[Geoserver-users] Error while adding new features to the WFS layer
Hi Some time when I try to add new features in my feature layer, I am
getting a error. Error is
<?xml version="1.0" ?>
<ServiceExceptionReport
   version="1.2.0"
   xmlns="http://www.opengis.net/ogc&quot;
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
   xsi:schemaLocation="http://www.opengis.net/ogc
http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd&quot;&gt;
   <ServiceException>
      *Feature type &apos;pointtest&apos; is not available: *
</ServiceException></ServiceExceptionReport>
This error only comes when I add new feature to layer and then try to save.
If I just press save after loading the layer and without adding any feature,
it is saved successfully.
I saw in geoserver, it show that this feature has been disabled. I think
this can be cause of error.
Any help..
Please I need this ASAP.
Regards
Pankaj Bansal
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-while-adding-new-features-to-the-WFS-layer-tp5092797.html
Any help on this please...
If required I can provide more info.
Regards
Pankaj Bansal
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-while-adding-new-features-to-the-WFS-layer-tp5092797p5092911.html
Hi Pankaj,
What version of GeoServer?
Also, can you include what is in the GeoServer logs after you’ve turned logging up to “Geotools_developer” level when this is triggered. That will give a better idea what the problem is.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 4 December 2013 20:40, pankaj123 <pankaj.bansal.jiit@anonymised.com> wrote:
*Feature type 'pointtest' is not available: *
Any help…
Regards
Pankaj Bansal
Sponsored by Intel(R) XDK
Develop, test and display web and hybrid apps with a single code base.
Download it for free now!
http://pubads.g.doubleclick.net/gampad/clk?id=111408631&iu=/4140/ostg.clktrk
Geoserver-users mailing list
