[Geoserver-users] Error with gwc when using curl seedrequest with bounds
Hello,
i have a problem sending rest request with a seeding request with bounds to the gwc.
A request without bounds works fine, when i add bounds i get an Internal Server error.
Its the same when i try to use the gwc seed form.
I’m using:
Geoserver 2.5
Jdk 1.7.0_45
Tomcat 7
I found a similar thread in the list:
http://osgeo-org.1560.x6.nabble.com/Re-Error-with-gwc-when-using-curl-seedrequest-with-bounds-td5130377.html#a5133754
Is upgrading geoserver or dosngrading the java version really the only solution?
Dirk
