Hi am using pdf print module, and i get an error in my 2.1.4 geoserver, i have my geoserver in the "DEFAULT_LOGGING.properties" mode and in the final pdf file, i get all fine, but not the image, and this is the logs from the geoserver, and i need some help from you,i need to know what is happening, thanks to all.
2013-03-25 08:30:24,296 WARN [print.PDFCustomBlocks] - Error while adding a PDF elementjava.io.IOException: Error (status=404) while reading the image from http://10.8.194.221/geoserver/une/wms?BBOX=-75.88961%2C19.952135%2C-75.6105%2C20.258522&HEIGHT=335&WIDTH=306&TRANSPARENT=true&map_resolution=50&VERSION=1.1.1&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&format_options=dpi%3A50&LAYERS=une%3Asigfre_cub_Adm_Lineas_Ferreas%2Cune%3Asigfre_cub_Adm_Autopistas%2Cune%3Asigfre_cub_Conv_sub220%2Cune%3Asigfre_cub_Conv_sub110%2Cune%3Asigfre_cub_Ren_Inv_Biogas_Vacuno&REQUEST=GetMap&STYLES=%2C%2C%2C%2C&TILESORIGIN=-84.956%2C19.825&SRS=EPSG%3A4326: Not Found
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
