I’m facing a strange problem that only happens on Linux. When trying to publish postgis layers which name is encapsulated with " Geoserver gives no error but is not able to publish the layer either. When checking the logs i could find the following:
relation “toponimia.lugares” does not exist Where: SQL statement “SELECT has_table_privilege((SELECT usesysid FROM pg_user WHERE usename = session_user), ‘toponimia.lugares’, ‘select’)”
I could immediately find the problem. In PostgreSQL the table is named as “lugares” and so, the previous query should be :
SELECT has_table_privilege((SELECT usesysid FROM pg_user WHERE usename = session_user), ‘toponimia.“lugares”’, ‘select’)
The stange thing is that I’m able to publish this layer when having geoserver installed in a windows machine. Is there any configuration i need to do in Linux to achieve the same result or is my only option to rename all tables?
I noticed that your problem went away, but even if it works now I am not sure if everything is correct. Double quotes around table names should be a hint for a SQL interpreter that you want to use do called delimited identifiers and according to ANSI SQL for example in your case the most correct SQL select should be written as
I would say that you call for troubles by using double quotas in table names, even it is allowed.
-Jukka Rahkonen-
Hugo wrote:
Dear all,
I'm facing a strange problem that only happens on Linux. When trying to publish postgis layers which name is encapsulated with " Geoserver gives no error but is not able to publish the layer either. When checking the logs i could find the following:
relation "toponimia.lugares" does not exist
Where: SQL statement "SELECT has_table_privilege((SELECT usesysid FROM pg_user WHERE usename = session_user), 'toponimia.lugares', 'select')"
I could immediately find the problem. In PostgreSQL the table is named as "lugares" and so, the previous query should be :
SELECT has_table_privilege((SELECT usesysid FROM pg_user WHERE usename = session_user), 'toponimia."lugares"', 'select')
The stange thing is that I'm able to publish this layer when having geoserver installed in a windows machine. Is there any configuration i need to do in Linux to achieve the same result or is my only option to rename all tables?
