Ok, I finally had some time to really go through this.
The first feedback is about WMS Post. It's actually not an official spec, it's just a recommendation paper. Which is probably why you're having a tough time figuring out what parts of WMS have Post. My advice would be to just drop it from your survey, since it's not an official OWS spec. See http://lists.eogeo.org/pipermail/wms-dev/2005-April/000749.html for a bit more info and http://portal.opengeospatial.org/files/?artifact_id=1118 for the actual paper.
There also was a question in yellow about REMOTE_OWS_TYPE and REMOTE_OWS_URL being required with SLD. To my knowledge they are not, unless you are using SLD against a layer that doesn't exist on the server, is only on a remote server. The SLD spec is a bit ambiguous, they're actually splitting it out in to two specs, one to deal with the symbology, one to deal with remote services.
GetGmlObject is generally agreed upon to be a pretty worthless operation that was stuck in to the spec sort of as an after thought to make a few organizations happy. And none of those organizations were actually software developers. To my knowledge there are no implementations of it, and no one is planning to implement it, since it just doesn't make a ton of sense. We refused to touch it as part of WFS 1.1 reference implementation. I'm not sure how much of that you want to include, but it may make sense to mention a bit of explanation as to why none of the open source servers are implementing it.
GetStyles is not supported in GeoServer at all, and PutStyles is supported but not spec compliant. They are likely to be implemented in the not too distant future though.
You missed PDF as an output format for GeoServer WMS.
We don't support any GetGMLObject - I'd remove it from your matrix.
best regards,
Chris
John Roberts wrote:
Dear All
I am currently studying for a Master's degree in GIS with UNIGIS. I am
currently doing my dissertation which evaluates the main FOSS GIS web
service products (GeoServer, MapServer, Deegree Web Services & MapGuide Open
Source). I propose to compare and contrast the four products using the OWS
specifications.
I have taken the main part of my dissertation and created a document which:
1. summarises the OWS specifications (chapters 1 to 4).
2. summarises the organisational structure and functionality of the four
products (chapter 5).
3. creates a matrix based on the OWS specifications against which each
product is compared (chapter 6).
I have trimmed down the document for GeoServer by removing the sections
pertaining to the other 3 products. I attach the document to this e-mail.
I would be very interested for any comments/corrections people may have. I
have highlighted any area I am not sure of in yellow. I am mainly looking
for input as follows (in order of importance):
1. Chapter 6, the OWS matrix. There is alot of functionality which I am not
sure if GeoServer supports (such as GetStyles, PutStyles). I have tried to
gather as much information from the website as possible. However time
limitations has meant that I have not been able to investigate each product
as much as I would have liked.
2. Chapter 5, organisational structure. I have gathered as much information
from the website as I could find but I still have some queries.
3. Chapters 1 to 4, OWS specifications. I feel I have got most of the
information correct here but would welcome anybody who has the time to go
through this text.
I will acknowledge anybody who provides input in the acknowledgements
section of my dissertation. If the input is straightforward functionality
(e.g. GeoServer supports WFS GetCapabilities) then I would use the
information and I would not make an explicit reference. However, if I wanted
to make an explicit reference (for example if I am referring to a more
subjective comment with regard to the relative pros and cons of the 4
products) then I would contact the person again to ask his/her permission.
Once everything is complete, I would like to post the final document with
information on all four products on the mailing list.
Thank you all very much in advance for any time you are able to give.
Kind Regards
John Roberts
Manchester, UK
!DSPAM:1003,45d24342237101804284693!
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Chris Holmes
The Open Planning Project
http://topp.openplans.org
