Hi I am trying to load a .shp file on geoserver. I am programming in C++ and
using the curllib library. When I try to upload, a store is formed on
geoserver but no layer is published. Also if I try to publish the layer from
geoserver GUI, it gives a error.
Here is the code..
static size_t read_callback(void *ptr, size_t size, size_t nmemb, FILE
*stream)
size_t retcode;
curl_off_t nread;
/* in real-world cases, this would probably get this data differently
as this fread() stuff is exactly what the library already would do
by default internally */
retcode = fread(ptr, size, nmemb, stream);
nread = (curl_off_t)retcode;
fprintf(stderr, "*** We read %" CURL_FORMAT_CURL_OFF_T
" bytes from file\n", nread);
return retcode;
void pushSHPToPostgresGeoserver()
CURL *curl;
CURLcode res;
FILE * hd_src ;
struct stat file_info;
char *file;
char *url;
file= "D:\\shp\\test.zip";
url =
"http://192.168.0.65:8080/geoserver/rest/workspaces/opengeo/datastores/test/file.shp?configure=all";
/* get the file size of the local file */
stat(file, &file_info);
/* get a FILE * of the same file, could also be made with
fdopen() from the previous descriptor, but hey this is just
an example! */
hd_src = fopen(file, "rb");
/* In windows, this will init the winsock stuff */
curl_global_init(CURL_GLOBAL_ALL);
/* get a curl handle */
curl = curl_easy_init();
if(curl) {
/* we want to use our own read function */
curl_easy_setopt(curl, CURLOPT_READFUNCTION, read_callback);
curl_easy_setopt(curl, CURLOPT_USERNAME, "XXX");
curl_easy_setopt(curl, CURLOPT_PASSWORD, "XXX");
struct curl_slist *headers=NULL;
headers = curl_slist_append(headers, "Content-Type:application/zip");
/* enable uploading */
curl_easy_setopt(curl, CURLOPT_UPLOAD, 1L);
/* HTTP PUT please */
curl_easy_setopt(curl, CURLOPT_PUT, 1L);
/* specify target URL, and note that this URL should include a file
name, not only a directory */
curl_easy_setopt(curl, CURLOPT_URL, url);
/* now specify which file to upload */
curl_easy_setopt(curl, CURLOPT_READDATA, hd_src);
/* provide the size of the upload, we specicially typecast the value
to curl_off_t since we must be sure to use the correct data size */
curl_easy_setopt(curl, CURLOPT_INFILESIZE_LARGE,
(curl_off_t)file_info.st_size);
/* Now run off and do what you've been told! */
res = curl_easy_perform(curl);
/* Check for errors */
if(res != CURLE_OK)
fprintf(stderr, "curl_easy_perform() failed: %s\n",
curl_easy_strerror(res));
/* always cleanup */
curl_easy_cleanup(curl);
fclose(hd_src); /* close the local file */
curl_global_cleanup();
*Also it is showing the following error on my application console..
***We read 16384 bytes from file
java.io.IOException: Wrong magic number, expected 9994, got
1347093252[osgEarth ] *fAIL, unable to load scriptEngine driver for
"javascript"*
*The file is uploaded in my geoserver data directory. If I try to delete
that file, windows shows file in use, "The action cannot be completed
because file is open in java(TM) Platform SE Library"..*
This is the error being show on geoserver if I try to publish the store as
layer..
java.lang.RuntimeException: Error occurred while building the resources for
the configuration page
at
org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:302)
at
org.geoserver.web.data.layer.NewLayerPage$6.onClick(NewLayerPage.java:241)
at
org.geoserver.web.wicket.SimpleAjaxLink$1.onClick(SimpleAjaxLink.java:45)
at org.apache.wicket.ajax.markup.html.AjaxLink$1.onEvent(AjaxLink.java:68)
at
org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at
org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at
org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at
org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at
org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at
org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at
org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at
at
at
org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at
at
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:97)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at
at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:168)
at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:233)
at
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.io.IOException: Wrong magic number, expected 9994, got
1347093252
at
org.geotools.data.shapefile.shp.ShapefileHeader.checkMagic(ShapefileHeader.java:64)
at
org.geotools.data.shapefile.shp.ShapefileHeader.read(ShapefileHeader.java:84)
at
org.geotools.data.shapefile.shp.ShapefileReader.init(ShapefileReader.java:358)
at
org.geotools.data.shapefile.shp.ShapefileReader.<init>(ShapefileReader.java:251)
at
org.geotools.data.shapefile.ShapefileDataStore.openShapeReader(ShapefileDataStore.java:558)
at
org.geotools.data.shapefile.ShapefileDataStore.readAttributes(ShapefileDataStore.java:785)
at
org.geotools.data.shapefile.ShapefileDataStore.getSchema(ShapefileDataStore.java:743)
at
org.geotools.data.shapefile.ShapefileDataStore.getSchema(ShapefileDataStore.java:737)
at
org.geotools.data.shapefile.ShapefileDataStore.getFeatureSource(ShapefileDataStore.java:1071)
at
org.geotools.data.AbstractDataStore.getFeatureSource(AbstractDataStore.java:598)
at
org.geotools.data.AbstractDataStore.getFeatureSource(AbstractDataStore.java:89)
at
org.geoserver.catalog.CatalogBuilder.buildFeatureType(CatalogBuilder.java:327)
at
org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:295)
... 89 more
Any help..
Please I really need this ASAP..
Note : I have done the same thing in .net and everything worked fine for me.
Regards
Pankaj Bansal
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-while-uploading-shapefile-tp5095598.html
