build successful. thanks.
Stefan
Von: Andrea Aime [mailto:aaime@anonymised.com]
Gesendet am: Montag, 28. Januar 2008 21:28
An: Ziegler Stefan
Cc: jdeolive; geoserver-users
Betreff: Re: [Geoserver-users] error while “mvn compile”
Ziegler Stefan ha scritto:
I changed to 1.6.x branch but my next error appears:
[INFO]
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 67 source files to
G:\my_geoserver\geoserver\ows\target\classes
[INFO][ERROR] BUILD FAILURE
[INFO][INFO] Compilation failure
error: error reading C:\Documents and
Settings\stefan.m2\repository\jaxb\jaxb-libs\1.3\jaxb-libs-1.3.jar;
error in opening zip fileerror: error reading C:\Documents and
error in opening zip file[INFO]
[INFO] Trace
org.apache.maven.BuildFailureException: Compilation failure
This seems a corrupt jar, a hard disk problem, or a memory hardware
problem. Let’s hope for the first, try deleting
C:\Documents and
and rebuild.
