:13,093 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
Hi again,
I tested also on Linux and it behaves the same.
It works properly on H2 db or memory storage.
I filled a bug for this.
http://jira.codehaus.org/browse/GEOS-6556
Stefano
41.95581N 12.52854E
2014-06-27 10:48 GMT+02:00 Stefano Iacovella <stefano.iacovella@anonymised.com>:
:2
Stefano
… 98 more
41.95581N 12.52854E
