[Geoserver-users] Error with gwc when using curl seedrequest with bounds
I have used json request with success
curl -x our.proxy.fi:8888 -v -k -u user:password -XPOST -H "Content-type: application/json" -d "{'seedRequest':{'name':'GWC_aerials','bounds':{'coords':{ 'double':['3200000.0','6800000.0','3300000.0','6900000.0']}},'srs':{'number':2393},'zoomStart':8,'zoomStop':11,'format':'image\/png','type':'seed','threadCount':4}}}" "http://localhost:8080/geoserver/gwc/rest/seed/GWC_aerials.json"
-Jukka Rahkonen-
stephanos_ch wrote:
Hello,
When using the following curl seeding task everything works ok:
curl.exe -v -u admin:geoserver -XPOST -H "Content-type: text/xml" -d
"<seedRequest><name>Layer</name><gridSetId>EPSG:900913</gridSetId><zoo
mStart>5</zoomStart><zoomStop>6</zoomStop><format>image/png8</forma
t><type>reseed</type><threadCount>3</threadCount></seedRequest>"
"http://localhost:8080/geoserver/gwc/rest/seed/Layer.xml&quot;
However when I include the boundaries:
"<seedRequest><name>Layer</name><bounds><coords><double>Xmin</doubl
e><double>Ymin</double><double>Xmax</double><double>Ymax</double></c
oords></bounds><gridSetId>EPSG:900913</gridSetId><zoomStart>5</zoomStar
t><zoomStop>6</zoomStop><format>image/png8</format><type>reseed</typ
the following error occurs:
Cannot construct org.geowebcache.grid.BoundingBox as it does not have a no-
args constructor
Please advice how to solve this.
Stephanos
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-with-
gwc-when-using-curl-seedrequest-with-bounds-tp5129526.html
Learn Graph Databases - Download FREE O'Reilly Book "Graph Databases" is the
definitive new guide to graph databases and their applications. Written by three
acclaimed leaders in the field, this first edition is now available. Download your
free book today!
http://p.sf.net/sfu/13534_NeoTech
Geoserver-users mailing list
Hello,
Unfortunately that didn't work either. I am using Geoserver 2.1.3
The full error given is
Accept: */*
Content-Length: 372
* upload completely sent off: 372 out of 372 bytes
< HTTP/1.1 500 Internal Server Error
< Transfer-Encoding: chunked
* Server Jetty(6.1.8) is not blacklisted
< Server: Jetty(6.1.8)
no-args constructor : Cannot construct org.geowebcache.grid.BoundingBox as
it does not have a no-args constructor
---- Debugging information ----
message : Cannot construct org.geowebcache.grid.BoundingBox as
cause-exception :
com.thoughtworks.xstream.converters.reflection.ObjectAccessException
cause-message : Cannot construct org.geowebcache.grid.BoundingBox as
class : org.geowebcache.seed.SeedRequest
required-type : org.geowebcache.grid.BoundingBox
-------------------------------* Connection #0 to host localhost left intact
Hope someone could help me.
Thanks in advance.
Stephanos
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-Error-with-gwc-when-using-curl-seedrequest-with-bounds-tp5130377p5133754.html
On Tue, Apr 8, 2014 at 9:39 AM, stephanos_ch <stephanos_ch@anonymised.com> wrote:
Hello,
> Accept: */*
> Content-Length: 372
Ah, I've already seen this one, it happens when an old XStream library is
told
to deserialize a XML when running on Java 7.
You have two choices:
* upgrade GeoServer to a more recent version, a recent 2.4.x series
* downgrade java to version 6
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
